Question about Toshiba Satellite A55-S1066 Notebook
My toshiba is not typing
Can't get into the system because it won't let me type my password. Only keys number 1,2, and the letter t. this computer is in my daughter's room.
Acer eRecovery management Restore system to factor default but I don't know the password
Locate and Unhide Hidden Rescue Partition
  • 1 Access the Diskpart command prompt. Acer stores custom eRecovery passwords on your computer in PQService, a hidden rescue partition. Locating this partition requires accessing the Diskpart utility from the command prompt. Diskpart allows you to run a scan on your hard drive and bring up hidden partitions. To access Diskpart, go to Start and type "cmd" in the search bar to bring up the black command prompt box, and then type "diskpart" at the prompt to switch to a Diskpart prompt. Depending on your computer, a new command prompt may open with the Diskpart prompt.
  • 2 Scan your computer configuration. At the Diskpart prompt, type "rescan" to run a system configuration check. When the scan finishes, you will receive a message informing you the scan is complete. At the command prompt, type "list disks" to bring up available disks and then type "select disk 0."
  • 3 Locate the hidden partition. At the command prompt, type "list partition" to view a list of partitions on your disk. Locate the partition with no name and a size of approximately 10GB. At the command prompt, type "select partition (number)."
  • 4 Determine the partition type and unhide the partition. The hidden PQService partition will be either a type 27 or a type 12 partition. If the partition is type 27, unhide it by typing "set id=07 override," and if a type 12, then unhide it by typing "set id=0B" at the command prompt.
  • 5 View the PQService partition. Return to the disk containing PQService by typing "select disk 0" at the command prompt, and then type "list volume" to view the contents of the disk. PQService will be visible in the list, preceded by a number. Type "select volume (number)" and then assign PQService a new drive letter so you will be able to open and view it from your computer interface window. At the command prompt, type "assign letter=f."
Reset eRecovery Password
  • 1 Open PQService. Navigate to the drive containing PQService. Find the file "aimdrs.dat." Right-click on the file and select "Open with" and then "Textpad," "Notepad" or another text editor you prefer.
  • 2 Open the file and find the password. Open the file with your text editor and locate the eRecovery password. Look for a line that reads, "Password=password name," "Hint=the password hint." Write down the password and close the file.
  • 3 Open eRecovery using the recovered password and follow the instructions to create a new password.
Read more
May 23, 2015 | Acer Computers & Internet
Tip
TRICKS AND TIPS ON HOW TO ACCESS THE BIOS/CMOS WHENEVER YOU FORGOT THE PASSWORD
BIOS PASSWORD ARE USED TO SECURE YOUR COMPUTER BY PREVENTING OTHER USERS TO ACCESS YOUR COMPUTER'S BIOS SETTING OR MAKING IT UNBOOTABLE REQUIRING PASSWORD.
But in some cases, some people forgot the password.
HERE ARE THE TRICKS AND TIPS ON HOW TO ACCESS THE BIOS/CMOS SETTING WHENEVER YOU FORGOT THE PASSWORD.
SOLUTION1. RESET THE BIOS PASSWORD USING DOS COMMAND PROMPT.
1. Go to start menu and choose RUN. For other operating system like Windows 7 and Vista, just use the search bar and type the command prompt. Right click mouse and run as administrator.
2. type the word "debug" and press enter
3. type the code "-o 70 2e" and press enter
4. type the code "-o 71 ff" and press enter
5. type the letter "q" and press enter
6. type the word "exit" and press enter
7. try to restart your computer and it will remove the bios password.
SOLUTION 2. TRICK THE COMPUTER TO GENERATE BIOS PASSWORD.
Some computer can generate bios password when you enter 3 different incorrect bios password. Below message will appear:
Password check failed
Fatal error...System halted.
CNU9117K31
Use the last line as password. CNU9117K31
SOLUTION 3. USE BACKDOOR PASSWORDS
AWARD BIOS
AWARD SW, AWARD_SW, Award SW, AWARD PW, _award, awkward, J64, j256, j262, j332, j322, 01322222, 589589, 589721, 595595, 598598, HLT, SER, SKY_FOX, aLLy, aLLY, Condo, CONCAT, TTPTHA, aPAf, HLT, KDD, ZBAAACA, ZAAADA, ZJAAADC, djonet
AMI BIOS
AMI, A.M.I., AMI SW, AMI_SW, BIOS, PASSWORD, HEWITT RAND, Oder
OTHER PASSWORDS:
VOBIS & IBM - merlin
Dell - Dell
Biostar - Biostar
Compaq - Compaq
Enox - xo11ne
Epox - central
Freetech - Posterie
IWill - iwill
Jetway - spooml
Packard Bell - bell9
QDI - QDI
Siemens - SKY_FOX
TMC - BIGO
Toshiba - Toshiba
In TOSHIBA BIOS, just hold left shift key during booting process.
For IBM APTIVA BIOS, press both mouse repeatedly during the boot.
SOLUTION 4. CLEARING THE CMOS JUMPER OR DIPSWITCH SETTING.
Go to your motherboard and look for jumper should be located near bios chips or near the battery. THere is usullay 3 pin switch two of them covered with this jumper.
