Question about Cuisinart Grind and Brew 10 Cup Coffee Maker
Won't brew any coffee
The only light that is on is the green program light, when we try to set the time we hold until flashing set the time and then what...? because it just reverts back to what was there.  HELP!, this brewer is fairly new.
  • 8,596 Answers
Press the program set button one more time to exit program mode.
Posted on Dec 17, 2008
All I need is the manual to my Mr.Coffee Pot how to set the timer to Mr. Coffee GBX23.
First set the clock on the brewer with the unit plugged in. Press and hold the Hour and Minute buttons until the current time is set. Next press the Delay Brew button while using the Hour and Minute buttons to reach the time you want the coffee to begin brewing.
Set up the coffee maker with ground coffee or beans and sufficient water in the reservoir then follow the directions below.
For brewing with fresh ground beans, press and hold the Delay Brew button until it flashes then press Select once. The Grind and Brew light should come on and the Delay Brew light should become steady.
For ground coffee, press and hold the Delay Brew button and then press Select twice. The Brew Only light and the Delay Brew light should both be on and steady.
Most Mr. Coffee product manuals are here: http://www.mrcoffee.com/InstructionManuals.aspx . The direct link to the GBX23 manual is http://www.mrcoffee.com/Manuals/MANUALS/GBX23_43_50118420.PDF .
I hope this helps.
Aug 20, 2011 | Mr. Coffee GBX23
How do I program the stay or go coffee maker to turn on at a certain time, I worked the past few evenings, but the green light will not come on, I did have trouble the other times also
To Program Automatic Brew
1. Make sure clock is set for correct
time of day.
2. Press PROG button and digits will
flash.
3. Press H and M buttons until desired
brewing time is reached.
4. Press PROG button to confirm setting.
Digits will stop flashing and
return to set time of day.
5. Once brewing time has been set,
follow this procedure:
• Follow steps in "How to Make
Coffee."
• Push AUTO-ON-OFF button once
and "Auto" will be shown in display
indicating the brew cycle will begin
at the set time.
NOTE: If AUTO-ON-OFF is pushed
twice, the light will glow and brewing
will begin immediately. Press AUTOON-
OFF once to turn off and once
more to set programming mode.
Jan 13, 2011 | Hamilton Beach Stay or Go 45234 Coffee...
Greetings: Problem with auto grind Cusinart DGB600 coffeemaker. Properly prepared coffeemaker to brew coffee but noticed time is replaced by - - - . Suspected it was time to replace cleaning filter, which...
sounds like the coffee maker had a power surge. Try setting the time again.
1. Setting the Clock When the coffeemaker is plugged in, 12:00 will appear until you set the time. Entering "Time Set" Mode: To set the time, hold down either the "Hours" or "Minutes" button until the clock begins flashing (about 2 seconds). You are now in the "Time Set" mode and can operate either button to achieve the desired setting. The buttons can be held down to scroll through the digits, or pressed and released lightly to advance one digit at a time. When scrolling, the numbers will advance slowly at first and then speed up to the rate of about three per second. When the number displayed approaches the desired setting, release the button and press repeatedly to advance one digit at a time. Be careful to make sure that the PM indicator is on if a PM time is desired. Exiting "Time Set" Mode: The "Time Set" mode can be exited in one of two ways: 1. Press any button besides the "Hours" or "Minutes" button. This will exit the "Time Set" and activate the selected function. 2. Do nothing. If neither the "Hours" nor "Minutes" button is pressed for a period of five seconds, the "Time Set" mode will be exited. 2. Setting the Program Ti m e : When you press the "Program Set" button, it displays the current program time (default time 12:00 p.m.). Entering "Set Program Time" Mode: Press and hold the "Program Set" button (about 2 seconds) until the green light and LCD display begin to flash. This signals that you have entered the "Set Program Time" mode. The desired time can be set by pressing the "Hours" and "Minutes" buttons to scroll forward through the digits. Pressing and holding either button will allow you to scroll continuously, slowly at first, and then to accelerate to the rate of about three digits per second. As the desired time setting approaches, release the button and then press repeatedly to advance one digit at a time. The coffeemaker will start to brew at the programmed time. The "Program" mode cannot be entered if the c o ffeemaker is in its "brew" cycle. Exiting "Set Program Time" Mode: "Set Program Time" may be exited in any of three ways: 1. Press the "Program Set" button. This will cause the coffeemaker to revert to its previous state. If it was OFF, it will return to the OFF position. If "Programmed", it will revert to this state, and so on. This is a safety feature. 2. Press any other button (except "Hours" or "Minutes"). "Set Program Time" will be exited and the function of that button will be executed. 3. Do nothing. If neither the "Hours" nor "Minutes" button is pressed for a period of five seconds, the "Set Program Time" mode will be exited and the programmed setting will be in effect.
