I have a printer attached to a server and i want to install the printer driver bt i dont where to install it so, Where do i install the printer driver? please help
Install the printer driver on the computer you want to use it on, Then in setup it SHOULD ask you if its a Local Printer or a Network printer, You choose network and it SHOULD find it on its own. Granted everything goes as it should...
Posted on Nov 24, 2008
Apr 22, 2011 | D-Link DP 301U (DP-301U) Print Server
Ensure that communication has been established and that a driver test page can be printed from the 64-bit server. Once functionality has been confirmed from the 64-bit server, proceed to the next step.
Currently, 64-bit clients will be able to connect to the shared 64-bit print driver that has been installed on the 64-bit server as the architecture currently matches. However, if 32-bit clients wish to map to the shared 64-bit print driver on the 64-bit server, the 32-bit version of the same driver will need to be installed within the current 64-bit driver.
This process can be done by navigating to the printer properties of the 64-bit driver on the 64-bit server, clicking the Sharing tab and clicking the Additional Drivers button.
Once the administrator clicks the OK button, a print driver window will pop-up asking for the 32-bit driver components. Again, the administrator will need to download, and extract the 32-bit version of the print driver on the 64-bit server. Once the window below comes up, the administrator will need to navigate to the 32-bit driver components and select the appropriate driver .inf file.
For example, the UPD .inf file would be the first file in the list and be named hpcuXXXc.inf.
Once the appropriate .inf file is selected, the 32-bit driver components will be installed within the 64-bit driver on the 64-bit server. This can be verified as both x86 (32-Bit) and x64 (64-Bit) boxes will now be checked and show the status as installed by clicking the Additional Drivers button compared to the screenshot in Step 3 above.
Now that 64-Bit and 32-Bit drivers have been loaded onto the 64-Bit server, 32-Bit and 64-Bit clients can now navigate to the shared print driver on the 64-Bit server, by manually navigating to the shared print driver on the 64-Bit server from the client machine. Typically the path is \\servername\sharedprintername.
Once the client maps to the shared print driver, printing should work successfully.
For problems or errors that continue to occur after completing the aforementioned process, ensure that the latest version of the print drivers are being used www.hp.com . If there are problems with older discrete drivers, it is recommended to use the latest version of the Universal Print Driver which can be found at www.hp.com/go/upd .
Mar 17, 2011 | HP Laserjet P4515x Printer
Nov 29, 2010 | Brother MFC 7420 All-In-One Laser Printer
May 30, 2010 | HP Photosmart C5280 Printer
Jun 19, 2009 | Sharp (AR-NB2N) (ARNB2N) Print Server
Sep 24, 2008 | HP JetDirect EX Plus Print Server
Apr 01, 2008 | HP LaserJet 9040n Printer
Jan 24, 2008 | EPoX BT-PA04AU (192062001) Print Server
Jan 17, 2008 | IOGear GBP301 Print Server
Nov 11, 2007 | Konica Minolta magicolor 2430 DL Laser...
Aug 24, 2017 | D-Link Air Plus DP-G310 (dpg-310) Print...
176 people viewed this question
