Question about Lexmark Office Equipment & Supplies
Printer won't connect to wireless network
Everything works except the last step
  • emtownsend Jan 10, 2009
    Unable to connect to wireless either via Macintosh OSX or Windows XP Pro.
    Set printer to defaults and retried but no change.
    Downloaded newest drivers and again no change.
    Does this even work?
  • Matthew Ballew
    Matthew Ballew May 11, 2010
    More information would help, What is the Last Step?
  • 89 Answers
Sorry, but we still need more information...
Posted on Nov 25, 2008
Tip
WPS54G Printer Server Setup
I bought a Linksys Wireless-G WPS54G printer server and trie to put it in my home network. Following the instruction from the manufacturer and spent many hours, I still couldn't make the printer server work. There was no problem to get the IP address from my DHCP server using the wired connection. But when I pulled off the network cable and tried the wireless connection, I got "connection failed" error at the last step to install the printer server. I checked my router's client monitor and found the printer server did get the dynamic IP address wirelessly. When I pinged that IP address, there was no response at all from the printer server. In another word, the printer server couldn't communicate with other devices in wireless mode in the network. I searched the Internet and found there were many users had same problem and couldn't resolve the issue even from the manufacturer technical support. As a last resort before I was going to send back the printer server, I switched the network router to one of a different brand. My previous router was manufactured by BUFALLO INC and the new one was made by D-Link. After I rerun the installation following the instruction, the "connection failed" error was gone. The printer server could work finally.
The tip here is: Try a different brand router when there is a connection failure problem for installing the WPS54G printer server, if possible.
on Mar 02, 2008 | Linksys Wireless-G WPS54G Print Server
Brother MFC-7840w wireless printer won't connect to network. I have searched a ton of solutions on the web and have had no luck. I have several devices connected to my wireless network, but just...
Improve the Fixya.com experience for everyone by voting!
The solution I'm suggesting works in my business (LAN installations) about 95% of the time. I trust that it will work for you.
Let's see if I can help you.
Begin by turning on your computer and your router
Make certain that you have the latest drivers from Brother by clicking on the following link: Brother Driver Downloads
Open Control Panel and click on 'Diagnose Connection Problems' and follow the instructions.
The last choice is to use the Setup Wizard. It seldom works for me but you might more luck than poor me. Here are the instructions:
The Connect to the Internet wizard will guide you through the steps of setting up an Internet connection.
Open the Connect to the Internet wizard by:
• Clicking the Start button Picture of the Start button
• Click on Control Panel.
• In the search box, type network,
• Click "Network and Sharing Center"
• Click Set up a new connection or network
• Then double-click "Connect to the Internet".
This should have you up and running.
All the best
Ben
Jun 18, 2011 | Brother MFC 7840W Printer
Everything works well on my wireless linksys e2000 router my itouch, my computer except my samsung wireless lan adapter wis09abgn cant seem to connect to the internet on my Tv i plugged it in the usb slot...
IT looks like it might not be accepting the type of security on the router..try changing the security typa it might work.
(P.S. YOu might need to re-connect all the wireless computers to the new network once you change the security.)
Hope this helped.
Feb 13, 2011 | Computers & Internet
HP Photosmart c6380 wireless printer works fine, but windows xp does not recognize the scanner
  • First, we need to create the Ad hoc network that will provide wireless connection between your computer and printer. On the right hand portion of the Taskbar, you can right-click the wireless icon and choose "View Available Wireless Networks". Or you can double click the wireless icon, then click "View Wireless Networks". It is also accessible from the Control Panel. Either way, the same window as shown in step 2 will pop-up.
  • 2
  • setup-xp-via-ad-hoc-1.2-120x120.jpg View Wireless Networks The Wireless Network Connection window shows you all the wireless networks in range including the network where you are connected. If you have many neighbors with wireless networks, it will all show up. Click "Change advanced settings" and it will bring up the Wireless Network Connection Properties window. Choose the "Wireless Networks" tab and at the bottom click "Advanced" button.
  • 3 setup-xp-via-ad-hoc-1.3-120x120.jpg Wireless Networks Properties From the Advanced option window, choose "ad hoc" networks only. This is just to simplify the process. You should also bring this back to original setting after you are done connecting via Ad hoc. You may choose to skip this step if you wish and you should still be able to make the connection without a problem.
