Question about Optoma EP719 XGA DLP PROJECTOR 2000L 2500:1 CONT DVI-D WITH HDCP Multimedia Projector
Shutting down my projector keeps shuting off after it powers up I have an Optoma EP719 projector that shuts off after being on for only a few minutes, It works fine sometimes, and other times the problem comes back. Can anyone help me with this please? Thank you. suedeman2
  • suedeman2 Dec 03, 2008
    Hey - thanks so much for the info. Before I received this info from you, I took the unit to a repair facility. It will be interesting to see what they say was the problem, and compare it to your suggestions. I may have to do a better job of keeping the insides clean. Thanks again.
    Bob
I have the exact same problem for the same projector. The issue is the blower for the bulb itself, which is mounded in the heart of the projector next to the light pipe. Over time the blower blades accumulate dirt and crud which reduces the effectiveness of the blower to cool the bulb. In order to get to this blower you would have to completely disassemble the projector, the blower is the last component you will be able to remove. I highly recommend a service center perform this maintenance unless you have a profession in electronics, are familiar with protection from electrostatic discharge, and your warranty is expired. If you take the risk of cleaning the blower yourself, try as best as possible to remove all traces of dirt from each blower blade. It is a tedious task. Removing the surface dirt is easy, just use a vacuum and a brush, but the burned in dirt which builds up in the pores of the plastic due to heat and time is very difficult with out some sort of solution or mild abrasive, and as everyone should know, liquids and electronics don't mix. There are dielectric cleaners and rapid evaporation cleaners available for electronic equipment that you can try. The only issue is once the blower has gotten dirty enough over a long enough period of time, it will not take long until the problem returns. The cleaner you get it, the longer it will last before it needs another cleaning. If the blades will not get clean enough and the problem occurs at too frequent an interval, then a replacement blower or complete servicing is recommended.
Posted on Jan 23, 2009
    Problem Solver:
  • 4 Answers
Clean out the filters by taking the case of then before powering the unit on (make sure the lamp is cold) take out the lamp ad clean off any dust etc and check at the front of the unit centre that the disc for the DLP isnt broken, a typical fault on these machines. otherwise i did have one machine that switched off due to low mains voltage!! 198v instead of 220v (here in spain)
Posted on Dec 03, 2008
Optoma EP719 Projector "Pulse"
It is one of the fan, it is bent or out of place and cause reptead disturbance at cyclic intervals. The projector must be taken apart and examined on the inside
Jul 22, 2008 | Optoma EP719 XGA DLP PROJECTOR 2000L...
Power on, fan runs, get a red led at the "lamp" indicator then the projector goes to standby and shuts off. Projector is a benq MP515
Hi
Check the lamp physically if looks ok then problem suspect with Lamp ballast or lamp
ANS BY
M.R. Mumbai & Dubai
Sep 01, 2010 | Optoma EP719 XGA DLP PROJECTOR 2000L...
Optima EP719 won't power on - when power button
check that the lamp is on securly and that the cover is on securly too.
Feb 02, 2010 | Optoma EP719 XGA DLP PROJECTOR 2000L...
I have the Optoma ep719 and it will not power on. I plug it in the power light flashes. When you hit the power, the fans will come on and the bulb will light up for about 2 sec. Then it will go back to the...
some dry out, and you can't tell by looking at them. see if the colorwheel is spinning. if it chirps before it shuts down, or if it doesn't spin at all, replace it. otherwise replace the ballast.
Oct 27, 2009 | Optoma EP719 XGA DLP PROJECTOR 2000L...
Optoma EP719 Projector Won't Power Back On
When you first replaced the bulb it went back on and then later it did not. Most projectors have a safety switch that it is activated upon the bulbs cover placed. Once the cover is removed it activates the switch and shuts down power to bulb. It sounds based on your remarks, that this switch may have intermitten problems. I would suggest, locate this switch and verify its operation. Or, make sure the bulb cover is placed and/or secured properly.
Feb 18, 2009 | Optoma EP719 XGA DLP PROJECTOR 2000L...
Help needed for Optoma EP 719 DLP PROJECTOR
It's a setting in the menu. A few minutes poking around will fix it.
Jun 12, 2008 | Optoma EP719 XGA DLP PROJECTOR 2000L...
EP719 Projector is "Buzzing"
Could be something touching the color wheel
Dec 19, 2007 | Optoma EP719 XGA DLP PROJECTOR 2000L...
405 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