Dec 28, 2010 | Cuisinart DGB-600 Coffee Maker
I have Mr Coffee APX33; I do not know how to set the coffeemaker to turn on automatically. I do not have the manual. Hope you can help. Thanks! Larry
First you have to make sure to set the clock for the correct current time:
Press down and hold the SET button. Then alternately press the UP and DOWN buttons (indicated by arrows), until you reach the current time, then release the SET button. (there is a PM indicator on screen but not an AM indicator - if you don't see the PM you are at AM)
To set the time for the brew to start in the future:
Press and release the MODE button once and the Delay Brew Clock picture will start flashing on the screen.
While the Clock picture is flashing - hold down the SET button while you use the UP and DOWN arrow buttons to set the desired brew time (you can hold down an arrow button to get there faster). Release the SET button and now that brew time is programmed. (After a few seconds the clock picture will disappear but the future brew time is programmed.)
To activate the delayed brew:
Press and release the MODE button once. The Clock picture will be flashing and the time shown will be the time that you previously set for the future brew). While the Clock picture is flashing - press and release the BREW button. The Clock picture will remain on steady. The BREW light will not come on until the time in the future that you have programmed.
Pretty confusing - but it does work. Just remember that if you see the Clock picture on steady - the machine will come on at the time you have set in.
If you want to use the machine earlier - while the Clock picture is steady - you just press the BREW button and it will brew.
If the Clock picture is steady but you want to cancel the automatic future brew - just press the BREW button twice. (This turns it on and then off and cancels the future brew).
I can send a copy of the manual if you like. Lennyg678@aol
Sep 17, 2010 | Mr. Coffee APX33 Coffee Maker
Set time to start brewing in the morning
The following instructions shuld have you in hot coffee in the am.
S E T T I N G T H E C L O C K A N D D E L A Y B R E W T I M E
On programmable models CGX20/CGX23 & CGTX84/CGTX85 only
To Set the Clock:
1. Plug the power cord into a standard electrical outlet. The clock will flash on the control panel to
indicate that the time has not been set yet.
2. Press and hold the HOUR and MINUTE buttons until you
reach the current time. The PM indicator will light on the left
of the display.
The clock is now set!
NOTE: Pressing any button before setting the clock will cause
the clock to start keeping time from 12:00 a.m. You must set
the clock if you want to use the Delay Brew feature.
To Set the Delay Brew Time:
After setting the clock, simply press and hold the SET DELAY
button (Figure 1), and set the brew time by pressing the HOUR
and MINUTE buttons. The PM indicator will light up on the
clock display.
The Delay Brew Time is now set!
NOTE: To activate the DELAY BREW cycle, see the “Brewing Coffee Later” section.
To check the programmed time, push the SET DELAY button. The display will show the time you have
programmed the coffee to brew.
http://www.mrcoffee.com/Manuals/MANUALS/CGX20_43_62164399.PDF
Dec 30, 2009 | Mr. Coffee CGX20 12-Cup Coffee Maker
No instructions on programming auto shut-off time (feature listed on box).
