Question about Compaq Computers & Internet
I bought a used compaq armada 500 and hooked up to cable internet and they say the modem has been disabled. What do i do next? thank you for any suggestions
  • kantno Nov 24, 2008
    hey i think we are getting closer!!!!! now how do i know which modem if have; standard300, standard 1200, 2400, etc. it is a compaq armada e500 thank you so much in advance
    i think it is a lucent win modem now it says it need to install disc where do i get them?
  • 903 Answers
If you go to Start>accessories>System Tools>System Information and you will be able to get the make and model of your modem. Let me know the exact make and model and I will try to find the driver for you.
You could also try just updating the driver for it, if you have not already, now it is enabled windows may pick up the correct driver, right click on the device as you did to enable it, and select properties, then select update driver.
If this does not work, then get back to me with the make and model number,
Posted on Nov 25, 2008
  • 903 Answers
Go to control panel>system>hardware>device manager and right click on your modem and select enable.
I hope this helps
Posted on Nov 24, 2008
I wanted to search the web on the compaq armada 3500 that i got and was wondering where the cable goes and if it even gets internet
hi yes you should be able to connect a wifi dongle via the usb port on the side for your internet connection, you would have to buy a pcmcia network card if you want network connection to internet through your modem, so if you have wifi router/modem then a dongle would be better..hope this helps
Jul 12, 2010 | Compaq Armada 3500 Notebook
Just will not let me log on to the internet keeps saying cable is disconnecte
either your cable is bad or your nic is bad.
If its the cable use a different one and remember pc to modem needs a "patch" cable.
Oct 28, 2009 | Compaq Armada M700 Notebook
Not sure I bought a used compaq armada e 500. it
Maybe,however there are a few things you can do to stablize the computer.First of all the system fan and the vents needs to be cleaned,secondly you need to put thermal grease between the processor and the heat sink.This should stop the computer from shutting down.As for the system time you can check the cmos battery or change it.
Good luck
Oct 20, 2009 | Compaq Amarda E500 Notebook
Compaq armada v300
If you have a router on your broadband, you need a RJ45 network cable - right next to the modem port on your laptop is a network port - this will use the correct cables you need to connect to your router.
If you don't have a router but only a broadband modem, just connect it to the USB port on your laptop, install the software and you should be good to go.
Feb 08, 2009 | Compaq Armada E500 Notebook
Cant connect to the internet
680 Error is No Dial Tone, Make sure you are trying to connect with a Ethernet port, DSL will need a Modem, In between the computer and Phone jack (Sorry if im being too basic, but i want to make sure we cover EVERYTHING) Go in to the connections and try using the Ethernet adapter. Let me know where that gets ya
Nov 24, 2008 | Compaq Armada E500 Notebook
Where's the modem on old (1997) laptop?
Dear
Infact U have a modem in ur Compaq Armada Lappy
But I tell u it is PCMCIA Modem, u find right side of ur Lappy
this modem require a special cable that contain phone jack.
If u dont have that cable , u should Purchage that one.
after that u will able to use ur model.
Oct 23, 2008 | Computers & Internet
Compaq presario c500..what do i need to buy or purchase to use the internet?
This model has a wireless network adapter built in, so if you are on DSL isp connection you need a wireless DSL modem/router, if cable then a cable router to attach to your cable modem.
Sep 11, 2008 | Compaq Armada 3500 Notebook
Can I get the internet on compaq armada 1700 laptop?
That phone line will only be for actual phone lines.. as it will be a modem.
If the lappy has an ethernet port (slightly larger than a phone port, but looks the same) you could use that with an ethernet cable to a DSL modem. (the modem has the phone wire plugged into it)
Most laptops have an ethernet port, but yours might be a bit too old perhaps? If that's the case, you can buy either a USB to ethernet adapter (but you might not have that either) or a PCMCIA ethernet card. The latter will definitely work for you, and can be bought second hand VERY cheaply... if not for nothing.
I really hope it has something a bit newer than '95 though... otherwise just getting the internet to work could be a problem. Good luck!
Jul 14, 2008 | Compaq Power over Ethernet 12 Port...
Cannot obtain internet
if you already have an ethernet card installed in the laptop, then it should be fine. did you try rebooting the modem that you are hooking the laptop to? Sometimes with different ISPs that is one of the major issues.
May 27, 2008 | Compaq Armada E500 Notebook
Problem connecting DLink modem into laptop
your network adaptor driver is not installed send your mail id i will send the driver for your mail
Mar 27, 2008 | HP Compaq Presario V6000T Notebook
Computers & Internet Logo
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
