Question about Motorola Mobility RAZR V3i SLVR L7 L8 OEM Original Stereo Cell Phone Hands Free Headset Headset
Razr liquid damage
On my Razr. Was briefly wet. liquid damage dot is red. It starts up with message "Insert SIM" even though SIM is inserted. Is able to make 911 call. If I try to charge it says "Unable to charge". I have dried it next to heater for a coupkle of weeks without result. Is there any hope?
As for the "Insert Sim" problem, I might be able to help. My daughter put my phone in the toilet. Yes the toilet and I was getting the same "insert sim" message. THen I saw online a suggestion to take out the sim and battery and put the phone in the refridgerator. I know it sounds crazy but it dried out my phone VERY QUICKLY. It sucks out the humidity in the phone. IMPORTANT: The website I read said to make sure that you use the fridge and not the freezer. It will hurt your LCD. And to only put the phone in for 15 min and then take it out and back in for 15 and then out again. WHy, I don't know. But I did it this way and it worked.
Posted on Oct 03, 2007
Well i just read your suggestion and i don't know what flex pad connectors are, but i'm assuming that they're the hinges that flips your phone open and closed. anyways, i kept half way closing it, still able to view the lcd screen, and i noticed it would change from "unable to charge" to "charging"!!!! so i don't know what was going on or what happened to make this crap happen. now is this normal for water damage? i live in north carolina and it's been 108 degrees with, like 60% humidity. could water in the atmosphere possibly damage the circuitry of cell phones? well, my phone is charging...for now. I can't live without my phone!
Posted on Aug 10, 2007
If you are handy - open the phone and clean the flex pad connectors with a cotton swab and a little bit of isopropyl alcohol.
Posted on Jan 11, 2007
My RAZR keeps giving me the message "Insert SIM" and the SIM is a
yes, your cellphone is recognizing the sim card, sim my be damaged
Jun 23, 2009 | Motorola Mobility RAZR V3
Can I Have my razr repaired
Then you should take the phone to a repair center and have it fix for a fee.
The white dot on the back of the phone is to safeguard the manufacturer from malicious damaged or use by the customer.
So if it is red that means if had to come into contact with liquid , moisture or water at sometime.
Apr 29, 2008 | Motorola Mobility RAZR V3
Insert SIM message
try your sim card in someone else phone it might be the sim card not the razor
Mar 31, 2008 | Motorola Mobility RAZR V3
Motorola
Trya hard reset, you may lose data
try holding down the power
remove the back cover and battery
(at this point briefly let up on the power)
remove the sim card
wait for "insert sim card" message
remove battery
reinsert sim card and battery
release power key when the splash screen comes up
Feb 13, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Insert sim
H2o, on the phone. It may still be saved. the only thing is that you may not have the tools to open the phone. the tools needed are a T-5 and T-6 for most V3. my best idea is to try to softly scrape the Sim Card reader Prongs/contacts. but please if you have never open a v3 don't try it. just take to your local service provider or to one of those guys with a accessories stand selling the face plate replacement @ the mall. they may not charge you anything .and cross your fingers so the micro resistors inside the phone did not fried, this happens if the phone was ON when it got water in it.
Hope this helps
Thanks
Jan 06, 2008 | Motorola Mobility RAZR V3
Insert SIM Card
you need to get a new main board.....or you can take it to a mobile store tech and have the phone fully service.
But the best solution would be to buy a need mobile....most time when a mobile gets wet......it's more of a 50/50 chance that it will work properly again.
SE K750i displaying 'insert sim' even though sim is inside.
This problem is due to your phone's sim card IC malfunctioning. It may get damaged due to phone dropping gently into rough surface and its crystal structure may break due to it. for any queries mail to mahesh_vr@yahoo.com
Sep 01, 2007 | Sony Ericsson K750i Cellular Phone
Mobile Phone - Flip
"unable to charge", "insert sim". is your phone been dropped or got wet? if unable to charge, when using a wall charger, try different outlets. if using onl one charger, tr different chargers. if it won't work, try other compatible batteries if you would get a charging message. if does not work, have your phone checked with a service center
Sep 01, 2007 | Motorola Mobility RAZR V3c Cellular Phone
Confused Phone
Hi There, The red dot does indicate that the phone got some form of liquid in it. Sometimes parents give toddlers their phones and they bite on them thus getting saliva in the phone which is a form of liquid. I hope this wasn't the case. Sam !
Jul 25, 2007 | Motorola Mobility RAZR V3
URGENT: INSERT SIM - UNABLE TO CHARGE
dear for not charging first check ur charger if ok then check and clean charging jeck. even not ok chen the status of solder of jeck if it is unsolder then sold it. even if not ok then check the charging fuse 0 ohams if meter shows continuty then ok other wise replace fuse. for inser sim card check connection from sill card ic(like combice resistor)
Mar 25, 2007 | Motorola Mobility RAZR V3
Radio Communications Logo
87 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
