Question about Maytag Neptune MAH5500B Front Load Washer
Door will not open on my MAH5500B front washer
I put in a load of laundry and saw the water coming in but I am not sure if it ran completely through a cycle. I tried to open the door and it would not open. It made a beep noise and the panel said (do) and then Fl.
I pushed the pause button and waited many minutes and it still would not open. The door lock lite is not on, but the door is not opening. You can open it a little but it catches, I am assuming on the door latch or lock latch. Please get back with me as soon as possible as the laundry is piling up.
  • Anonymous Nov 25, 2008
    this same thing happened to me last night. I was on here looking for a solution and here was the answer. Thanks so much.
    However, do I need to re-set the release on the door latch?
  • Maytag Master
  • 2,651 Answers
You can take the 4 phillips screws out of the corners of your soap dispensor, the lid of the dispenser willlift up and youll see wrapped around in there eitehr a floresent green or orange plastic wire. that is a manual release cord for the latch assy. this will allow you to get your clothes from the machine, form there look into why the latch never released
Posted on Nov 25, 2008
Why the water wont come in the washer ,and the door stayed lock
Because the cycle hasn"t get to the point yet were the water need to pump in to the washer so you have to leave the washer on to work it self. u might have mistakenly stopped the washer yourself after u turned it on or something else is wrong and u have to give us some more info on what's going on . Now let just try this and see if ur washer will work.
Let restart the whole process again, the normal way u start ur laundry,
1, Turn washer off ( Like you're done washing )
2, Now put a new load into the washer, check all button to make sure they are in the right position then turn washer on.
Still not working. Then we need some more info or you need to call someone to take a look at it .
Mar 03, 2015 | Maytag Neptune MAH5500B Front Load Washer
Door stuck closed after wash is done
If the water in the machine is above a certain level a fail safe on the door lock will not allow it to be opened. Check the filter, make sure the machine has completely drained. Obviously, there may be a problem with the lock itself but try this first.
All the best
Mar 20, 2013 | Bosch Axxis WFL 2060 Front Load Washer
I have an IQ touch front load washer. lately I have noticed a mildew smell coming from the clothes and drum after washing. i have followed the manual and completed the refresh and comlete cleaning...
Water can remain in ANY washer after the load is done. With a top-loading washer, it's easy to leave the lid up so that the water evaporates. With a front loader such as yours, however, the open door can take space in your laundry area, so we usually close the doors. I suggest that you take a dilute solution of chlorine bleach and water and put it on a disposable cloth and wipe down the inside of your washer as well as the areas around the door itself and the part of the washer that the door closes onto. Once you've done this, leave the door open until the smell dissipates OR overnight. If you will get into the habit of leaving the door open for a couple of hours after you're done with your laundry, you will probably solve the problem.
I really hope this helps. If it does, please come back to Fixya and rate my solution.
Jul 09, 2011 | Electrolux Washing Machines
Hi! I have a Maytag Neptune front loading washer machine. On a few occasions I have found a small amount of water in the drum before starting my weekly laundry. Today when I went to start my laundry...
This is symptomatic of a water control valve not closing completely- its no power/fail position is closed.
Whichever it is, hot or cold, needs replacing!
Service call ;-0(
Good luck,
John C
Mar 06, 2011 | Maytag Neptune MAH5500B Front Load Washer
Once the wash cycle begins, the washer door is locked and cannot open until complete cycle is done. Is this normal or is there a way to stop wash cycle and open the door?
If this is a front load washer, yes it's normal.
You wouldn't want your laundry and all the water falling out on the floor because the door didn't lock, would you ?
Jan 17, 2011 | Washing Machines
Sour smell inside washing machine
IMPORTANT: Read thoroughly. DO NOT add detergent or other laundry products to this cycle.
1. Remove all items from the washer.
2. Open the dispenser drawer and 2/3 cup (160 mL) of liquid chlorine bleach to the bleach compartment. DO NOT use more than 2/3 cup (160mL) of bleach per cycle as this will lead to product damage.
3. Close the washer door and dispenser drawer.
4. Select the Clean Washer cycle or a full wash cotton 104 F wash (40 C). DO NOT use any higher temperature as this will cause unnecessary fumes
5. Press Start and allow cycle to complete.
6. If the bad odour persists, repeat the procedure 1 or 2 more times. This may be necessary if this is the first time you have run this cycle.
7. After the cycle is complete, leave the door open slightly to allow ventilation and drying of the washer interior.
8. Repeat the cleaning procedure monthly.
To maintain the washer freshness:
1. Use only HE High Efficiency detergent.
2. Leave the door open after each cycle to for better ventilation and drying of the washer interior.
3. Use warm / hot water in your machine unless the fabric you are washing requires cold.
4. Use the correct amount of fabric softener.
5. If your laundry room is damp, use a dehumidifier.
6. Clean the door seal of visible residue.
Jul 11, 2009 | GE WHRE5260E Top Load Washer
LG wm1814cw washer is leaking from the front
Did you check the door bellow. I know you said it's not the door but if you really open that rubber pull it back and check it from top to bottom. let me know I'll keep thinking.
Jan 13, 2009 | LG WM-2277HW Front Load Washer
kathy..theres three screws at the bottom panel...remove them,,always unplug first...and you will see your pump claen your filter,,ok onthejob,,just screw it out
Jan 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
108 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
