The washing machine will not fill with water.
The water supply is fine. The washing machine switches on and then fails to start.
    Sergeant:
    Champion:
  • 291 Answers
This depends on the make of the washer / some whirlpool and kenmore will fill but if the lid switch is bad it will not advance to start washing ,,,, put the dial on spin and with it turned on close the lid and if it dont start spinning then your lid switch is your problem ,,,, can help better if i can have the make, model and serial off your washer.
Larry
Posted on Nov 24, 2008
My Indesit 7105 has flashing H20 lights, have checked but no blockages. It fills and drains fine, It wont agitate though, any ideas?
The machine does not fill with water or 'H20' flashes in the display.
The water inlet hose is kinked. • The water inlet hose is not connected to the water supply. • The water pressure is too low. • The water tap has not been turned on to allow water to flow into the machine. • There is no water supply to the house. • The inlet valve filter is blocked. • The START/PAUSE button has not been pressed.
Faulty pressure switch machine thinks there is no water in the machine.
Apr 01, 2017 | Indesit Washing Machines
Fisher and Paykel top loader washing machine, won't stop filling up with cold water
The pressure switch usually has air in the feed pipe which sometimes gets water into it which then fails to notify the system when to switch off water supply which then prevents the relay to the motor to start.check the feed pipe so it is empty of any water.this will allow the pressure switch to work properly.if the switch has failed you can get replacement part from eBay.
Dec 05, 2014 | Fisher and Paykel Washing Machines
My lg intellowasher wf t8501tp won't go into a
Check the pressure switch and hose. Pressure switch is what turns the pump on and off. Trouble is usually in the hose so check it first. Look for the hose to be unattached or clogged.
Jan 13, 2013 | Washing Machines
My washer will not stop filling - it overflowed the tub, and will not drain.
If you can hear water running into the machine when the power is off then the fill valve has failed
If the water switches on and off when you switch the machine power supply on and off then it is either the pressure switch or the pipe supplying the pressure to the pressure switch
Easy test is to remove the pressure switch pipe at the base of the outer container and start the washer filling , blow lightly into the pipe and you should hear a click and the water should turn off
If it does not then the switch is faulty, if it does then check for congealed soap in the small plastic fitting from which you removed the pipe in the first place
Apr 07, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Washing machine continues to fill when starts
If it fills with water and starts the cycle and the water keeps running in then your water inlet valve on the back where the water supply comes in is sticking. It needs replacing.
Oct 01, 2009 | Washing Machines
Doesnt stop pouring water
it is suppose to turn off, bad fill valve.
Nov 08, 2008 | Washing Machines
Washing machine fills in the water but does not start the wash cycle
The fact that it does not fill completely can be related to a problem with the water-level switch, that regulates the water level.
See from Repairclinic:
"This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch."
However, when it is only the switch the mashine usually completes the cycle, but with less water than normal.
A possibilty is that either the timer is faulty or there is a problem with the water supply.
Check that water is coming from water supply with regular pressure, and that hoses back there are not obstructed.
More likely you will have to replace the timer.
See again from Repairclinic:
"When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water."
  • You can find parts at the following websites, you need to input your model number. If the part is not listed contact them.
    Repairclinic
    Partselect
    Don't forget to rate the solution.
    Many thanks.
    Sep 01, 2008 | Washing Machines
    Zanussi turbodry 1050
    this may sound silly but check the waste outlet pump electrically, some models are wired up so if the pump fails the water will not enter the machine, this works on the theory that if it fills up it can not empty also check the solenoids for open circuit electrically, double check the water supply to the machine, it may have been fine but you could have kinked the pipe placing the machine back where it should go?
    Oct 04, 2007 | Washing Machines
    Machine does not fill with water
    I had a Zanussi d/w up until about 5 years ago and there were two perennial problems that required attention. First of all, there was a double solenoid inlet valve for the water supply at the back, one part was the main fill, the other was a supply to the water softener - big plastic lump in the bottom under the salt filler. The main fill solenoid would fail about every 2 years and I would buy a replacement directly from Zanussi for about £10. I believe the failure may have been due to the fact that the machine was filled from the hot supply. This was allowed in the specification but the higher temperature may have led to failure. (Side note) In any case, it is better to fill dishwashers with cold water anyway because during the initial part of the wash cycle proteins are rinsed off rather than being stuck on the items, and secondly, heating from cold increases the contact time of the wash detergent solution and also improves results. If the solenoid controlling the supply to the water softener has failed, it may well lead to the phenomenon you are seeing because the regeneration cycle happens after the wash in most machines. If you feel comfortable about using a mains tester(a neon screwdriver one would do) and can *safely* reach the solenoid with power on and the machine the right way up, then you could see whether power is reaching the regeneration side of the valve or not. If it is, and water is not entering then you have the culprit. Another area that affects filling is the level switch. Generally these are pneumatically operated device looking like a flat drum, about 8cm across and 1cm or so thick. They are generally mounted up high in the machine or door and have two or three wires on terminals and a small flexible plastic tube leading somewhere into the wet area of the machine. As the water level rises, water goes part way up the tube and air above it operates the switch to turn off the water. Sometimes there are two levels used and hence two switches inside this assembly working at different pressures. One could have gone. Another problem is that gunk can get in the lower part of the tube and reduce or block it from detecting. and generally this results in no filling at all. Hope this helps!
    Mar 25, 2006 | Zanussi 24 in. DA6141 Built-in Dishwasher
    Washing Machines Logo
    42 people viewed this question
    Top Washing Machines Experts
