WS-65907 Projection TV
Hi.. I saw a posting from you saying you had a fix for this TV. When I turn it on it shuts off about 5 seconds later.
    Guru:
  • 1,894 Answers
It must be some thermal heating problem. use a external fan and check fi the problem exists. and if the unit gives any blink code after it shuts off please let me know.
thank you
Posted on Nov 25, 2008
I have a WS-65907 tv, it wont turn on
Mitsubishi self check: MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ON FOR A MOMENT AND GOES OFF.
PRESS AND HOLD "device"(input) and "menu" buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC's is blown---set will detect no voltage to convergence IC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
let me know what you find--hope that you find 2 blinks, a pause and two blinks--this is the most common and easiest to fix.
Oct 30, 2012 | Mitsubishi WS-65907 65" Rear Projection...
Mitsubishi ws 65907
do u hear a clicking sound.
this can be due to relays getting tripped
Jun 22, 2008 | Mitsubishi WS-65907 65" Rear Projection...
Hi, I have the ws-65907 65", it was working last
No,this problems is not the projection lamp problems.The tv now have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have colors shadows pictures or look like 3D pictures.The tv convergence board,the 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like 300-350 for parts and labors.
Oct 26, 2010 | Mitsubishi WS-65907 65" Rear Projection...
The tv will instantly shut off after its powered on. I did a self check by holding the menu and input buttons for 5 seconds and the green power light in front blinked twice then paused, and blinked twice...
this is error 22. which is a short curcit protection error. the first suspects in this case is the convergence ic (stks) these are supplied by 24 and -24 volt lines. these short and shut the set down.
Oct 16, 2010 | Mitsubishi WS-65907 65" Rear Projection...
Mitsubishi ws-65511 tv won't turn on
If the green power light on the front comes on for a second or two and goes out: Press and hold both the menu and input buttons on the front of the set for at least 5 seconds and release both. Power light will blink a two digit error code: 2 blinks, 2 blinks, pause and it will repeat several times. Let me know if you find a error code and I will tell you what it means. IF this information was something you did not know, rate this solution as very helpful as I do this here for free. SD TECH
Sep 07, 2010 | Mitsubishi WS-65511 65" Rear Projection...
Tv not turning on
U know how to solders?Replaced the convergence ICS and all it resistors,should get ur power back.Tries Websites Tv repair World.com,Tvrepairkits.com.First check ur DM power board see not any burn parts first.
Jan 12, 2010 | Mitsubishi WS-65907 65" Rear Projection...
Turn it on and turns off again
sounds like your powersupply is bad. usually reasonable repair. 150-250 parts and labor
Jun 05, 2009 | Mitsubishi WS-65907 65" Rear Projection...
Mitsubishi ws-65907
I had the same problem with my WS65907. If you know a little about electronics and how to solder, you can fix this yourself. First you're going to have to carefully remove the PC board from the TV. There are four "pico" fuses located by the regulator. check the ohms across each one. I found two of mine were "open". I replaced them for $1.49 Ea.
Dec 31, 2008 | Mitsubishi WS-65907 65" Rear Projection...
Mitsubishi ws-65907 tv not turning on
Let's just buy new TV's to help stimulate the economy.........
Dec 14, 2008 | Mitsubishi WS-65907 65" Rear Projection...
Mitsubishi ws-65907
can u please give me ur email ID so that i can send u a DOC file having all step by step instructions?
since it is very long i can post it here
Televison & Video Logo
Top Televison & Video Experts
