Question about GE 7-4836 Clock Radio
Strange fixed display for GE 7-4612B clock radio
The clock cannot be set and only displays what appears to be:
1P:G8
The hook on the `G' isn't there but other than that this is how it looks.
It has worked well for a long time. It has no battery but has worked without it all this time.
Thanks for any ideas or solutions...
  • 3 Answers
I have this same problem with my clock radio, same model #. I have a feeling that this may mean this clock will be on its way to the dumpster very soon.
Posted on Nov 22, 2010
How do I set the time on Timex T231 clock radio?
Setting The Time of T231
NOTE: The time can only be adjusted when the clock radio is in the OFF mode. If the radio is playing, press and hold the MODE/ALM RESET button until the display briefly shows 'OFF' and then reverts to the time.
1. If the display is flashing, press the HOUR / REV button to advance the display to the correct hour. If the display is not flashing press and hold the CLOCK button until the display begins to flash, then press the HOUR / REV button to advance the display to the correct hour. Observe the PM indicator to confirm that you have set the hour correctly. If the PM indicator is 'On' the hour on the display is PM. If the PM indicator does not appear the hour on the display is AM.
2. Press the MIN / FF button to advance the display to the correct minute.
3. When the correct time is flashing on the display press the CLOCK / PRESET button once more. The display stops flashing and the clock begins to run.
Oct 01, 2014 | Timex Audio Players & Recorders
Tip
USING THE CLOCK 1. NORMALLY THE LCD CLOCK DISPLAY (6) SHOWS THE HOURS AND TIlE...
USING THE CLOCK
1. NORMALLY THE LCD CLOCK DISPLAY (6) SHOWS THE HOURS AND TIlE MINIJTES.
2. BY PRESSING SET (9) ONCE THE MONTH AND DATE WILL APPEAR.
3. BY PRESSING SET (9) TWICE THE DISPLAY SHOWS THE SECONDS.
4. TO RETURN TO THE NORMAL DISPLAY PRESS SET (9) ONCE.
on Mar 05, 2009 | Jeep KNG36-JXLWBC AM/FM/Weather Radio
Instructions
From the manual:
Setting the Clock
1. Press and hold the Time Set Button until the display begins flashing
2. Press the Reverse or Forward Button to set the time. Holding a button for a few seconds will advance or reverse the time rapidly. Set the correct AM/PM time, shown by the PM Indicator on the display
3. After setting the time, press the Enter Button or wait about ten seconds for the unit to beep twice and the display to return to the normal mode
Setting the Calendar (It is important to set the correct date in order to use the 7-5-2 Alarm settings)
1. Press and hold the Date Set/7-5-2 Button until the display flashes and the year replaces the month/day at the bottom of the display
2. Press the Reverse or Forward Button to set the correct year, and then press the Enter Button. The unit will beep and the display will show the month and day. Again, press the Reverse or Forward
Button to set the current date
3. After setting the date, press the Enter Button or wait ten seconds to return to the normal display mode
Setting the AM/FM Radio Alarm
1. Press and hold the Radio Alarm Button until the settings and radio frequency appear on the display.
2. Press the Reverse or Forward Button to set the alarm time.
3. Use the AM/FM Band Button or the Memory Set 1-6 Buttons to select a radio station to wake up to. Adjust the alarm volume using the Volume Thumbwheel
4. After setting the wake time and sound, you will need to select your 7-5-2 setting. The 7-5-2 setting lets you set the alarm for a full week, Monday through Friday, or the weekend. Before setting the alarm, be sure that you have set the date, as shown in the Setting the Clock and Calendar section. While the display is still flashing, press the Date Set/7-5-2 Button until the desired setting is shown at the top of the display.
5. After you have programmed the radio alarm, press the Enter Button or wait ten seconds to return to the clock display. The Radio Alarm Indicator will appear on the display, showing that the alarm is set.
Setting the Nature Sounds Alarm
1. Press and hold the Sounds Alarm Button until the settings and Nature Sounds Indicator appear
3. Use the Nature Sounds Button to select a nature sound to wake to. There is a choice of four sounds:
Sound #1: Ocean Surf
Sound #2: Forest Spring
Sound #3: Rushing Brook
Sound #4: Summer Wind
5. After you have programmed the nature sounds alarm, press the Enter Button or wait ten seconds to return to the clock display. The Nature Sounds Alarm Indicator will appear on the display.
Setting the Buzzer Alarm
1. Press and hold theBuzzer Alarm Buttonuntil the alarm setting appears on the display.
3. After setting the wake time and sound, you will need to select your 7-5-2 setting. The 7-5-2 setting lets you set the alarm for a full week, Monday through Friday, or the weekend. Before setting the alarm, be sure that you have set the date, as shown in the Setting the Clock and Calendar section. While the display is still flashing, press the Date Set/7-5-2 Button until the desired setting is shown at the top of the display.
