Question about Kitchen Ranges
Door locked on oven without reason
The oven locked started blinking while I was baking and I hit the clear button numerous times to no avail.
  • 1 more comment
  • Marc Cramer
    Marc Cramer Nov 24, 2008
    the oven locked without prompting and I hit the clear button to no avail.
  • kacdaltks Nov 24, 2008
    Bluestar oven door will not open. Please Help.
  • jimpryan Feb 12, 2009
    The Locked Door light keeps blinking as if it is trying to complete a "self cleaning" cycle and the door clicks and whirrs however the door never locks or self cleans and it wont cook normally anymore.
I turned the circuit breaker off for about a minute and restarted and it seemed to work
Posted on Nov 25, 2008
Door locked wont self clean
Turn off breaker for minute or so if no contact repair man mcro switch bad or out of position. Did he try to pull door right after candle. The motor takes time to clear the hook from the latch. If so he probly bent some thing in the mech that latches the door or on the switch plate that holds the micro switch
Apr 25, 2017 | DCS (WOTD-227) Double Oven
Oven Locked Out
The back of your range is a motor (right side?) that controls the locking of the door. The position of the rod may not be right because the motor may be bad. You can disconnect the motor and rod. By removing the rod and bypassing the motor, you can now bake.
Jan 07, 2014 | Ovens
Hit the "clean " button on my gas stove. Not only did it not clean but the Door locked button has been flashing for 2 weeks. Everytime I go to cook and it the Bake, Broil key it flashes DR then F9 I h
Personal opinion. Do not mess with settings on a gas stove. Call a gas oven repair tech and have them come out and fix it. That way if it happens again you have someone to call
Nov 03, 2017 | Frigidaire (FEB30S7D) Oven
Frigidaire Gallery Series Oven Locked
Not familiar with this particular stove, but it sounds like you activated a child protection lock. To turn these on and off, you have to hit that lock icon and hold it for 4-8 seconds for anything to happen. This is so that the kids won't have sense enough to unlock it, assuming that you locked it to keep them out!
Also, frequently they work  in stages. Hitting it one time (for 4-8 seconds) will lock the panel, hitting it another time will unlock it, hitting it a third time might lock the door, and so on. So RTFM, or just keeping hitting it multiple times for 4-8 seconds each, and see what does what. But the manual should tell you everything you need to know. You can go to the GE website, or to managemyhome.com, which is maintained by Sears, and you should be able to find a PDF copy of the manual if you don't have the manual that came with it.
Feb 03, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
How do I clear error beeping (F9) on my Amana gas range
try to hold in on the oven light switch plunger that the door would hit if it was closed properly. what you probably did was to pull the door open while it was trying to lock. once you hold the plunger in, then hit the clean cycle again and then push to cancel button to get the door latch to unlock the door. it may take a minute or two but that should clear up the error code and let you use the oven again.
next time if you push the clean by mistake, just let it go and then when it says "locked" just push the cancel button. it will unlock and be ready to use.
Jan 27, 2009 | Maytag MER6772 Gemini Electric Kitchen...
GE JGBP80 oven shuts off and the locked door light flashes
That's awesome! I just found this site on Christmas day minutes away from family arriving and I had exhausted the manual for help. Under the troubleshooting section of the manual it lists "door Locked" light blinking as a problem with the only solution being - "shut the door." With three dishes in the oven that didn't help!
I took the advice of the site and wiggled the actual door lock on the inside of the oven and that didn't work right away either.
I had to trick the oven into thinking the door was shut by pressing the sensor on the right hand side in and then turn on the oven cleaning cycle with the sensor held down. After the lock activated and moved across with the door open, I had to hold down the door unlock feature and wiggle the lock as it unlocked. A little more complicated, but none the less it worked!
It must be a sensor inside the locking mechanism that isn't reading the lock being open - or something...
Dec 08, 2008 | GE Profile JTP18 Electric Single Oven
Oven door won't unlock
I had the same problem on my Kenmore Electric Range. Door would not unlock. Tried pressing "Off" for multiple seconds, but still would not unlock. No error codes. Clock was displaying normally. Finally decided to try running it thru the self cleaning operation to get it to cycle thru locking and unlocking the door. When I started self clean, the door automatically went thru the auto lock and "locked" appeared in the display. I then hit "Off" to clear it and stop the cleaning cycle. The door then unlocked as normal!
Feb 16, 2008 | Kitchen Ranges
How do I clean my frigidaire self clean gas oven
after the three hour prompt comes up hit start while the door lock light is blinking and let me know what it does
Jan 09, 2008 | Frigidaire FGB24S5A Gas Single Oven
Kenmore Elite Range door locked error message
Hold down the number three button until the LOC message disappears and then the door will open.
Dec 23, 2007 | Kitchen Ranges
F9 code
I hit the same F9 problem when trying to self-clean, except that the door was locked OPEN.
After much trial and error, I found the following fix: 1. Switch circuit breaker off. 2. Switch circuit breaker on. 3. Press Bake button. 4 Press the small/inside button which indicates that the oven door is closed.
The lock mechanism opened and the oven now works fine.
Nov 22, 2006 | Amana AOCS3040 Electric Single Oven
Kitchen Ranges Logo
67 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
