Question about Mitsubishi WS-55859 55" Rear Projection Television
No more blue
Hitichi 50v715 52`` has too much green ,i can`t adjust it out.
do i need a new blub or is it the light engine?
    Scholar:
  • 167 Answers
HELLO. YOU MIGHT NEED A NEW COLOR WHEEL. FOR YOU SET."GOOD LUCK"
Posted on Nov 25, 2008
I changed the color wheel and the blub the picture is fuzzy and the colors look out of place a lot of green need help!!!!!!! hlp6163w
Are you sure that you have the good color wheel for the LIGHT ENGINE install in your tv. Samsung use different version of light engine who had their own color wheel.
Apr 27, 2010 | Samsung HL-P6163W 61" TV
Have little blue dots in the middle of the screen when TV is on - already changed blub and dots are still there - cause?
The cause is a bad blue TFT panel in the light engine. Unfortunately the only solution is to replace the entire assembly. It is available at http://www.encompass.com I have a tip at http://www.fixya.com/support/r4251975-replace_dlp_light_engine which explains how to remove and install a new light engine as well as where to get the parts. If you need more help let me know. Thanks for using FixYa and for the generous rating.
hardrocko
Mar 19, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
Light does not turn green lights come on fan
Try another blub and check to make sure the cover for the blub is on and the liltte switch is being triggerd by the cover to tell the unite the blub cover is on. Kinda like on a washing machine. Good Luck
Feb 18, 2010 | Mitsubishi SL1U Multimedia Projector
MY SONY 006 IS FLASHING 4 GREEN BLINKING LIGHTS
U have power and sound right?The backlight video inverter board is the prob.
Sep 29, 2009 | Sony QUALIA 006 Television
How do i change the instrument panel lights from blue to green my VW Passat?
trust me the blue is nicer but ull have 2 take the dash off 2 change the blubs
Sep 20, 2009 | 1999 Volkswagen Passat
Blue circle cast on top of & through middle of screen
When you start getting like a blue hue-haze-spot, etc. Yes the issue will be with the light engine system
Sep 01, 2009 | Hitachi 55VS69 55" Projection HDTV
Have a green tint over 90% ot the center of the screen
I had the same problem with my 60V500A about a year ago. The screen got a red tint in the center and the image was fuzzy in that area. A new lamp didn't solve the problem. I did some checking and found out that the original light engine used in this model had a cooling issue that could cause the light engine to overheat and distort the LCD panels. My warranty had run out more than a year before this happened so I figured I was screwed since the light engine was so expensive. I decided to call Hitachi tech support and see if I could get a discount on the cost of a new light engine since the cooling problem was a known issue for this model TV. I calmly explained to them that I was aware of the cooling issue in the light engine and that I felt like a $4000 TV should last more than two or three years. Tech support gave me the phone number for my local authorized Hitachi service center and I gave them a call. Once the technician confirmed that it was the light engine that was the problem Hitachi sent him a replacement light engine at no cost to me. I was WAY past my warranty period so I still had to pay for the labor to replace the light engine. $300 for labor was a lot cheaper than buying a new light engine or tossing the TV and buying a new one. I have to say that Hitachi earned my respect for admitting there was a problem and doing what was needed to correct the problem more than a year after my warranty had expired.
Feb 20, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Hooked up a hdmi/dvi cable
try using the red- blue- green high def connections
Dec 08, 2008 | Hitachi 57F500 57" Rear Projection...
Samsung rear projection tv sp42w4hb
I would check the CRT socket module for Cracked solder joints. If not you may be in the early stages of the CRT shorting, If so you will need a new CRT.
Jan 04, 2008 | Televison & Video
Mitsubishi WS-55859 55" Rear Projection Television Logo
50 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
