Question about iLO (2 GB) MP3 Player
Songs are No longer showing up in Windows Media
OK...so my songs are STILL on my iLo but not showing up in my list of songs for the device on Windows Media AND I can't sync songs on iLO any longer. What happened? It used to work fine. I get an error message: Your device requires that this file be converted in order to play on the device. However, the device either does not support playing audio, or Windows Media Player cannot convert the file to an audio format that is supported by the device.
  • dez33333 Dec 07, 2008
    but my player is the sandisk e260. i have a full player of songs, but windows doesn't acknowledge them and i'm unable to add or delete to the player.
  • 15 Answers
SOURCE: problem with songs
http://www.lenoxx.com/2005/mp3player/mp556.htm if you have a ilo model mp-556 (on the back cover) this page has links to the firmware ... i follow the instruction and got mine working. u might need to use the reformat as well as the upgrade firmware to make your list read the same. reformating will set your storage area back to factory specs. i e delete all your songs on your player
Posted on Aug 27, 2007
SOURCE: ilo mp3 Player Model MP-556
Get media player 10. I have no problem.Also number your songs in the order you want them to play in,or it wont play'em in the order you put'em in player.
Posted on Jan 07, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: No files found
Switch it to MTP or auto mode in settings menu
Posted on Jul 05, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: Hidden Song Files on an ILO
The songs are in the wrong format
ThaMp3Doctor
  • 8596 Answers
SOURCE: ILO does not list all songs.
switch to mtp mode or auto, and make sure the songs are in the correct format
I can download music on my mp3 but when i go to play it it says its empty
Ilo player must be synchronized, coping and pasting files is not enough:
  1. Start Windows Media Player and select following menus: "File.", then choose "Add to Library." then the "Add" button. Then, look for the folder where your keep the mp3s to upload.
  2. Plug the Ilo MP3 player into USB.
  3. Click the "Sync" tab that you find at the top of Windows Media Player . You will find the Ilo MP3 player on the right side of Windows Media Player. If Ilo is not ther, then right-click on Sync tab and click "Refresh Devices."
  4. Click "Library" then "Songs." on Windows Media Player . Highlight the son songs, and choose "Add to Sync List."
  5. Click "Start Sync" button that will appear at the bottom right corner of Windows Media Player. The songs will then be uploaded to the Ilo MP3 player.
Sep 07, 2009 | iLO (2 GB) MP3 Player
How do i put music on my ilo mp3 player?, when i upload it onto my computer. it wants me to either download a windows 98 driver or to put it in a different usb port.
use a xp machine and see if it work.if so then 98 won't work with your mp3.98 may have usb ports but you need special driver for it.some don't exist since the mp3 was built for xp or up-to-date operating systems.ou can charge it but not put songs.windows 2000 will work.there is very little usb devices that work with 98
Jul 28, 2009 | iLO (2 GB) MP3 Player
Songs Won't Sync and Don't Show up in Windows Media
use this programs do covert yours musics Link
if it work please rate like very helpfull and vote me thanks
Mar 11, 2009 | SanDisk Sansa m250 MP3 Player
Finding songs on my ilo mp3
installed Itunes software.. to transfer songs file.
Sep 11, 2008 | iLO (2 GB) MP3 Player
No files found
Mar 27, 2008 | iLO (2 GB) MP3 Player
Mp3 player
I had the same problem.
I use Windows Media Player to load all my music to my ilo. When I went in, it said I had only so much room, and it wouldn't read my music from the device.
So I finally just right clicked it where it show up to left. In the same column as the playlist, and the library of all the songs you already have on your computer.
When I right clicked, I scrolled down to "FORMAT". It told me that it would delete the songs from my device, and I happily clicked ok.
It worked for me. I hope it works for you.
Good Luck.
Dec 27, 2007 | iLO (2 GB) MP3 Player
Storage
The iLO manual says you cant get songs from music stores like Napster. Lime Wire works very well on mp3 players. This same problem happend to me but then i realize it doesnt work if the songs come from Napster
Dec 21, 2007 | iLO MP3 Player
Problem with songs
Jul 24, 2007 | iLO MP3 Player
Mp3 player won't play
your ILO has somehow lost its file structure. look for a tiny pinhole to reset the device. if none, then remove batteries to attempt reset. if still no songs, then firmware upgrade if possible or copy file structure (using windows) from a friend's ILO.
Jun 08, 2007 | iLO (2 GB) MP3 Player
No files found
Ok I have same player, same problem. Turns out Windows Media player copied the files into the FM subfolder on the device. FIX: connect device to computer. Do not open WIndows media player, instead open windows explorer, in there you should see the ilo as a new drive. Click the drive and go into the FM folder, now select all files and drag them directly to the drive. The secret is the files have to be outside of the FM folder loose in the device (not in any folder) After that I safley removed the device from the system tray icon and powered it on and the songs were all there. It runs an index process that creates the lists, this takes a second.
Dec 12, 2006 | iLO MP3 Player
iLO (2 GB) MP3 Player Logo
Top iLO Audio Players & Recorders Experts
Mohamed Ismail
Mohamed Ismail
Allen Benge
Level 1 Expert
Jon Piercy
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
