Question about MSI RX480 Neo2-F Motherboard
Motherboard upgrade Running Windows XP. tried upgrading to MSI RX480 Neo2-F motherboard. Once everything was installed Windows would not start. would get to windows startup then loop back to bootup screen. When I re-installed old motherboard and components everything went back to normal. Is there any special preparation needed for Windows XP before installing new components? On another computer tried the upgrade installion on XP disc and ended up merely re-installing XP
  • 624 Answers
The different hardware components on the new motherboard require different drivers that what are already loaded on your installation of Windows. My guess is something requires a driver that the base Windows driver install will not cover and as a result errors out and restarts. I too have tried this trick on several occasions, sometimes it work and sometimes it doesn?t; however, the key is similar hardware. My guess would be IDE controller, video, chipset or perhaps USB 2.0 is causing your problem. What you can do perhaps is boot into Windows safe mode and try to figure out what is causing the problem. In the long run it may save time and aggravation by just reinstalling Windows ?? Let us know how it turns out.
Posted on Jan 02, 2007
Instal driver but sound not coming
Hello download the right driver here:
http://www.msi.com/product/mb/865PE-Neo2-PLS--PFS--PFISR.html#/?div=Driver&os=All
Please select your windows and unzip the file when downloaded.
You also need the chipset driver.
Here is only drivers for win xp so if you are running windows 7 or vista you have to buy a soundcard because the driver is not supportet for a new windows system.
The green outlet is for the speakers and see that the volumen isen`t
turned down low or muted.
Good luck
Dec 03, 2012 | MSI : 865PE Neo2-PLS P4 Prescott FSB800...
I HAVE A MSI RX480 NEO2 MOTHERBOARD IN MY COMPUTER NOT VERY OLD AND IM GETTING NO SIGNAL GHANGED GRAPICS CARD STILL NO SIGNAL
Check the monitor input, it must match the video card output Eg. VGA or DVI,
Try a different video cable.
If the video input is correct then try a different monitor to see if the monitor is faulty
Mar 02, 2012 | MSI Computers & Internet
I have a Galaxy geforce 210 1gb graphics card and it is not working on my computer. I keep getting it is a code 35. my motherboard is a RX480 Neo2 OS is windows vista 32bit. The graphics card shows up that...
The Multiprocessor System (MPS) table, which stores the resource assignments for the BIOS, is missing an entry for your device and must be updated.
Contact the system vendor to update the BIOS. or you might try restart your computer
during the boot process you will see on the screen to press delete to enter setup
Press and hold delete during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
hope this will help
Jul 28, 2011 | MSI RX480 NEO2 Motherboards
I have installed Windows on a computer and I can not find the sound. I do not have it at all and everything I have connections. Please what can I do
first make sure your audio is enabled in the bios you motherboard manual will have instructions for this. then install the audio drive from your motherboard drive disc
Feb 01, 2011 | MSI RX480 NEO2 Motherboards
I have had a motherboard failure the MS-7357 (V1.X) Mainboard... needing upgrade thinking of the MSI G41TM-E43 LGA 775 Intel G41 will i have to mess arround with the power switches with the case as this...
Boards don't come with switches. The problem with company made computers is that they get a manufacturer to make a board especially for the case they make. They do this to specifically stop you doing what you are trying to do, upgrade a machine with a proprietary board in THEIR case. You will find trouble at the rear of the machine getting to sockets and plugs.
It is far better to buy a good case, and then you can swap out components with ease. The case that held my Asus boarded P4 with the first SATA drives now has an Asus Quad Core in it with SATA 2.
MSI G41TM E43 LGA 775 Intel G41 HDMI Micro ATX Intel Motherboard Newegg ca
I would contact MSI direct
G41TM E43 MSI Global
Some of this might be useful
G33M - MSI
https://www.msi.com/Motherboard/G33M.html
... the app from the MSI website. Features - Automatically Detect the BIOS/Driver/VGA/Utility Update - Support Microsoft Windows XP/Vista/7 32/64bit. featurePic ...
::UPGRADE:: G33M (MS-7357) - new processor and RAM - MSI Forum
https://forum-en.msi.com/index.php?topic=125215.0 Mar 11, 2009 - 6 posts - ‎2 authors
The motherboard is a G33M (MS-7357) and has a piddly 1.6ghz processor and 1gb of generic RAM. I'm running Windows XP Home.
CPU-Upgrade: MSI G33M (MS-7357) processor support and ...
www.cpu-upgrade.com > MSI Nov 28, 2010 - MSI G33M (MS-7357) motherboard specifications ... FSB 200 MHz, L2 512 KB, TDP 35 Watt, Conroe-L, Rev A1, SSpec SL9XP, 7357v10.zip.
UserBenchmark: MSI G33M (MS-7357) Compatible Builds
www.userbenchmark.com/System/MSI-G33M-MS-7357/450 Compatible Components (from 7 PCs). Popular components in PC builds with the MSI G33M (MS-7357) Motherboard. CPU. Core2 Quad Q6600Intel $190Bench ...
Oct 21, 2017 | MSI G41TM-E43 LGA 775 Intel G41 HDMI Micro...
Ethernet LAN not detect
Hello download the lan driver from here:
http://www.msi.com/product/mb/865PE-Neo2-P-Platinum-Edition.html#/?div=Driver&os=XP%2032
Try to renew the driver and install the new one.
And check your bios settings for the lan.
Good luck
Jun 02, 2009 | MSI 865PE Neo2-PFS Motherboard
DRIVER DISPLAY ADAPTER NO DETECK
Make sure that your ram and everything else is plugged in on the motherboard. Could be something is not compatable with your moterboard.
Mar 01, 2009 | MSI RX480 Neo2-F ATI Radeon XPress 200P...
I need to update processor
it is not possible to upgrade the processor unless you want to change your motherboard to a higher processor speed.thanks
Dec 18, 2008 | Intel Motherboard
MSI RX480 Neo2-F Motherboard Logo
83 people viewed this question
Top MSI Computers & Internet Experts
Alun Cox
Computer Links
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
