Question about Whirlpool Heating & Cooling
Capacitor wiring; whirlpool air conditioner modei@ acm184xj1
5 wires for the capacitor where do they go; 1red 1yellow 3 whites ????
  • 236 Answers
SOURCE: reinstall capacitor 370 vac from a/c
Here is the standard connection of dual capacitor. Actually you can see the diagram on the unit but Im not familiar with the Intertherm model. What can I give to you is only the standard connection of dual capacitor.
Posted on Feb 26, 2008
  • 3361 Answers
SOURCE: Air Conditioner compressor fan stops, Capacitor wired wrong?
Purple should be on "C".
The fan motor may be destroyed now. Switch the wire and see if it keeps running or not.
Posted on Apr 28, 2009
  • 588 Answers
SOURCE: Easy Start Capacitor
Click on type of AC, if you can’t find the information you want there,
then click on contact us on the Green Bar.
You can get Service Support or Email address and Phone numbers.
Posted on Feb 21, 2010
  • 674 Answers
SOURCE: 561CJ060-a bryant air conditioner two control wires disconnected
Sorry if I am answering this 2x. If it is just A/C then the red and white probably go to the coil for the contactor that cuts on the fan and compressor. If it is a heat pump then they probably go to a circuit board. Red to R terminal and White to W1 terminal. Let me know what you find.
Posted on May 03, 2010
Testimonial: "great help. unfortunately there is something else wrong with this item. Thanks. Mike"
  • 43501 Answers
SOURCE: wires popping off the capacitor of my central air
remove all power and then take a pliers and carefully squeeze the clips a bit tighter so that they fit on the tabs hard...
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
Posted on Jul 19, 2010
How do I replace a power cord on a GE Window unit Air Conditioner?
the best thing is take one wire off at one time black to black white to white red to red thats the best i can do
Jun 24, 2014 | GE Electronic Room Air Conditioner AGW12AH
How do i wire a run capacitor 3 terminals to a 2 terminal run capacitor?
just hook the brown wire to one terminal of your new capacitor and brown/white to the other dont worry about the rest if it leave the wire off the f of the old three wire capacitor you now have two two wire capacitors one feeds compressor the other feeds fan
Jun 26, 2012 | Goodman CKL60AR60 Air Conditioner
I bought a replacement Dayton electric condenser fan motor. The original GE had 3 wires. L1 L2 & the fan capacitor wire. The Dayton replacement model 4MB21 has 4 wires, L1 L2 and 2 capacitor wires tan...
The tan/white wire can be insulated/capped and not used. Use and ohmmeter to take a resistance reading between the tan/white wire and L1 & L2. There will be no resistance between the tan/white wire and one of the others. This will be the common wire. Connect it to one side of the contactor. Connect the tan wire to the fan terminal on the contactor and the other wire to the common terminal on the capacitor (that is if you have a 3 terminal capacitor, if you have a 2 terminal capacitor connect tan to one side and the other wire to the other). Then connect the other side of the contactor to the common terminal on the capacitor (on a 2 terminal capacitor connect the contactor to the side that doesn't have the tan wire on it).
Aug 16, 2010 | GE Heating & Cooling
Wire an AC fan motor
Look at the schematic on the new motor , but i think if the 2 purple wires go each one to each side of the capacitor, the black to line and you need to connect the other line which Im 99% sure is the whte wire which is the only one left.Remember you need 220v between the fan motor lines for it to work.
Sep 30, 2009 | Carrier 38CKC036 Air Conditioner
Trying to install a fan motor for my outside ac unit replacement motor has 5 wires on it. my old on had only 3 driving me nuts
Your old moter had three wires. Common High and brown for capacitor. This one sounds like a two speed. Dont worry Now you have two brown wires for you capacitor instead of one. Tape off brown wire with white strip. Connect other brown to cap. You should have a white or yellow for common wire and black for high. Tape of the other extra wire and wire in like the three wire. Rusty
Jun 03, 2009 | Continental CE-PAC1163 Air Conditioner
check the capacitor of the fan motor wiring will be done in parellel to the compressor check the wiring.
May 31, 2009 | Whirlpool ACQ122XK Air Conditioner
Fan does not work.
I'm working on one right now and I believe it's the capacitor. It's hard to find this capacitor. So far I've tryed 3 HVAC suppliers and none have this rare capacitor. First UNPLUG THE UNIT. Take the phillips screws out of each side in the front. Then take the 3 screws out of the face of the control. There are 3 white common wires and a dark brown compressor wire and a light brown fan wire. Take the 1/4 inch screw out and unplug the wires and find another one.
Aug 05, 2008 | Whirlpool ACQ158XP Wall/Window Air...
Heating & Cooling Logo
259 people viewed this question
Top Whirlpool Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Tim Whalen
Are you a Whirlpool Heating and Cooling Expert? Answer questions, earn points and help others