You have to use the "Auto-Off" feature, which is located on the same button as on/off:
The automatic shutoff time (ASO) can be
programmed to shut off immediately after
brewing (0:00) or up to 4 hours later. The
default shutoff time is 2 hours.
Press and hold the On/Off button to display
current shutoff time. To change the preset
time, press and hold the On/Off button until
the red power light and LCD display begin to
Set automatic shutoff mode. Set the time
you want coffee to begin brewing by
following the instructions in “Entering Time
Set Mode.”
When the coffeemaker shuts itself off, two
tones will sound.
NOTE: Automatic shutoff may be
programmed either before or during coffee
brewing. If you program the auto shutoff
time after brewing is completed the unit
will automatically account for elapsed time.
For example, if you set the auto shutoff for
40 minutes and 25 minutes have already
elapsed, the unit will shut off automatically
after 15 minutes (40 minutes minus the 25
elapsed equals 15 minutes).
-Tha Mp3 Doctor
Apr 15, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
WARMING PLATE DGB 300
The Automatic Shutoff Time can be programmed
anywhere from immediate shutoff
after completion of the brew cycle up to four
hours. When the coffeemaker shuts itself off,
two tones will sound. Four hours is the default
time. The 0:00 setting shuts the unit off immediately
after brewing is complete. To check the
current setting, press the “On/Off” button and
the Automatic Shutoff Time will be displayed.
To change the preset time, press and hold the
“On/Off” button until the red “power” light
begins to flash. This signals that you have
entered the “Set Automatic Shutoff” mode.
Press the “Hours” and “Minutes” buttons
to scroll forward through the digits until
desired time appears. The first setting which
appears is preset at “4:00” and the next
display will be “0:00”, since four hours is the
maximum Automatic Shutoff setting. Pressing
The Automatic Shutoff Time (ASO) may be
brewing. You may also re-program the ASO
time when brewing has been completed. If you
do so, the Automatic Grind & Brew™ will automatically
account for any time that has already
elapsed after brewing.
Feb 01, 2009 | Cuisinart Grind and Brew DGB-300BK 10-Cup...
Braun Coffeemaker Programming
to prgram the automatic operation, press the automatic buton until the green pilot light begins to flash. The time "12:00" or the previously programmed time appears on the display. When the green pilot light begins to flash, release the button and press the hour and minute buttons until the correct shows; ensure the hours are am or pm. After programming is completed, the green pilot light will go off after 5 seconds.
Dec 08, 2008 | Braun FlavorSelect KF 180 Coffee Maker
Program light and 12:00 are flashing, no buttons work
Press program set once, then switch to clock mode to set time.
Sep 27, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Farberware FCP512S coffee pot instructions
How to set the time:
Plug the unit in
Wait until the hour on the LCD starts blinking
Press the CLOCK button to set the correct hour
Press the SET button to switch to minutes
Press the CLOCK button to set minutes
Press the SET button to accept the time
***there is no AM icon, only PM***
How to program delay brewing:
Press and hold SET until the hour begins to blink
Press PROGRAM until you see the tiny bell icon on the bottom of the screen
Press CLOCK until you get to the hour you want to start brewing
Press SET to switch to minutes
Press CLOCK to get to the minutes you want to start brewing
Press SET to finalize
Press PROGRAM to activate. When the little bell is flashing, the coffee pot is set to go on at the desired time. While the coffee pot is on or in warming mode, there are vertical lines on the top of the LCD screen that shows you it is on. If you press the ON/OFF button, you can turn it off before the two hour keep warm cycle is complete.
Hope this helps
Sep 09, 2008 | Mr. Coffee ISX23
Cuisinart Grind and Brew 10 Cup Coffee Maker Logo
115 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Tony R.
Tony R.
Richard Roth
Richard Roth
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
