Question about Sony KP-53S65 53" Rear Projection Television
Red tube going bad???
Yesterday my 3 year old tv out of the blue just started throwing red squiggly lines mostly around the border of the screen, but also now the entire picture is seemingly saturated in red... I have cleaned the lenses, carefully, but this didn't seem to help. when I hit the auto focus, there are two plus signs, one red and the other white... are these supposed to be one plus sign? if not is there a way to manually focus it back? or is one of my tubes going down hill fast? Thanks for any help Patrick
  • bbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbb
Posted on May 24, 2008
  • 53 Answers
Much to my suprise these tubes need to be re-juvenated with a crt shooter. this does not bode well with the so called king o the hill (sony). although after re-juvenating the tubes seem to hold up rather well.
Posted on Mar 12, 2007
Changed crt coolant, better picture. red squiggily line starting at top center of screen, runs about a third of the way down. thought i saw scratch or small crack in green crt "c" lens. would this cau
Sounds like you may have just left one of the wires loose from the red tube. Not likely an issue from the gren tube but you can always cover the top of the lens and let just green shine up. That may help narrow it down also.
Here is more detailed info for you also.....
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from TvRepairKits.com . It includes replacement coolant,step by step instructions, support, etc.
Jan 17, 2013 | Philips 60P8341 60" Rear Projection...
The tv has red images, I cannot get the red convergence line vertically to straighten, it is squiggly, the horizontal is straight, and the blue and green lines are both okay
the 43h71 has a pair of convergence ics that commonly go bad and cause this problem. replace original stk392-110 with stk392-120. the upgrades have a collector rated at 4 amps vs the 110's 3 amps and should be more reliable.
also know that they hyperboard in this set can cause squiggly lines throughout but will not affect the convergence.
Jul 06, 2010 | Toshiba 43H71 43" Rear Projection...
Red shadow on TV Screen Hitachi HDTV
Your convergence is bad. You need to have convergence amplifiers changed.
Apr 21, 2009 | Hitachi 51F59 51" HDTV Projection...
The tv is showing red lines on the screen.
These are retrace lines. The screen on the red tube is turned up too high. Inside the set there are 6 knobs. 3 for focus & 3 for screen. Turn down the red screen until lines are gone. These knobs are usually found by pulling of the front panel.
Apr 06, 2009 | Televison & Video
3 year old rca rear projection just started going blurry. green blue and red line across the top of screen. objects have shadow.
Focus and screen control box / remove front bottom panel there you will find it / it has 3 controls on top 3 on bottom top are focus for RGB tubes bottom controls adjust screen drives for RGB.
Jan 25, 2009 | RCA D52W23 52" HDTV CRT TV
SONY KP-46C65 PROJECTION TV
we have repaired 100s of these tv..most have a flicker issuse and it is getting hard to find replacement tubes. the cost sounds right...I suggest to invest in a new tv.
Sep 09, 2008 | Sony KP-65WS500 65" Rear Projection...
Toshiba 51h85c rear projection screen is red!!
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 14, 2008 | Toshiba 51H84 51" Rear Projection...
Red and blue
convergence amp ic going bad.
Dec 30, 2007 | Mitsubishi WS-55513 55" Rear Projection...
My TV has blue lines,flashes then turns off
Bad blue CRT common problem.....................T.
Nov 09, 2007 | Sony KP-51HW40 51" Rear Projection...
Sony KP-53S65 53" Rear Projection Television Logo
515 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