4. After you have programmed the buzzer alarm, press the Enter Button or wait ten seconds to return to the clock display. The Buzzer Alarm Indicator will appear on the display, showing that the alarm is set.
Dec 06, 2013 | Timex T309TT Clock Radio
CRA108: I can not set the time. I hold in the time button down while pushing the hour and/or minute button but nothing happens. The clock actual is displaying a time that is not proper. It currently...
My Coby CRA108 starting doing this after 6 months of use. Although I described the display as 1P:C8 since there is no key to properly display the character (hybrid of a G & C). I've left it unplugged and changed the backup battery with hopes it would reset. No luck so far. Anyone have success???
Jan 07, 2011 | Coby CRA108 Clock Radio
How do i set the clock in a 1992 buick century with stock radio
To set the clock, check this procedure:
1. With the radio ON or OFF, press SET. The SET indicatore will appear on the digitas display for five seconds.
2. You must begin to set the clock to the correct hour and minute during those five seconds. Press and hold SCAN until the correct hour appears on the display.
3. Press and hold SEEK until the correct minute appears on the display.
Hope help with this, remember rated this post, and TY for using Fixya.
Apr 15, 2010 | 1992 Buick Century
I have a bose awrc1p radio display light changes
This could be the battery causing the display to act strangely. If the radio still works audio-wise, the following should fix the display: The older model wave radios have either a 9v or 3 AA batteries (accessible from the bottom). Remove any battery, and reset the system by unplugging the power cord for about 40 seconds. Plug it back in without the battery attached. If the problem goes away- replace the battery or batteries. (which is only there to hold the clock time, presets etc when not plugged in) BTW- you'll have to set the clock, alarm, presets etc after this procedure. If the problem doesn't go away, call Bose. I think they can repair this for $99 and/or offer a new one as a trade-in discounted.
Jun 12, 2009 | Bose Wave Radio
Setting the clock
Setting the Clock for Systems with the
Set Button
Press SET. Within five seconds, press and hold the right
SEEK arrow until the correct minute appears on the
display. Press and hold the left SEEK arrow until the
Setting the Clock for Systems with HR
and MN Buttons
Press and hold HR until the correct hour appears on the
display. Press and hold MN until the correct minute
appears on the display. To display the clock with the
ignition off, press RECALL or HR/MN and the time
will be displayed for a few seconds. There is an initial
two-second delay before the clock goes into the
time-set mode
Nov 13, 2008 | 2002 Chevrolet Silverado 2500HD
How to set a deh-p4000ub car radios clock
try this:
Adjusting initial settings
Using the initial settings, you can customize
various system settings to achieve optimal performance
from this unit.
1 Press SOURCE and hold until the unit
turns off.
2 Press SOURCE and hold until function
name appears in the display.
3 Press FUNCTION to select one of the initial
settings.
Press FUNCTION repeatedly to switch between
the following settings:
Clock—AUX (auxiliary input)
Use the following instructions to operate each
particular setting.
# To cancel initial settings, press BAND.
# You can also cancel initial settings by holding
down SOURCE until the unit turns off.
Setting the clock
Use these instructions to set the clock.
1 Press FUNCTION to select clock.
2 Press c or d to select the segment of
the clock display you wish to set.
Pressing c or d will select one segment of the
clock display:
Hour—Minute
3 Press a or b to set the clock.
Turning the clock display on or off
You can turn the clock display on or off.
! Even when the sources are off, the clock
display appears on the display.
% Press CLOCK to turn the clock display
on or off.
Each press of CLOCK turns the clock display
on or off.
Aug 05, 2008 | Pioneer Audio Players & Recorders
BOSE MODEL AWRC-1P
My Bose mod AWRC-1P will not turn on. Please HELP ! !
WA4OBA
Feb 02, 2008 | Bose Wave Radio
Complicated GE clock radio/CD player
To set the time:
Hit the SET Wake/Time Button closest to the CD player until the clock face appears in the bottom left hand of the display.
Use the TRACK Rev Search Fwd Arrows to adjust the time.
Rev will decrease by minutes and Fwd will increase by minutes.
Hope this helps.
Jan 10, 2008 | Audio Players & Recorders
GE 7-4836 Clock Radio Logo
628 people viewed this question
Top GE Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Jim Goldsmith
Jim Goldsmith
john1959ny
john1959ny
Are you a GE Audio Player and Recorder Expert? Answer questions, earn points and help others
