Question about Dell Dimension 5100 (D51L1) PC Desktop
Wont power up
1 went through dell troublshooting ( removing cables from MB ) same problem 2 had power supply checked at Frys Electronics checked OK 3 ohmed on switch OK 4 replaced Motherboard same problem. Only green led on motherboard lites.. nothing else has power?????????????
  • 2 more comments
  • mulepanic Dec 02, 2008
    Computer will not power up. The green led light inside the tower lights up but that is all. I checked the power cable and it is ok because i used the same one with my printer and the printer powers up. I believe my problem may be a power switch/power supply that's inside the cpu, or at least I hope? Any advice?
  • Anonymous Dec 02, 2008
    my dell 5100 wont power up after a virus,a yellow light on the power button keeps on flashing,can anyone help.thanks
  • Susan Donnelly Jan 20, 2009
    how do i remove the motherboard?
  • Patrick Welch May 11, 2010
    No doubt you've fixed this or given up by now but in the interest of helping others with this problem here is a solution. I had the same problem and it turned out to be the Front I/O & Control Panel Assembly. I suspect that the USB ports had shorted out and took the whole card down. The not turning on problem was preceded by the USB ports failing. I couldn't figure out how to bypass the card to power the computer. Dell won't help if you are not under warranty (unless you purchase some additional support). I couldn't find a replacement board on Dell's web site but found some other vendors that sold them. I bought one for about $70 and it did the trick. There seems to be at least two similar model numbers for this card. I don't know if they are interchangeable or what the differences are. If you look on the card there should be a series of numbers. Look for an "X" followed by 4 numbers. In my case it was "X8682". This is the model number for the card. If you search for shopping sites with your Dell model and this card number you should find vendors to buy the card. I think this is a design flaw having the USB ports on the same connection as the on switch. It looks like many people have had this problem. One bad usb port and your whole system is taken down. My guess is that the average user is not going to be able to figure this out and will spend lots of money unnecessarily. For those comfortable opening up the case and covers (you can download the manual from the Dell site) and unplugging ribbon cables this is a fairly simple fix. Keep in mind the card won't come with any instructions. Make sure you follow power safety rules and ground yourself.
Hey arnwulf,u fixed my computer after a repair shop couldnt!-my 5100 had an amber light flashing on front and green light on motherboard.i had to remove the memory boards[if u got more than one u have to remove all]then put power on,turn power off,put memory boards back,power up again and hey wow,it works,u saved me a lot of money,thank you.
Posted on Jan 19, 2009
  • 55 Answers
Try replacing the memory.
Posted on Nov 25, 2008
Hi. I have a Dell Desktop dimentions e520.. 2 months ago, i went on a trip for a weekend and when i came back my pc wont turn on. it was blinking amber or orange. i search online and it might be the power...
The power supply is receiving power from the source but is unable to properly distribute it to the components. It sounds like the power supply but unless you have a power supply tester that indicates if all voltages are present the only way to make sure (and cheaper) is to replace the power supply as opposed to replacing the motherboard.
Sep 10, 2011 | Dell Dimension E520 PC Desktop
HP D7-1245DX Motherboard part number 506124-001 Power supply went bad, was running fine off of battery until battery went dead. Replaced power supply with good HP 463958-001 power supply, but it will...
I would first double-check the "known good" power supply. If there is something bad wrong with the MB, it could have blown the fuse in the power supply. I have seen very few fuses on motherboards, they are normally in the power supply. If the power supply checks out OK, then double check the connectors between the power supply and the MB.
Oct 02, 2017 | HEWLETT-PACKARD Hewlett Packard 506124-001...
My Dell Inspirion 531S desktop won't start back up after power went out at home. Push power button and tries to start up then power button stays amber and tower beeps twice, pause, then repeats. Tried...
if u have another pc at home ,u could try the memory from the dell in it if its compatible.(by dell) reseat the memory,any add in cards,and any video cards,and check all power supply cables to the mb.per the dell site(the 2 beeps are for the memory moduals) though it said to take out the memory and put 1 of them in and boot,if it works fine,then check the other 1.
Sep 03, 2010 | Computers & Internet
Dell Inspiron Vostro 530s won't boot.
I work for Dell, If the power button led light is flashing amber or amber (the Power supply is faulty) The Yellow light you saw inside the motherboard is the "Flea Light" (that is one way you could check if there is still power on the motherboard). Since the motherboard was replaced there are a few more things to check:
1. Video card (integrated or expansion)
2. Monitor (Make sure it displays self test feature when the cables are removed)
3. Monitor Cables (VGA / DVi)
4. Power Cable on the Monitor (try a different cable)
5. Power Supply (you already checked, but i suspect this is causing the problem)
Hope this helps.
Mar 16, 2010 | Computers & Internet
I have a dell xps 410 i replaced the power supply because it wont turn on still have the same problem,i used a dell just shut down one day now it wont do anything just one yellow light on...
Ok to troubleshoot it, connect the PSU to the MotherBoard ONLY, test, you may find that with it connected to the MB only it doesn't work, remove RAM and check, if PSU still No Go then MB is faulty if OK, add devices, DVD, Hard Drive, one at a time untill you find one that stops the PSU, that is ya faulty bit. replace it.
Jan 26, 2010 | Dell XPS 410 PC Desktop
The motherboard not give any display !
last 2 things to do
1.remove the cmos battery
2.remove the cmos jumper.
remove power cable from power supply.
3.wait for 2 to 3 mins
4.put the jumper back to the correct position usually pin one and pin 2
5.try to start the mb if ok
Nov 13, 2009 | ASUS P5N32-SLI Deluxe Motherboard
Dell Inspiron 9100 Laptop will not turn on.
Please try the following DIY to confirm the part
1.remove the battery and check on adapter mode.
2.If not powering on then check with refixing the battery.
3.if no use then check any LED is glowing,check with taping the num lock and if the LED responds then this is the memory issue otherwise a MB issue.
4.if no light glows then also this is a MB issue as converter board is on the board itself
Mar 07, 2009 | Dell Computers & Internet
Dell Dimension power problem
There are several different solutions for this as posted at this Forum.
1) A lot of people have just removed the Jumper for the CMOS and turned the Power back on and back off and replaced the jumper and/or removed the battery.
2) Several people have reseated the Memory and after booting back up it worked.
3) A few had to replace the Mother Board and CPU but in this instance they had to also replace the Case because the Dell case wasn't really fit for the heat of from the CPU.
4) I had the exact same problem and luckily replacing the Power Supply fixed this for me. I had to cut out the back of the Dell case for the toggle on/off switch but when I tested the old Power Supply it was only getting 5amps and this was causing the Amber/Orange/Yellow light to constantly flash.
I hope this helps!
Jan 20, 2009 | Dell Dimension 8400 power supply ** FREE...
Pc wont turn on
1. Remove all USB devices such as printers, mp3 players etc etc.
2. Remove the power-cable and the battery
3. Press and hold the power button for 30 seconds
4. Put the power-cable back in but not the battery and none the USB devices.
5. Turn the computer on
Also check the condition of the USB ports if it doesnt work and the fuse. If this doesnt work then I would recommend a repair.
Jan 19, 2009 | Computers & Internet
Check the fuse, if thats ok then try this -
Jan 18, 2009 | Computers & Internet
Dell Dimension 5100 (D51L1) PC Desktop Logo
219 people viewed this question
Alun Cox
