Question about Sony KP-51WS500 51" Rear Projection Television
Video 1-7 the video 1 or which ever mode you are using, 1-7, stays on all of the time.
It doesn't matter what video I use. It looks the same on video 1 to 7. Thanks
Posted on Mar 26, 2007
Hi. I have a FLATRON W1934S computer. Every time I switch it on it says "power saving Mode". How can I fix it?
Hello, I didn't understand the problem.
1.After switch on and it goes to power saving mode , which can be visibly seen by changing the color of power led from green9or blue) to yellow.
First thing to be done is when it goes to that state "power saving mode" remove the video VGA cabl , and if the unit gives video message "no video signal" which stays for a while and usually goes again to power saving mode , this is OK,
So if there is no video signal on input it should work like this. so you have to check you PC.
Another way is to use laptop or other PC to check the monitor itself.
Hope this helps a bit
Oct 29, 2014 | Computers & Internet
Cant get my tv out of video 2 and i dont have the remote what do i do
Tries pushes the tv manual channel button up a couple times most tv can get out video modes or enter video modes like 1 and 2 modes.Or try website like Remotes.com to buy the tv original remote to use.
Jul 23, 2011 | Symphonic ST419E TV
How do i get video to workon my vivitar vivicam x327
Video Mode
Press the MODE button to select the Video mode.
Note: The camera has limited internal memory allowing you to record up to 20 seconds in QVGA. An SD
card (up to 8GB) needs to be inserted in order to use the video mode normally.
When the icon appears on the top left corner of the LCD screen this indicates that you are in Video
mode.
1. Prepare the object or subject you wish to record.
2. Press the Shutter button to begin shooting the video.
3. The elapse time will appear on the top right of the LCD screen and the icon will flash on the
LCD screen.
4. Press the Shutter button again to stop the recording and save this file in AVI format.
Note:
1. You can preview the AVI files in Playback mode or once downloaded to your computer by using
Quick Time and Windows Media Player.
2. When the camera's memory is full, the “Memory Full Insert a SD Memory Card to Transfer and
Shoot More video!” message will appear on the LCD screen when you attempt shoot more videos.
Download the test file from the internal memory to the PC or delete them to shoot more videos.
27
Alternatively, you can insert a SD memory card to expand the memory to record longer videos.
3. The LED will light up when the light condition is not good.
Feb 22, 2010 | Vivitar ViviCam X327 Digital Camera
We have a Brothers Fax 2820 that continually stays in the sleep mode. How can I take if off the sleep mode.
Press Menu/Set, 1, 6, 2.
2 Use the dial pad to enter the length of
time the machine is idle before it goes
into sleep mode (00 to 99).
Press Menu/Set.
3 Press Stop/Exit.
Jun 11, 2009 | Brother IntelliFAX 4100 Laser Fax
Z525a screen comes on but stays vacant.
If you have access to a laptop computer that has an Infrared Port or Bluetooth communications, you can download your videos and picture files via either of these two methods. I use an old IBM Thinkpad 600 with IR port to download mine. You have to put your z525 phone into Infrared mode first, its kind of tricky with out seeing what you are doing. First, open your phone, press upper right (-) sign to get menu, click joystick control down 2 times then right 1 time. next press upper left (-) sign to select. next joystick right 4 times, and down 1 time. press upper left (-) sign, then joystick up 1 time. press upper left (-) 1 time. Your Infrared Port will now be turned on, and your I.R. enabled laptop can now receive the files from your phone. Close your phone, open it again, press upper right (-) , press joystick down 1 time, then left 1 time, then press the joystick center select button 2 times. Joystick right 1 time, press joystick select 1 time. press upper right (-) 1 time, joystick down 5 times, joystick right 1 time, joystick down 3 times, joystick center select 1 time. Hold the lower left corner of your phone toward the I.R. port of the laptop, it will receive the first photo file in your camera pictures file. Another possible method would be to obtain a usb connector cable for the z525 phone to connect it to your computer. Using the usb cable the computer would recognize the phone, you could click on the phone icon, under "MyComputer" and transfer the files to your hard drive. I hope this helps. -Mike
Mar 09, 2009 | Sony Ericsson Z525a Cellular Phone
Sony KV-36XBR800 Video mode stays on screen all the time
Very easy fix.....just press the "display" button on the remote control so that the on screen display is turned off when you are watching TV.
Jan 29, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
TV will not stay in Stretch Mode
I know of no solution for this, it is the normal operating mode of the system.
Jun 28, 2017 | Philips Magnavox 51MP392H Rear Projection...
Defective mode function switch
possibly the contact points are damaged. plz check with the help of a electronics repairman.
Feb 17, 2008 | Cameras
My olympus turnsoff by itself when in camera mode.
Olympus Tewchnical Support- especially if of recent purchase. If an older camera - then simply buy the next one - repair is not an option.
Jun 18, 2007 | Olympus Camedia AZ-1 Digital Camera
How long can I record using a DVD-RAM disc?
• Extra Fine mode (3-9Mbps record speed): Approx. 20 min. minimum per side. • Fine mode (6Mbps record speed): Approx. 30 min. per side (1 hour total). • Standard mode (3Mbps record speed): Approx. 1 hr. per side (2 hours total).
Sep 05, 2005 | Hitachi DZ-GX20A DVD Camcorder
Sony KP-51WS500 51" Rear Projection Television Logo
32 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
