Question about Lexmark T632 Laser Printer
Print head replacement lexmark t632
How difficult is it to replace the printhead on a lexmark t632 laser printer
  • KEVIN MCCUE May 11, 2010
    Thanks RSANDREW I wondered how a laser printer could have a print head yet the manual refers to it. A laser assy sounds right thanks
  • rsandrew May 11, 2010
    Kmccue the t632 does have a print head, in the service manual that is what they call it ..but they should call it (laser assy). they are not hard the change. it is located under the top laser cover. it just taks time to aling it once it is replaced. I normally mark a line on the back of the old one with the chass. before I remove it.
    Problem Solver:
  • 10 Answers
You will have to remove the top cover, both side covers and the rear door and redrive to get to it. Once these covers are removed you will need to remove three screws to release the printhead and disconnect a couple of cables.
I usually have to clip a couple of zip ties and use needle nosed pliers to get the cables out.
It is do-able if you are patient.
Posted on Mar 11, 2009
  • 66 Answers
Hi Kmccue,
The Lexmark T632 is a laser printer. It does not have a printhead. Perhaps it is the toner cartridge you are talking about. Pull the cover open in the front and pull the cartridge out.
Rgds
S88
Posted on Dec 19, 2008
T632 duplex jams
Please ensure the power connector wires for the fuser are routed properly so as not to rub on the aluminum bar that is used during the duplex function.
Apr 03, 2013 | Lexmark T632 Laser Printer
How to replace mirror motor assembly lexmark t632 or printhead
I would suggest you contact a certified Lexmark trained technician to replace the printhead or you may contact Lexmark Technical Support.
Oct 12, 2011 | Lexmark T632 Laser Printer
How do i find out what my current page count is on the Lexmark t632
Print a menu page:
press menu right button until utility menu is displayed, then press select (lcd display print menu), press select again and the printer print the menu page, where you can see all the parameters.
May 19, 2011 | Lexmark T632 Laser Printer
Is there a guide or video that shows how to replace the printhead on a Lexmark T632 printer?
there is no print head on a T632
Either you change the drum, or the maintenance kit whisch supplies the method to change the different elements
Feb 09, 2011 | Lexmark T632 Laser Printer
I have an error on my Lexmark T632 printer saying 933 service printhead error, can you tell me what this means
Printhead error message indicates that the printhead (laser scanner) unit inside the printer is not working correctly.
First step trying to fix this is to turn printer off, and back on after 10 seconds. If this won't clear it, try and plug the printer in a different power point straight into the wall. If the error does not clear, the printer will probably require service to correct the issue.
Sep 28, 2010 | Lexmark Optra T610 Laser Printer
Prints on my Lexmark T632 have a dark line running from leading to trailing edge of the paper. Toner cartridge replaced but didn't help. Lots of toner scattered through out the printer.
Great job on replacing the toner cartridge. Most probably problem's on the fuser or the charge roll. They may need to be replaced. But also check maintenance count to see if you have already reached the 300,000 prints. It affects the print quality when you have reached the limit.
Jun 24, 2010 | Lexmark T632 Laser Printer
934 service Printhead error
head may be damaged, try reinstalling software first before you try to send the head repaired locally. may have to buy a new head if its dot matrix.
Jun 24, 2009 | Lexmark T632 Laser Printer
T632 lexmark getting dirt on printed pages
Hi Krimlakh,
Try replacing the toner cartridge first. Usually when this happens the waste hopper of the toner cartridge is full and start to leak on to the page.
Rgds
S88
Dec 18, 2008 | Lexmark T632 Laser Printer
I have a Lexmark T632 that is used very often. Constantly printing over 1000 pages daily and I always get the error message Print head Error 934 - Lost Lock condition but once I shut down the printer and...
These error codes indicate a problem with the mirror motor circuit in
the printhead assembly or the mirror motor cable to the system board
cable or system board assembly. Check the continuity of the mirror
motor cable connected to J5 on the system board. If incorrect,
replace the cable. The voltage at J5-7 measures approximately
+24 V dc. If incorrect, replace the system board. If correct, replace
the FRUs in the following order:
• System board
• Printhead assembly
Dec 10, 2008 | Lexmark T632 Laser Printer
Lexmark T632 Laser Printer Logo
1,138 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
