Accelerator accelerates too much the game
Hey guys, i recently got an acer aspire one netbook, it rocks really, i been trying to play freedom fighters and guess what, the games runs really fine and fast, TOOOOO FASTTTTT, it looks like its 80 or 90fps and i cant play like this, anyone knows how to fix that?
i have 1gb ram, 120gb hd, intel media mobile graphics accelerator, i tried messing up with the accelerator configuration but couldnt do anything, can anyone help me fix this?
I was playing Bewelled 3 on my Acer Netbook and the screen went into horizontal lines and I was unable to see anything. Turned it off and on again and cant see the startup screen, still horizontal lines.
I'll give you some simple solutions...
(i) Juz connect to external monitor, if it working fine surely it is the problem with the LCD.
(ii) Plz make sure that the configuration support this game.
(iii) The last option is repair / re-install the operating system, coz while you tried force shut down, the system files may corrupted...
Thanks & Regards
Anas K A
May 28, 2011 | Acer Aspire 4720 Notebook
Tip
Ea electronic art freedom fighters pc
<pre>
tips.....
too fast and crash audio unsync
this because your pc is too fast
this works on winxp, not tested on ther os but try the same proccess might work..
2 option is available
1. on freedom fighters directory look for freedom fighter.ini open it and
find disablevsync (change this to enablevsyc) then right-click on
application ico then select properties change the
compability to 95 or 98 ( this sync does not include audio
2. start the game then alt+tab then endtask ctrl+alt+del then find
freedom fighters.exe right-click change affinity and disable either
1 or 0 cpu to reduce cpu processes speed, and back to game now
you can observe the audio is sync w/o eax creative audio card
by korotchan
note: everytime you start the application need to repeat 2nd step.... taskman resets the setting, or you can use processes control application
like coreaffinity application
</pre>
on Nov 01, 2010 | Video Game Consoles & Games
What is code back case FREEDOM FIGHTER Iam forget,. My cd case has gone..,.,.,
WHAT I WILL DO BECAUSE I WANT TO INSTALL FREEDOM FIGHTER GAME BUT THEY ARE ASKING FOR THE AT THE OF THE CD CASE AND I HAVE LOST MY CD CASE .
Nov 10, 2010 | EA - Electronic Arts Freedom Fighters for...
When i am playing the game of igi project destop
That means that the video card in your computer does not have hardware acceleration, does not have it turned on, or lacks the proper video drivers to use the hardware acceleration.
Upgrading the video drivers is one thing to try.
Upgrading your DirectX version is a second.
May 14, 2010 | Acer Aspire 4315 Notebook
Hi - I have an Acer Aspire One netbook & Acer Game problem
You can check the basic system requirement for the game and then check whether your laptop meets the requirement or not.
If your system meets the requirement then you can try to uninstall the game and then reinstall it.
This should help you.
Mar 20, 2010 | Acer Aspire One PC Notebook
Acer aspire 5600 shut down
the only way you can upgrade the graphics on a laptop is to purchase a graphics accelerator card that plugs in to the usb slot, its not an upgrade as such but it will allow you to play high res games on the laptop, there would have to be a memory upgrade to go with that also
Nvidia are doing some good laptop accelerators at the moment but they are expensive!!!
kind regards
Nov 17, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Playing high graphics games on acer aspire 4315
Check the requirements printed at the back of each game. this will tell you if the game runs. If some game is slow try disabling the antivirus while you run the game, remember to restart antivirus afterward.
Do not use software accelerator, majority of them are useless, some of them carries malaware and viruses.
Aug 13, 2008 | Acer Aspire 5100 Notebook
Logitech Freedom wireless joystick
i have had similar problems... it might be the disk also if the disk is really old it might not play properly becuase your computer is to new.but if that isent the problem your joy stick might only hook up to a desk top if you have considered these issues and nothng seems to effect it well ... get a joy stick that needs to be hooked up ... hope i helped
Jul 27, 2008 | Sony Logitech Freedom (vs9632830403)...
Graphics
Turn on the hard ware acceleration in the game menu. If it's the same, then turn up the acceleration from the advanced button in the diplay properties, settings tab.
Jul 08, 2008 | Acer Aspire 4520-5582 Notebook
Acer Graphic Card
your grapics card is 128mb. and the most new game wont a 256mb grapics card and an avaible 1gb ram or more and your card is an onbord on you can't replace it.
May 21, 2008 | Acer Computers & Internet
Computers & Internet Logo
91 people viewed this question
Alun Cox
David Payne
David Payne