  • 4 setup-xp-via-ad-hoc-1.4-120x120.jpg Create the ad hoc network Click the "Add" button and type in a name for your Ad hoc network. Make it more intuitive so you can easily recognize your own network just in case there are other Ad hoc in range. Check off the automatic key and enter a 5 or 10 digit network key. This is the same key that you will input at the printer later. Click OK and then OK again. You are now connected to the Ad hoc network. You are half way through.
  • 5 setup-xp-via-ad-hoc-1.5-120x120.jpg ad hoc network Make sure the printer is ON as well as the wireless radio button. On the printer control panel, press the setup button to access the menu. Go to Wireless Menu and press OK. Press the arrow to go to Setup Wizard and press OK so the printer will automatically search for wireless networks in range. From the list of networks, find the SSID or Ad hoc name that you created and press OK and type in the network key using the alphanumeric keypad on the printer. The printer should confirm the connection in less than a minute. That's it! Try to print a test page to make sure everything is working properly.
  • Dec 06, 2010 | HP Photosmart C6380 All-In-One InkJet...
    Trying to connect printer to computer wireless
    1. Step 1 Check if your printer is network ready. Many newer models are designed to work on networks. Examine the documentation to see if your printer supports Wi-Fi (802.11x) or Bluetooth.
    2. Step 2 Add network support to your printer. If your printer is not already wireless you can connect it to a wireless routermag-glass_10x10.gif using the RJ-45 Jack (it resembles a large telephone jack). You can also buy an expansion card that will add a jack or buy an external print server that will connect to the USB or parallel port.
    3. Step 3 Connect your printer to the network. If your printer is not wired, you’ll have to connect it directly to your wireless router. Connect a networking cable from the RJ-45 Jack on the printer (or adapter) to the router. Plug it into any jack except the UPLINK. The printer should automatically connect to the network when turned on.
    4. Step 4 Install printer drivers on all computers. Using the disc that came with the printer or drivers downloaded from the manufacturer, install the printer’s drivers onto each computer on the network.
    5. Step 5 Print. You should be able to access the printer just like any other wireless device. Select the printer from the Print menu when you print.
    6. Share Your Printer in Windows
    7. Step 1 Install the printer. Set up the printer as normal on a machine that is already connected to the wireless network. Connect all necessary cables and install all necessary drivers.
    8. Step 2 Open the printers and faxes folder. Click "Start," then "Control Panel," then "Printers and Other Hardware" and then "Printers and Faxes."
    9. Step 3 Share your printer. Find the icon for the printer you just installed. Click the icon once and then select SHARE THIS PRINTER in the tasks pane on the left. Now, right click the icon, select properties and go to the SHARING tab. Click "Share Name," and then click "Okay."
    10. Step 4 Connect to the printer. On the other computers within the network, open the control panel and click "Printers and Other Hardware." Select "Add a Printer."
    11. Step 5 Select "Printer Connection." When prompted, select this option instead of the local printer. Find and select the printer you just installed and select it.
    12. Step 6 Print as normal. Next time you print a page, send it to your networked printer.
    Hope this Help.
    Cheers!!!!
    Jul 24, 2009 | Brother MFC 490cw Color Inkjet...
    I have a printer attached via USB to a wi-fi connected desktop in a WGR614g network which supports an additional ethernet-connected desktop and two wi-fi laptops. Can I make the printer wi-fi accessible...
    Do a search engine hunt for a "WIRELESS PRINT SERVER" and you'll bring up a Netgear WGPS606 for about $60-80 or a Linksys for $36-150 (the same one :-)).
    The Netgear has 2 USB A ports and 4 ethernet ports. You plug in your printer, activate the wireless part to receive a signal and you have a networked USB printer.
    I assume the Linksys works exactly the same way, except it may not have the additonal 4-port ethernet switch.
    Carl
    May 01, 2009 | NetGear WGR614 Wireless Router
    Wireless Setup
    well..I suppose we should determine that you have your small office/business network set up first, right? it's under network connections. If it's not there, then your printer will stay invisible. Is this a replacement or new install?
    Feb 17, 2008 | Brother MFC-8870dw Wireless Multifunction...
    Cannot scan using the wireless router
    You can't scan over a network, quite simply. When you set up networking with Windows, it asks if you want to set up "File and PRINTER sharing", unfortunately this does not include scanning, even if it is an All in One printer.
    Sep 07, 2007 | HP Photosmart C3180 All-In-One InkJet...
    143 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Don  Farrell
    Don Farrell
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
