Eurovox problems max
F orgotten my pin number ive accedently skipped a channel.and i would like to retrieve it
  • shimya Nov 25, 2008
    im sorry. your comments ,still does not help me.
  • 89 Answers
Im assuming your talking about the Pin for the Parental Controls? To my knowledge there is no place online that can help us reset your pin, You will need to contact the manufacturer and have them give you instructions on resetting the pin, The only way i would think you would be able to get the skipped channel back is to get the pin, Sorry for your trouble.
Posted on Nov 25, 2008
I have a Eurovox EX7000hd, i tried to re-scan recently and its asked me for a PIN? Ive never set a PIN and have had no problems over last 6 months. Ive tried 0000,1004,1007 and 1648 plus many random ones....
All eurovox/starview and digivox boxes have been blocked from nagravision encrytped channels, this shows in different ways on different boxes.
Virgin has now switched to nagravision 3 encryption.
All eurovox/starview boxes can now only receive SOME free to air programs.
If you rescan, all the programs are picked up, but all the encrypted channels are blocked.
There is no fix yet, and there will probably be NO fix for your box, or any box without an ethernet connection.
Check afterdawn.com or techkings for more info
Sep 12, 2010 | StarTech.com StarView SV211K 2-port KVM...
Eurovox max v most of the scrambled stations are saying insert smart card i have never had to put a new code in and dont know how to
Smart card is a card that is inserted into the settop box(I believe thats what you are using) so that your subscription is activated and you will be able to watch channels. If the card is already inserted Turn off the set-top box gently pull out the card and re-insert it. If problem persists or you do not have a smart card kindly contact your cable operator so that he can provide you with the same.
Apr 25, 2010 | Televison & Video
Why does mu Eurovox Max V box not get ESPN or Sky Sports 1? It gets all other Sports channels.VM user.
It is possible that the channel name is not being resolved as happens with me with some channels. I have to go through the "TV" numbered channels till I find the one I want and then rename it. eg TV1003 etc I don't know the number for ESPN.
Oct 05, 2009 | StarTech.com StarView SV211K 2-port KVM...
Can any tell me how to setup a eurovox its the 2007 version ive scanned the channels theyve all came up but skysports, movies and all the other channels you pay for wnt come on. i used to have a starview...
Dont know if it helps or not but this is the method i used to set up the eurovox max when i first got it - it may work for you.
EUROVOX MAX SETUP
This is the method I use for setting up the eurovox max box but I have been told that it works for versions 1 and 2 as well
PLEASE NOTE : IF YOU ARE USING A SPLITTER IN YOUR SETUP THIS MUST B E REMOVED for the initial POWERSCAN as the box needs to scan from a pure signal- this will ensure all channels being found. – scanning throught a splitter can result in the loss of 50+ channels.
Firstly before you start to scan the box you need to:-
PRESS MENU
GO TO CONFIG
GO TO CLEAR DATA – IF IT ASKSYOU FOR THE PIN PRESS 0000
SELECT – ERASE ALL CHANNELS
Then it will ask you are you sure so press OK
Then wait a few seconds then press EXIT and EXIT again
What you need to do now is a POWERSCAN.
The following is a step by sep method of carrying it out!
Press the MENU button
Go to INSTALLATION and arrow right to USER INSTALLATION
Type in your pin (normally 0000)
Press the YELLOW button for POWERSCAN and change the mode to FULL from Normal by arrowing right to reveal FULL
Now press OK, this will begin the BRUTEFORCE POWERSCAN which can take up to 40 minutes,but it is guaranteed to find every single channel on the network in your area.
Once done the box will switch to a random channel to indicate it has finished !
You will now have around 240 or more channels (in some cases regions can receive up to 330 channels!)
You now need to switch to a non free channel and let the box update the codes – this could take a minute or two, it will indicate on the screen “updating please wait” once finished all channels will now be unlocked.
That’s it you’re all done … HOWEVER …. If you find that you get no channels at all there is a further adjustment you can make to ensure you get the 250 plus channels that your area box will be able to receive and again it’s quite simple to do!
First press MENU
Then go to USER INSTALLATION
Type in your pin (0000)
Press YELLOW button to POWERSCAN
Then change the mode to NORMAL
Then arrow down to the SYMBOL RATE and if its on 6.952 then change it to 6.887 (or vice versa!!)
Then press OK and it will carry out a scan like the powerscan of before.
If after you have tried this and you still are channels short then keep the symbol rate at the new figure but adjust the scan to FULL and try again.
Sep 16, 2009 | StarTech.com StarView SV211K 2-port KVM...
Eurovox Max V -codes required for basic channels on Chorus Dublin
Then you don't need codes. It won't amplify the signal and if it's weak it won't receive all the channels.
Sep 15, 2009 | StarTech.com StarView SV211K 2-port KVM...
Key codes for eurovox max v
ebay selling codes for £1.00
have you checked there?
Dec 16, 2008 | StarTech.com StarView SV211K 2-port KVM...
EUROVOX MAX V - North East /Mbro
ok try this to sory your problem out. Press menu, 1570 , on nagravision screen is EMU set to ON ?
press ok , code screen make sure this is in box . Provider ID NTL 5401,
key 0. 3F B8 36 62 72 E5 E2 76
key 1. 35 5E D6 40 6E AA 99 41
should work fine now .good luck.
Eurovox Max V 2008 - needs new firmware flash (27 Nov 2008)
go to http://www.bigmaq.co.uk/ download the latest firmware its there ive seen it install that problem solved
Dec 04, 2008 | Audio Players & Recorders
I have eurovox max 2008
due to upgrade in the software of the eurovox and other recievers you will need to upgrade your box once you have done that power scan your box and it should be up and running.
Dec 01, 2008 | Audio Players & Recorders
Televison & Video Logo
Top Televison & Video Experts