Procedures :
1. Turn off your computer.
2. Unplug the power cable from the power supply unit.
3. Wait for 30 mins to be safe that your motherboard is fully discharged.
4. Locate the jumper.
5. If there is 3 pin switches, the jumper shows would be in 1-2 position. Just place it in 2-3 position with a few seconds and then return it back to normal position 1-2 position.
6. If there is only 2 pin switch, just remove the jumper with a few seconds and then place it back to normal.
7. Connect all the connection and restart your computer. It it will reset the bios setting.
SOLUTION 5. REMOVING THE CMOS BATTERY
If the jumper switch solution doesn't work, try this solution by removing the cmos battery.
Procedures:
2. Remove power source cable.
3. Go to your motherboard and remove cmos battery.
4. Wait for 30 mins or more before returning it back.
5. Place the battery back correctly
6. Plug your power cable and start your computer and it is done.
GOOD LUCK AND I HOPE THIS WILL BE HELPFUL FOR OTHERS.
on Dec 19, 2010 | Computers & Internet
Toshiba satellite - Letter "N"
First check to see if NumLock is turned on. This is usually indicated by a LED somewhere either above the keyboard or possibly at the front of the machine. If it is currently on, you will want to toggle it to OFF in order to type in your password. This is usually done by pressing the blue FN key located at the lower left corner of your keyboard, along with one of the function keys at the top of the screen. I believe on Toshiba laptops, this should be FN + F11, but check the keys themselves. Look for a blue picture, usually of a calculator. Holding the FN key down and then pressing this key should turn off NumLock and allow you to type the password.
Note: It is also possible that the 'N' key on your keyboard has gone bad. If this is the case, open the On Screen Keyboard, accessible through Start > All Programs > Accessories > Ease of Access, and type your password using this.
I hope this helps!
Feb 28, 2011 | Computers & Internet
NTLDR is missing this is the message i get then it says press any key to restart when u do nothing happens
remove all the external devices plugged into your computer. and try to restart. if it does not work,
You need to have your Windows XP disk with you to resolve the problem. You just need to copy it directly from the Operating system CD. The NTLDR is responsible for loading Windows so if its is missing or damaged, there's no way you can load Windows back unless you copy it from the CD to your computer.
follow these steps:
1. insert the Windows XP disk in your computer
2.Restart your computer and press f12 to open up the boot menu
3. Select CD/DVDor ODD from the options and repeatedly tap the enter key until you see the "windows is loading files" message.
4. select the option to repair your computer (letter R)
(A command prompt will open)
5. Log into your Windows installation by pressing the "1" key and press enter.
6. You will then be prompted for your administrator password, enter that password. (leave it blank if you do not have a password)
7.type the following:
copy e:\i386\ntldr c:\ (press enter)
copy e:\i386\ntdetect.com c:\ (press enter)
(letter e corresponds to the drive letter of your CD/DVD drive, change it if you have a different letter assigned to that drive. for example: Your DVD drive is drive F, instead of typing "copy e:\i386\ntldr c:\",type "copy f:\i386\ntldr c:\")
8. after succesfully copying the files, type in exit or quit and reboot the computer and allow it to reboot normally.
Hope this helps
Jun 18, 2010 | Computers & Internet
Hello i am having trouble getting my computer
your product key should be 5 letters or numbers per block and there should be 5 blocks the product key is located under the laptop also make sure you type it EXACTLY as written some people get confused by 0=zero and O=the letter.
hope this helps.
Apr 25, 2010 | Toshiba Satellite Pro L300 Notebook
NTLDR is missing
This error is caused by a corruption to your windows bootsector. I guess you are using XP. You will need to boot from your installation cd and choose the option to repair the computer using the recovery console.
once the console has found your operating system you need enter:-
FIXMBR
followed by :-
FIXBOOT C:
any problems post a comment.
Nov 05, 2009 | Acer Aspire One Netbook 8.9" Notebook
When typing along the keyboard qwertyuiop, the keys that have numbers will type numbers instead of letters,uio will type 456. If you hold the FN key in it will then type type letters, how do I correct this...
This means that NUM LOCK is set to on. All you have to do is to press the Fn key and then locate the NumLock key and press it. The num lock is usually also highlighted with the same color as the Fn key.
Please comment back if you still have issues. I will be glad to assist you further.
Aug 06, 2009 | Toshiba Satellite Pro L300-EZ1501 Notebook
The num lock key controls letters on regular keyboard.
Let Number key stay off then you could use normal 1234567890 that is between QWERTYUIOP and F1-F12
May 22, 2009 | HP Pavilion DV9920US Laptop
Need to type numbers and letters for a local wireless login
Can't say what the problem might precisely be but how about typing the full key into Notepad and then copy/paste into the wireless key facility?
Dec 06, 2008 | Dell Latitude D600 Notebook
Letter
The letter "H" on your keyboard got stuck and it's like pressed down all the time. You can pop out the key then clean it. If the issue is resolved, you should not hear the beeping sound anymore when you boot up the unit. Or better yet, if your under warranty, contact Toshiba, 1-800-457-7777 and they'll be blad to repair your keyboard.
Hope this helps.
Sep 16, 2008 | Toshiba Satellite A135-S4527 Notebook
Toshiba Satellite A55-S1066 Notebook Logo
Top Toshiba Computers & Internet Experts
Brian Sullivan
Brian Sullivan
joecoolvette
joecoolvette
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
