Question about Eureka Altima Upright Vacuum Model 2996AVS Vacuum
Eureka Altima Bagless Upright Brush is not spinning
I've got a fairly new vacuum and the brush is not rotating. All dust bins are empty, the vacuum makes sound like it's running, but nothing is happening. The attachments are working, but I can't actually vacuum carpet with it. Any ideas?
  • 2 more comments
  • wrightonmom Nov 29, 2008
    Mine does the same but the lint, and hair
    backs up in hose never goes into cup! Belt is good - we have taken it apart again and it's only 2 months old!
  • msteimer Nov 30, 2008
    I am having the same problem with the vacuum sounding fine, but the roller is not rotating when I am pushing it. The roller does spin when in an upright position though, and I can do the hardwoods ok - strange.
    For the person who is having lint stuck in the tubes - I had this happen too. I ended up cleaning the filter on the front, and that took care of the situation.
  • leannabarnes Dec 18, 2008
    ANY IDEAS? I took it apart, the belt is fine the motor is running but the brush is not rolling!!
  • Anonymous Mar 23, 2014
    When I push the power button for my vacuum nothing happens. It had been working fine, then all of the sudden it wouldn't turn on.
    Scholar:
  • 55 Answers
You probably just have a broken belt. The belt needs to be changed about every 6 months regardless. I believe yours takes a style EXT U(Extended life upright), or a regular Eureka "U" belt works fine too.
Posted on Nov 24, 2008
Is the beater brush on the Bissell Helix NOT to spin on bare floor setting?
Hey Tony! The brush does continue to rotate when using the vacuum on the bare floor setting.
Feb 02, 2013 | Bissell Cleanview Helix Deluxe Bagless...
Eureka Model Whirlwind litespeed. The rotart brush does not turn or rotate. Should it turn or rotate in order to give better suction?
Hello fnintel, yes, if you are using the upright vacuum it should spin, ( the belt likely slipped off, or the brush is clogged with hair and the likes.)
However, if you are using the hose on the vacuum like a shop vac, some models bypass the rotary brush.
Jan 09, 2011 | Eureka Whirlwind Litespeed 5840 Bagless...
I have a Ultima 12 amp e10071, The brush is not turning, there is tension on the brush as if the belt is connected but still there is no rotation. The motor does run. How cani open the vac to take a...
You get to the belt & brush roll area from the top. On the hood of the vacuum, right behind the word Altima, to the right & left sides, you will see a screw. Remove them, lift off plastic hood. Check belt if broken or just stretched too big to catch brush to turn it. Check ends of brushroll for any hair, thread buildup & clean it. See if end caps turn easily. If one or both ends do not turn easily, the brush roll would need to be replaced.
Eureka Brush roll part # 62365-3
Eureka U belt part # 61120D
Sep 01, 2010 | Eureka Altima Upright Vacuum Model 2996AVS...
I have a Eureka Altima and not sure how to change the belt?
1) Use handle release to lower handle
flat onto floor
2) Remove 2 screws from the front side of
brush roll cover
3) Lift and remove brush roll cover .
4) Remove brush roll and belt. Thread
new belt around motor shaft and
brush roll
5) Insert left end of brush roll first. Make
sure square on brush roll cap is in
place. Pull right side of brush roll to
stretch belt. Secure right end cap into
base.
6) Rotate brush roll 2 turns to center belt.
7) Replace brush roll cover
8) Replace 2 screws
And you can get the maual here.
http://www.eureka.com/service/manuals/80244.pdf
Good luck
Sep 27, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
I would like to disassemble my eureka altima to clean brushes
The Altima line has 2 screws on the hood (part where the knob is that says high carpet and low carpet) that you remove with a philips head screwdriver then you just lift the hood of the vacuum
Mar 08, 2009 | Eureka 402A Bagless Upright Vacuum
Brush spins & then trips & quits
Sounds like a clog to me. Check that the roller brush cap fittings (caps at either end of the brush roll) don't have thread in them as well as checking that the dust channel from the sole plate is completely clear.
Dec 16, 2008 | Eureka 5892AVZ Bagless Upright Cyclonic...
Low suction on Eureka spinduster vacuum cleaner
The belt has stretch enough so as to not drive the brush roll under load. Try a new belt.
May 10, 2008 | Eureka 2971AV EZ Kleen Bagless Upright...
Eureka Maxima Bagless brush not spinning in vacuum position
belt doesnt have to be broken, check the metal arm on the vacuum, see if there is build up of old rubber from previous belts, clean the arm that spins the belt and double check to make sure u have the correct belt
Jan 19, 2008 | Eureka 4700A Maxima Bagless Upright Vacuum
No sucking
Could be that the dust cup filter is clogged, part #60958, or the inlet down by the brush roll is clogged.
Oct 01, 2007 | Eureka 402A Bagless Upright Vacuum
Eureka Altima Upright Vacuum Model 2996AVS Vacuum Logo
420 people viewed this question
Top Eureka Vacuums Experts
charlesjo336
Level 1 Expert
JoeVacs
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
