Question about Dryers
Lint trap not functioning properly
Kenmore 500, only 1 year old. Noticed that not much lint was being trapped in screen over several months. When I pulled the vent tube off the back, it was full of lint. I do not see any way that the lint can get around the screen. What is going on? This is concerning from a fire standpoint.
    Genius:
  • 1,028 Answers
Ck vent to outside with restricted vent system air flow is reduced through screen and no lint pulled through it either ..bet you've had long dry times too
Posted on Nov 25, 2008
The lint screen is only catching lint on the left side of the screen what does this mean?
sounds like you may have a blockage in the ventilation. try cleaning out the vent hose and the lint trap area and see if that helps. Also, you may want to wash your lint trap with a brush. If you use fabric softener, it can get clogged up and be unable to be noticed just by looking at it.
Aug 11, 2017 | Dryers
Hw do you get something out of lint trap?
Should go onto screen covered by a plastic cover that pulls off then remove screen and shake lint into garbage
Aug 12, 2014 | Kenmore Dryers
Dropped pen into lint trap. Now Dryer makes a screeching noise.
The pen has fallen into the blower housing and is hitting the fan blades.
Unplug the dryer!! Remove the two screws at the top of the lint trap. Remove the rear panel. Remove the four screws at the bottom that attach the lint filter housing to the blower housing. Then, remove the pen from the blower housing.
Apr 06, 2010 | Kenmore Dryers
I smell a burning smell from the dryer. I was running dryer a lot today and tonight I smelt something burning when I opened the door. I noticed my light catcher was full, could this be the problem?
Yes it could have been the lint igniting in the bottom of your dryer in future clean lint trap after every load and take trap door out and vacumn inside trap at least once a month If you ignore the lint trap you could end up with a serious fire so take care of it when you remove screen a certain amnt of the lint falls down into the bottom of dryer and after time a buildup can ignite.. more serious with a gas dryer as the igniter and burner is at the bottom of most gas dryers
Dec 17, 2009 | Whirlpool GEW9200L Electric Dryer
Lint is massing toward the bottom of the lint trap
please check your exhaust vent, where the dryer air comes out of the house, this particular pattern is very indicitive of a slow moving exhaust, you may need to clean the duct between the machine and exhaust as well
Oct 22, 2009 | Kenmore 62602 Electric Dryer
Lint fell down the lint trap. How do I get it
Luckily, dryers are light. Best thing to do is pull it out until you can remove the back cover. (unplug it first) Then vacuum and clean all the dust and lint you can. This should be a yearly thing at least anyway. Replace the back plug it in and slid it back. I do mine every 6 months or so.
Jul 13, 2009 | Whirlpool Dryers
Dropped bleach pen into lint trap. How do I get it out?
its not too hard to get out.
you will need a #2 phillips screwdriver and or a 1/4" socket driver
remove lint trap
remove 2 screws at lint trap
unplug unilt
open the top (2 clips between lid and front panel in the crack, push them with a butter knife or putty knife to release top) opens like a hood
pull out dryer and pull off rear panel
on the left hand side there is a metal duct like thing lol
that leads to the lint trap at the top.
there should be 4 screws at the bottom where it gets round.
remove them, and wiggle the duct open. your pen should be there..
May 25, 2009 | Kenmore 62602 Electric Dryer
Lint filter sensor with Error Code: 01 constantly comes on after the dryer is in use for 5minutes or less. Screen is clean, vent from back of dryer to 3ft of flex hose to outside wall is spotless.
Sounds as though the sensor is dirty of faulty. I would recommend having a service tech out to check and replace. Also if the sensor is going bad, it may be tripping it due to the excessive heat.
Apr 08, 2009 | Bosch Nexxt 500 Plus Dryer
Roper dryer by whirlpool- gas dryer
You have a severly blocked vent, its not removing the moisture to the outide but instead getting trapped in vent.reccomned reventing unit with solid duct pipe, not the vynyl flex tubing and mke sure the outside exhaust port is totally free of obstruction a well
Feb 24, 2008 | Dryers
Dryers Logo
117 people viewed this question
Top Dryers Experts
