Question about Kenmore Refrigerators
Lower shelf cracked in 3 different places, it my 2nd.shelf,
Kenmore mod# 795.77309600, 2 door, freezre on the bottom,I need some help, they cost 100 dollars..thank you bob flynn
peyton32034
  • 410 Answers
SOURCE: Just purchased used 596.73824200 bottom freezer.
you can go here and find the parts you need. i really cant tell what age your refrig is by the model#  i believe it is a 24 cu ft. if you can give me a serial# off of the unit i can tell yo how old the unit is. thanks Peyton
Posted on Feb 19, 2009
  • 1122 Answers
SOURCE: BROKEN DOOR SHELF NEED REPLACEMENT
you can go to sears .com click on parts, put in your model number and get your part also you can try repair clinic .com,let me know if you find it,thanks-mike
Posted on Apr 12, 2009
  • 56 Answers
SOURCE: Need two door shelves, Sub Zero, 251 RFD, the last two shelves
http://www.subzero.com/locator/locator.aspx?type=0&zip=Zip%20Code will get you to the nearest SZ?wolf parts distributor.
Posted on Apr 23, 2009
bobicehouse
  • 1524 Answers
SOURCE: need shelf
Sears Parts Direct
Part for KENMORE, Model # 25336608896 Shelf, sliding, wiring
Part # 218272502 Category:Refrigerators and Freezers $34.41 In stock
  • 71 Answers
SOURCE: We have a subzero 201R and I need a door shelf replacement
subzero number 1800 222 78 20. EXCELLENT CUSTOMER SERVICE. depends in what part of the usa.they have information for your close store
Posted on Apr 02, 2010
Kenmore elite refrigerator is not cooling, but the freezer seems to be working fine.
Kenmore Elite refrigerators come in several styles, including units with a freezer at the top and units with freezers at the bottom. The top and bottom of the fridge work on different systems. Sometimes the freezer may function perfectly, while the fridge performs poorly. Most issues with the fridge cooling are due to incorrect settings or poor cleaning practices. Checking common problems with the refrigerator will help you diagnose the situation and keep expensive repairs to a minimum
1. Check that the Kenmore Elite refrigerator is plugged in. Inspect the circuit breaker of the home if the refrigerator is plugged in but not running.
2. Pull the unit out from the wall and vacuum the condenser coils at the back of the unit.
3. Turn the temperature control in the Kenmore Elite refrigerator to the "On" position.
4. Turn up the temperature on the temperature control, located inside the unit on the wall.
5. Check the seal along the door for signs of cracks or dryness. If it is damaged, lift up on the seal to expose the screws that hold it in place. Loosen the screws and pull the seal off. Place a new seal on the unit, starting in the corners and working your way around to insert the tabs into the Kenmore Elite fridge door.
6. Check the seal along the door for signs of cracks or dryness. If it is damaged, lift up on the seal to expose the screws that hold it in place. Loosen the screws and pull the seal off. Place a new seal on the unit, starting in the corners and working your way around to insert the tabs into the fridge door.
7. Move food away from the vents inside the Kenmore Elite refrigerator.
I hope i solve you problem.
Have a nice day : )
Sep 04, 2011 | Refrigerators
Leaking around front door rubber
Hello, you most likely have a rip somewhere on your door boot. Put your hands around the boot and look for any cracks or holes. If there is a hole, you will need to replace it. Boot costs between 60 to 100 dollars. Repair man costs should be no more than $60.
Best of luck.
Feb 23, 2011 | Kenmore Elite HE5t Washer
F3-error. Kenmore classic oven Heating element will not go pass 100 deg. Heating element recently replaced. Broiler is also malfunctioning
Hello there:
Whenever you get the dreaded f-3 code this is the code that tells you that the temperature sensor is going bad or already has gone bad and needs to be replaced immediatly. It should look something like this and cost about 50 dollars
Jun 20, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
MFD2560HEW Bottom freezer french doors. Top shelf in fridge is 52.2 degrees 2nd shelf is 45.7 degrees 3rd shelf is 38.5 degrees and the bottom shelf that slides out that sits above the freezer is freezing...
At this point I am not sure if your Auto Damper that regulates the cold air is stuck closed or if the thermistor that controls the damper is responsible. You could also be having a defrost problem restricting the air flow to the fresh food section. Look into rear of freezer to see if there is a layer of frost building on rear panel. If yes then we will need to focus in a different direction. First by manually unplugging fridge and then using a hair dryer to help speed things up. The manual also has diagnostics test that you can do to locate a problem area like thermistors or many other errors will show once placed into diagnostics. Sea Breeze
Jun 03, 2010 | Maytag MFD2560HES Bottom Freezer French...
I have an LFRD25850SW Fridge. The bottom shelf above the crisper drawers has cracked at the left front and is causing the drawer to stick. I need to replace the shelf frame (glass is OK). Can you give a...
The shelf frame is cracked . It can be purchased if the part is still available from LG . I wouldn't hold out hope though because LG is notorious for discontinuing parts after 3 years. Find a parts supplier who has contact with LG parts to see if it's still available . I was able to order one for my customer back in the spring.
Oct 22, 2017 | LG LRFD22850 Bottom Freezer Refrigerator...
Whirpool door latch--digital display show DL.. how to fix it..and how much it cost to fix it
Hello there
This is telling you that the door latch assy may be bad
first remove the bottom panel. you will have to use a star type driver to get it off than reach up and manually release the door this is a 65 dollar part and your local appliance repair center should have oit or go to applianceparts pros.com and they have them their ok
Hope this very helpful for you
Best regards Michael
Jan 19, 2010 | Kenmore 4292x Front Load Washer
When baking bread in my Kenmore electric range (9435) the loaves on the bottom rack burn on the bottom and the ones on the higher rack take almost 2X as long to cook
In an electric range, the ideal place for baking is the middle shelf. there are temperature differences within the oven cavity. On the bottom shelf the heating elements actually "broil" the bottom of the pan. In the upper part of the oven, the temperature is lower, being blocked by the lower pans. A convection style oven is more ideal for bread baking.
Aug 23, 2009 | Kitchen Ranges
Admiral upright freezer dripping water inside on top
Hello.
I can help. Once we notice anything different from before we start becoming more aware of small variations. Regarding things on the top shelf warmer than on the bottom, this is always true because, "warm air rises and cold air falls". If you want the top shelf colder turn the thermostat to the next colder setting, always a good idea in the Summer season anyway.
Even though your gasket looks good, a ten year old gasket is not as pliable as a new one resulting in the moisture problem you describe. I would begin by applying a thin coating of vaseline to the gasket once a week for a month. This little trick of the trade will often work. If it doesn't improve the situation do replace the gasket.
Jun 25, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Broken door handle
Hi, there should be two screws holding the handle. I looked up my suppliers and this would need to be ordered. The cost is between 21 and 29 dollars, depending on color.
Part#8559750 Graphite color or P#8559751 Black
If I can assist you further, please let me know. I can order the part.
Thanks
Vic
May 15, 2009 | Kenmore Elite HE4 Electric Dryer
Refrigerators Logo
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
