Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Kitchenaid Icemaker leaking in big drips on front of freezer bins
Kitchenaid superba icemaker water is leaking and freezing in big drips down front of freezer bins.
  • Anonymous Dec 01, 2008
    water leaks from spicket drip after drip until i shut off the water suply
  • dcslice Jan 01, 2009
    We have the same problem! Big icicles running from the ice maker down the front of the storage bins. I guess the water line is blocked or the tray is unlevel(?)
  • KitchenAid Master
  • 19,396 Answers
Either the inlet valve is stuck or the icemaker solenoid is shored.
Most likely the second one.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Posted on May 22, 2009
2 Suggested Answers
SOURCE: kitchenaid superba icemaker leaking/freezing in freezer section
Thank you, I am going to go check right now
Posted on Nov 09, 2008
Kitchenaid refridgerator/freezer/icemaker model KBFS5ET5500 EVERYTHING WORKS BUT THE ICE MAKER...JUST QUIT. THERE DOES NOT SEEM TO BE A SHUTOFF VALVE AT THE BACK OF THE FRIDGE. I AM LOOKING TO SEE IF THE...
Hello Raymond,
In a most of cases if the filter were clogged it would affect BOTH the icemaker and the in door water dispenser,its never a bad idea to replace espically if they is a foul odor or taste in the ice or water. The water valve on the back is going to the most likely problem if the in door dispenser works yet the icemaker does not,a lot of times when the water valve is bad when its supposed to be fully closed cutting all water flow into icemaker it stays open a wee bit allowing water to seep through it causing the hose that connects to it ,running up the back wall into the icemaker to freeze up at the top where the tube enters into the freezer,that tube needs to be thawed, and to prevent it from freezing in the future the water valve needs to be replaced.
Goodluck,i hope this helps you to fix your icemaker,
Gene
Aug 09, 2011 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid Superba Ice Maker quit
If you add some water there, yourself. It should make some ice for you, untill the water runs out.
Try this
http://www.acmehowto.com/howto/appliance/icemaker/diagicemaker.php
Sep 08, 2008 | KitchenAid Superba Architect KSCS25INSS...
ICEMAKER HAS NO WATER IN IT AND ICE STRIPPER NOT MOVING BUT WATER DISPENSER WORKS KITCHENAID SUPERBA MODEL #KSCS23INBL00 SIDE BY SIDE WITH ICE AND WATER DISPENSER IN DOOR
First check to make sure the icemaker is on. Most icemakers have what looks like a wire that extends to the right. Down is on, up is off. If yours does not have this, there might be an on off switch on the icemaker itself. If the wire (bale) is on, or the switch is on, then the icemaker is defective, unless the freezer is too warm. Icemakers have a thermostat in them that will not let them operate if the freezer is too warm. Sometimes that thermostat will not activate until the freezer is 15 degrees.
Mar 03, 2010 | KitchenAid Superba Architect KSCS25INSS...
The icemaker on my KitchenAid superba KSBS25in does not work
Their might be an easy fix here. Try a hair dryer. heat the ice maker and dislodge a possible stuck ice cube( a common problem)
More HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 15, 2009 | Kitchen Ranges
Freezer and icemaker freezes, jams.
I have run into this before and found it very helpful to re-level the refrigerator. By leaning the fridge back toward the wall about an inch helped keep the water and ice in the tray. Remember to remove items that block air flow in the freezer. Remove the ice bin and clean it then start over with the fridge leaning back a little. Hope this helps.
May 01, 2009 | KitchenAid Superba KSRG25FK Side by Side...
Icemaker is not making ice.
check water valve /filter it maybe the ice maker
Apr 02, 2009 | KitchenAid Superba KSRS27CN Side by Side...
Kitchenaid superba icemaker leaking/freezing in freezer section
Your water hose that connects to the back of the freezer may be loose. Move the fridge out away and in the back make sure it is tightend.
Let me know if it helped :)
Oct 20, 2008 | KitchenAid Superba Architect KSCS25INSS...
Water leaking from ice/water dispenser
hi there,
you may have a kink in the water line leading to the icemaker. the leak is due to warm water entering the icemaker itself. i would also check the water valve in the icemaker itself and ice actuators or paddles to any breakage.
Sep 04, 2008 | KitchenAid (KSRD22FKST) Side by Side...
Icemaker Not working
No it should take about 24 hrs to get a full bin of ice. The most common problems with this style icemaker is the fill tube freezes which they have a replacement heated fill tube or the board on your freezer wall that pass a light through your ice bin to tell if its full or not stops working
Dec 05, 2007 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
3,006 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
