Question about Panasonic AG-456 Camcorder
Camera has become lemon. (AG-456/NV-M40?)
Hrmm, I recently bought a well used AG456 off ebay and it worked for about half a year before the thing decided it didn't want to record properly in S-VHS mode, eg. only in VHS. This pissed me off, so I decided to take a look inside to see if anything was amiss, and to give it a nice good clean of the heads and such. Well this proved to be a bad idea. Some parts of the camera showed signs of salt exposure and corrosion, especially the rear power distribution circuit board. (i dont know what this is called, but it's near the battery slot and has the system clock battery on it) I took all necessary grounding precautions and then removed the board and cleaned the salty parts with a non abrasive sponge. Then after everything was connected and dry, I put it back together. Now upon switching on the camera nothing works AT ALL except the viewfinder which displays a flickering "0000" and only one button seems to effect it, which is the counter DISPLAY button, which then makes the viewfinder display "M000". No other functions work - eg. tape eject or zoom. I've even plugged the camera video and sound outputs into tv and no image is produced. I am no technical genius, but i do know that i've probably done something fairly stupid along the lines of opening up the camera. If anyone has any idea what I have done, or what I could to do to fix this, help would be much appreciated.. I miss using this great camera! Thanks!
  • 2 more comments
  • Ben Hewbe Jan 17, 2007
    Thankyou Udupi. I shall try your solution.
    I appreciate your help, on what I thought would be a problem no one could help with.
    Thanks
  • Ben Hewbe Jan 25, 2007
    Hrmm I seem to be able to find no way of responding to you on this Udupi, so...
    I'm afraid I might need some more information on the solution to this problem.
    What/where exactly can I find the Process board to main board connector.
    Or which parts are the process and mainboards...
    Thanks for your help Udupi.
    Klaus
  • Ben Hewbe Jun 30, 2007
    Holy cow!!!!
    Thankyou so much!! You've made me life 100% percent happier!!
    Thankyou Udupi and thankyou tvservice for your excellent help and down to earth instructions.
    I wasn't really sure what the process board was or anything, but when you said 'they lay upon each other' i looked for a connection and found it.
    It works!!!!!!
    Thankyou!!!!!
    Cheers
    Ben
    Solved Solved solved!!!!
    (Sorry the Fixya rating page doesn't work for me!!!!)
    Thankyou!!
    Champion:
  • 221 Answers
When you disassembled the camera, the process board and the main board were connected via a connector. The boards physically lay one on top of the other; the connector lies between them. When the camera is re-assembled, you need to make sure this connector re-seats when the boards are pressed together.
Posted on Jun 28, 2007
    Problem Solver:
  • 19 Answers
Dear sir, Your not fixed Process board to Main board connector properly, if you fixed properly "0000" indication in EVF that will go off. Then you have to check other complents. Thank u. Reply if any problem. Raghavendra Udupi Ms.Prathiksha Electronics
Posted on Jan 17, 2007
Zoom Buttons stopped working,manual ok
Your problem is most likely one of three things: the zoom rocker (or wires connecting it to the main control) have gone bad, the zoom motor has failed, or you have bad capacitors in the camera which are causing the controls to not operate as they should. In any case, the camera will probably need servicing to restore it to complete function.
Nov 30, 2010 | Panasonic AG-456 Camcorder
User manuel for panasonic nv-m40 vhs video camera
Hi.
Please click here to download the instructions manual: Panasonic-NVM40 (English).
Jul 16, 2010 | Photography
No color in the viewfinder
ag-456 vf is black and white only.
Apr 24, 2009 | Panasonic AG-456 Camcorder
Can I use Panasonic AG456 camcorder on PAL system ?
le istruzioni che ho scaricato parlano di NTCS sistem
Ma in editring si pu? convertire in pal con power director oppure usando un software di conversione anyconverter pal
Dec 06, 2008 | Panasonic AG-456 Camcorder
This camera is making a sound when recording and also the lens has devloped some fuzz inside. Please let me know where they can service and clean lens out. Also I need an to purchase a new battery. Thank...
the sound you refer to during recording on the ag-456up is probably bad bearings on the video head. unfortunately, this part is no longer available. any good electronic repair shop should be able to clean the lens. a new battery should be available from wal-mart, circuit city, best buy, etc.
Oct 15, 2008 | Panasonic AG-456 Camcorder
Panasonic AG-456up s-VHS Camcorder
the panasonic 9000 video camera is good
Oct 04, 2008 | Panasonic AG-456 Camcorder
AG-456
the ag-456 only outputs composite video. if your pc has a video card with a composite imput, you may be able to use the ag-456.
May 23, 2008 | Panasonic AG-456 Camcorder
Panasonic ag456
these camera should operate with only the adapter, but they are notorious for having broken solder connections on the rear board where the audio and power connectors are. disassemble the camera and re-solder the connectors on the board; you may need to add a little epoxy glue to help hold the audio connectors.
Sep 25, 2007 | Panasonic AG-456 Camcorder
Any have the Panasonic ag-455 SVHS manual?
Hey I think it would difficult to find a manual for a AG-455, though being very similar to the AG-456 (which seems to be more popular) would you be happy with the manual for that model? I downloaded the AG-456 manual from somewhere last year but unfortunately can't remember from where. I do have the PDF file if you're interested though.. Would be happy to send to you if you're interested. Cheers
Nov 15, 2006 | Panasonic AG-455 Camcorder
Panasonic AG-456 Camcorder Logo
205 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
