Question about Jensen Car Audio & Video
When i tried to hook up the car radio it would not turn on
  • 65 Answers
Can you elaborate on the problem... there are alot of things that could be wrong by what you have said... Try giving us a description on what you did and what you have tried...
Posted on Nov 25, 2008
WON'T TURN ON
un hook the radio and harness. take the red and yellow wire and hook them together. take a jumper wire hook the ground and the red and yellow to a battery and see if it will turn on that way if not the you have a bad radio.
Nov 26, 2013 | Clarion VX401
Error code 02-66 when I try to use my ipod with my pioneer head unit
I fixed it! I had a working set up. I synced my iPod touch and update the software, then hooked it back upto my car stereo. I received error code 02-66. I disconnected the iPod and cable from the radio. Turned off the radio restarted the iPod. Turned radio back on with main menu displaying on iPod I hooked it back up to the Pioneer radio. Vuala! It works. Hope this helps.
Aug 09, 2013 | Car Audio & Video
Radio just makes whistle sound doesnt matter if mic hooked up or not same with antenna,worked great when bought lasted 2 days had fixed 2 days again had fixed again worked 1 day as soon as you turn on...
What type of power source is it hooked to? straight to car battery or some other power source? Sometimes cart alternator noise is picked up by radios. Try hooking the power source up differently
Mar 19, 2011 | Connex Radio Communications
I just bought an Alpine CDE- 103BT. When i turn it on, the radio works well but when i try to put a cd on or usb flash drive....no sounds...Help me pls
you have the wrong remote wire hooked up on the radio. there is more likely a blue, and a blue/white on the radio wires. hook it up to the blue/white, or if that doesn't work try an accessory 12v wire from somewhere else
Jan 30, 2011 | Car Audio & Video
I have an AudioBahn A4004T Amp. It was working fine and then I had it sitting in my house for a few months. My cousin wants to use it in his car so he hooked the power cables up to his battery to see if it...
If you only hooked up the power and ground the amp will not turn on. You must also hook up the remote wire. This either can come from your radio, your fuses, or your power wire itself. If you hook it up to your radio then it will turn on when the radio is turned on. If your radio doesn't have a remote wire to amp then you can read your owners manual and hook it up to the radio fuse and when the radio turns on the amp will turn on. An lastly you can run a wore from your power wire to your remote plug in. But if you do this the nano will constantly be on if it is hooked up to the battery.
Dec 25, 2010 | AudioBahn A4004T Car Audio Amplifier
Have to turn the radio off manually and the clock radio stays on
Your radio power wire is hooked to the wrong power wire in the dash. The stock radio was hooked to a wire which was only hot when the ignition was turned on. A second wire provided continuous power to maintain the radio presets.
Jan 28, 2010 | 2004 Ford Escape
Hooked up subs in my 07 tahoe radio plays but truck wont start
when you turn off the radio and subs does the car start?
do other things work in the car like headlights indicators brake lights
i sugest you turn off the radio and start car or unplug the subs from the battery and try
Dec 31, 2009 | 2007 Chevrolet Tahoe
My alpine v12 turns on but no sound
no you don't have to hook up both of the power terminals. but should have it hooked up so you get the proper power to the amp. use a disubution block with two 8 gauge wires.
do you know if the radio's rca jack's are good? have you ever had another amp in the car? if it worked before try new rca's from the radio to amp. recheck all connections from amp to speakers and make sure no wires fell off.
Sep 22, 2009 | Alpine MRD-M605 - V12 MONO AMP 600WX1 RMS...
I have a 1992 eagle talon tsi im trying to hook up stereo
there is a "remote" wire that turns it on-sounds like you hooked it up to your lights. It needs to be hooked-up to the ignition so your radio turns off and on with the engine. Your power wire can go to the battery if you absolutely can't figure out which 1 it is that old radio used, but the remote wire must be hooked up right to turn it off so you don't leave it on and run the battery down.
Aug 31, 2009 | Car Audio & Video
I AM TRYING TO HOOK UP AN AMPLIFIER IN A STOCK 04'dodge stratus.
you should be able to hook it the power antena at the power intena there should be 3 wire one power one ground and the other is the one your looking for take a volt meter or a test light and find the one that gets power when you turn on the radio and turns off when you turn off the radio
Aug 25, 2009 | 2004 Dodge Neon
Car Audio & Video Logo
22 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
