What cord do I use to connect a computer to a Toshiba e25 to have as print option. Or does this type of copier not have the option for the user to print from the computer. Note: I do not have the sales receipt for this copier nor can I find the specs, how would I be able to tell if this copier even has the option to print directly from the computer.
in Gestetner 3245 wat is the best developer type ( type 4 or type 5 ) wat is the different of the...
(More)
in Gestetner 3245 wat is the best developer type ( type 4 or type 5 ) wat is the different of the type 4 and type 5... i will use a refill toner sikomoro..?
Error Code E075-004 on a clc 1000 I have Re-position the transfer belt but I keep getting this error...
(More)
Error Code E075-004 on a clc 1000 I have Re-position the transfer belt but I keep getting this error code and told to turn off and then on but the error keep commin back. I was also told that i had to go into service mode and do this (E075/RLS in > Function > F-MISAp) But I have no ideal how to evon start to get to service mode. Can Someone Please Help Me?
i try to copy after processing error call service center f-28-3,please help me to solve this problem...
(More)
i try to copy after processing error call service center f-28-3,please help me to solve this problem i check everything nothing wrong,
hola como cambio el idioma de la canon np 6025 de aleman a español o dande consigo los...
(More)
hola como cambio el idioma de la canon np 6025 de aleman a español o dande consigo los manuales.. gracias
