Question about Princeton Digital VL1918 Monitor
No Display on Monitor (Princeton VL1917)
The monitor has been working fine. I connected it to my laptop and set it to display both on laptop screen and external vga screen. Worked for a while, then monitor was blank. Now, no display even when connected directly to desktop. When monitor is first turned on, very brief flash of screen, then blank. Is there a setting that would cause this? Any suggestions on a fix?
Thanks,
~Marc
  • 153 Answers
Try leave it for some time and try it again to the PC, when you connected it to the laptop it must have auto configs it selfself too suit the laptops resolution.
Posted on Nov 25, 2008
When i turn on my dell vostro a860 the screen is black.When I plug in external monitor shows pictures on both (monitor and laptop).When I disconnect external monitor the laptop works fine.The trouble is...
Windows Vista® 1 Right-click an open area of the desktop. 2 Click Personalize. The Personalize appearance and sounds window appears. 3 Click Display Settings. 4 Select the external LCD monitor in the drop-down menu.Monitors and Displays 51 5 In the Display Settings window, move the Resolution slider bar to the left or right to select a screen resolution that matches the native resolution of the external LCD monitor. 6 Click OK. Windows® XP 1 Right-click an open area of the desktop. 2 Click Properties. The Display Properties window appears. 3 Select the Settings tab. 4 Select the external LCD monitor in the Display drop-down menu. 5 Under the Screen resolution section, move the slide bar to the left or right to select a screen resolution that matches the native resolution of the external LCD monitor. 6 Click OK.
Jan 02, 2011 | Computers & Internet
Princeton Digital VL1917 Monitor no power no display
Very common problem, look for bad caps with leaking/bulging tops as shown in my pictures:
http://s807.photobucket.com/albums/yy352/budm/Princeton%20VL1918W/
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Oct 09, 2010 | Princeton Digital VL1918 Monitor
I have had the monitor plugged into my HP laptop. Suddenly, it showed a "Power Saving Mode" message on a blank screen. I have gone through my troubleshooting guide. The screen now shows my background...
Depending on which version of windows you have the directions may be slightly different but in the display settings check to see if it is set to extend the display or to duplicate the display both do very different things. Hopefully adjusting this will correct your issue.
May 31, 2017 | Princeton Digital VL193 19 in. Flat Panel...
When I hooked the monitor up to a new Toshiba laptop, the screen quite working and showed the message "Out of frequence". since then I hooked it up to an older Dell, and I get the same message. I have been...
Hi, once you have the External Monitor connected; go to, from the Desktop2_bing.gif Screen, right click to open window, select Personalize. Scroll to find: Display Settings. You can make all the adjustments to correctly connect the monitor, updating drivers etc. Follow any given instruction when changes are complete. "Did this solution help?"
Feb 28, 2010 | Princeton Digital VL2018W Monitor
AcerAL1714 LCD Not Connecting With DELL Inspiron 15 Vista Laptop
There is a symbol of Two monitors on F3 Or F4 button
1. Press Fn key and hold it
2. by holding Fn key press F3 key
Your monitor will start displaying
Oct 05, 2009 | Acer AL1714 17" LCD Monitor
No volume
Being a person with some experience repairing Princeton Monitors... 776 so far.
If you have not had volume from the monitor right out of the box It would appear the speaker connector was not install or fell off due to poor installation at the factory.
Princeton Monitors have a lot of problems. when they work, they work well.
They are known for their very bad capacitors in the inverterboards.
If the unit runs but you have no green light and no picture Your Caps are toast.
As for your speakers, remove the front bezzel and look for the twisted wires usually black and red with a small white connector. If you find it just danggling, the connector it should go into is on the right lower side of the monitor's screen. It's keyed so installing it only one way will make it work.
Hope this helps.
Sep 10, 2008 | Princeton Digital VL1918 Monitor
PC flat screen monitor to DVD player hook-up
It appears that the monitor was designed to work with the display circuits and software driver on a Personal Computer. There is no circuitry in the display to handle the out put of DVD player. A smart TV has the circuitry. the display does not.
Nov 26, 2017 | Princeton Digital VL1916 19" LCD Monitor
Princeton Monitor VL1917 - No Power
This is the way how to examine what's wrong with your LCD monitors. After you turned your pc on, you have to check that if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. This is because of the lamps inside screen. Some of them were broken and it is very easy to replace. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so. Hope this help!! If anything I can help you with, feel free to let me know.
Thank you,
Mar 23, 2008 | Princeton Digital VL1918 Monitor
Princeton Digital VL1918 Monitor Logo
224 people viewed this question
Top Princeton Digital Computers & Internet Experts
jairo sanchez
Josh Whitehead
Josh Whitehead
Daniel Dollive
Daniel Dollive
Are you a Princeton Digital Computer and Internet Expert? Answer questions, earn points and help others
