Question about Whirlpool Kitchen Ranges
I would like to know th oven dimensions of an older whirlpool brand double built in oven Model #RB260PXY
  • 4 Answers
SOURCE: installing a whirlpool wall oven
You could call whirlpool and they can email you the instructions. Or your can go on whirlpool.com and enter your model number under the upper customer support tab.
Posted on Nov 21, 2007
jsrock516
  • 5911 Answers
SOURCE: whirlpool built in double electric oven
Okay...a few more questions. Are both elements NOT working? That is, BROIL and BAKE features are now dead? If so, you may an Electronic Oven Control (EOC) board failure. This is the clock/timer for your range. All the oven features are typically controlled by the EOC.
If its just one element. More than likely the element has blown. You will need to unplug the range and remove the back panel in order to access the terminal lugs where the elements penetrate the back of the oven wall. There are a pair of terminals for each element. A resistance check across these terminals will vary, but should read something on the K ohm scale. If the continuity readings are infinite (open) replace the element. I have a link under my "Tips and Tricks" that explains how to do this, if needed.
Are you confused yet? If so, please post back and let me know.
Posted on Aug 12, 2008
  • 136 Answers
SOURCE: our Whirlpool 27" Built-in Combination
This often is a stuck or faulty door switch and it has blown the interior microwave fuse.
Q-- My microwave is completely dead.
A - House fuse has blown or interior fuse inside the microwave has blown ( usually a part inside the microwave makes this fuse blow ) Sometimes a bad fuse holder inside the microwave cannot hold the fuse tight enough and the fuse will blow as well.
Q - The fan in my microwave oven is not running will this hurt my microwave?
A - YES, the fan cools the magnetron and electronics, take the microwave in for service, most fans are not too expensive to replace.
Q - My microwave blows the fuse inside itself as soon as I push the start button.
A - Usually a shorted high voltage capacitor...see components section
Q - I burnt something in my microwave and now it is dead...help!
A - The fuse inside the microwave may have blown, but more commonly the flame/oven thermostat has sensed the over cooked food and the flame/oven/cavity thermostat has opened up - Info on that
also look for this electric wiring chart given in this link below just click on the link
http://www.applianceaid.com/image/microflowchart.JPG
thanks.
Posted on Oct 13, 2008
SOURCE: Self Cleaning Cycle for Oven
I lost the instruction manual for my Whirlpool 30" Electric Built-In Double Oven and want to clean it. Can I get instructions for how to set the cycle for self-cleaning, etc.?
Posted on Nov 24, 2008
SOURCE: No heat from oven but fan and light works
Timer might be blocked on auto, you need to get it back to a manual setting.
Posted on Oct 18, 2009
No power on double oven after a storm
I have a RBD275PRS00 built in double oven. Had an electric
www.fixya.com/support/t8971528-rbd275prs00_built
Apr 16, 2011 - Had an electric storm the other night and ever since the oven won't -Whirlpool ... Question about Whirlpool RBD275PR Electric Double Oven ... For an oven to require parts after 2.5 yrs of service and 2 self cleanings tells me ... fiest press the on key see if the display comes if not the turn the power off for 5-8 ...
Whirlpool panel buzzing Ovens Questions & Answers - Fixya
www.fixya.com > Forum > Tags > panel buzzing > Ovens
Whirlpool ovens panel buzzing related questions and answers. ... the control panel on my Whirlpool electric double oven Model is RBD305PDS14? ... No power on control panel During self clean cycle the power to the panel went out. ... panel the instrument panel on an oven won't change time because of a storm problem.
Jan 01, 2016 | Whirlpool RBD275PR Electric Double Oven
How do I get a user manual for my Whirlpool AKP802WH Genesis circa fan oven built under double oven?
Do you know about how this unit is? I tried the model number you posted on two different websites and they came up with nothing. Either it is too old or you do not have the right model number. Sorry.
Apr 07, 2015 | Whirlpool Ovens
How do i set the clock on Whirlpool built in double oven? Can't find a model number. 5 buttons from left to right. Alarm bell, clock with hand at 12, clock with hand at 3, + and - signs. Pleas
The model number is usually located on the side of the door or on side of the oven cavity area near the door opening. Sometimes if you have a drawer or warmer the model number is located on the oven side of the drawer or warmer (sometimes not directly facing you but on the side of that area. If the oven is electronic you press a clock button or you hold one of those buttons for a couple of seconds like a start or set button. The model number though will help you find a user manual and it for sure should be clear. I hope this helps you.
Nov 16, 2014 | Whirlpool 24" Double Electric Built-In...
I am havine a problem getting the self cleaning working on my O'keefe & Merritt electric oven. I don't know the model, but I do know that it was purchased in 1978. I've used the self cleaning setting...
Keefe Merritt 12 6267 Manual Book
O & M was merged with what has become Frigidaire/Electrolux Home Products.
You can get parts from them.
The serial number for a built in wall oven from that era would be something like this : 11-6361-30/123
Electrolux's parts number is 800 599 7569. (Phone number)
If the oven needs replacing, Sears, Magic Chef, and Whirlpool offer something in this size range. (You need to measure the dimensions.)
You may need to "google" "O'Keefe & Merritt electric oven repair" plus your location. Electrolux's service department might provide a contact.
Nov 24, 2017 | Ovens
Whirlpool Microwave Oven Serial Number MH660XW-0
Hi Adam,
Built in over the range? The models change so rapidly unless it is less than a year old there probably wont be an identical replacement, Fortunately the mounting brackets remain close if you stay in the same brand. Whirlpools can be purchased at almost any retailer like Lowe's, Sears, BestBuy etc. Measure the the original and look for one that fits that dimension.
Eric
Jun 09, 2009 | Whirlpool Microwave Ovens
May 10, 2008 | Whirlpool GBD307PDS Electric Double Oven
Whirlpool double oven rb130pxv
As long as you line up the hinges with the receptacle in the door, it should slide right down. Try a shot of WD-40 on both.
Sep 08, 2007 | Whirlpool RBD305PD Electric Double Oven
Kitchen Ranges Logo
41 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
