Question about Dishwashers
Dishwasher not washing dishes properly
18 month old delonghi dishwasher is working but the bottom rack of dishes comes out unclean. ive observed that the top spray arm is spraying but the bottom spray arm is stationary throughout the entire wash cycle.ive inspected the bottom spray arm and its clean and clear,removed base plate hoses are ok,no leaks. what do you think it could be?
  • 4 Answers
Thanks akubra_lands, it worked for me too on model DW28W. I thought I should elaborate on your answer for anyone else who comes across this while researching the same problem.
The repair is ridiculously simple (takes about 10min) and the only tools needed are 1 philips/posidrive screwdriver and 1 flat blade screwdriver. Assuming you've unplugged it from mains power:
  1. Tip the dishwasher on its right hand side (looking from the front).
  2. Remove 4 screws from the metal base - 2 front and 2 rear (the rear ones have anti-rattle washers on them).
  3. Pull the base away, taking care of the pair of wires leading to the flood indicator float switch which is still attached to the base.
  4. Remove all 4 screws which fasten the solenoid valve to the pipe which leads from the pump upwards to the center of the tank (which feeds the lower spray arm).
  5. Pull the solenoid/valve body off the pipe and you will see it has a whitish plastic flap with a hinge at the top end.
  6. Use the flat blade screwdriver to gently prize open one side of the flap hinge and twist the flap until it is completely free of the valve body. Put the flap to one side.
  7. Replace the valve body, without the flap, and secure all 4 screws.
  8. Reassemble the dishwasher. Done
Now take a moment to admire the handiwork of the engineer who planned the failure of that innocent little plastic flap around 6 months after the expiry of the warranty.
I actually had a repair man come and look at the problem, and yep, right on cue, he told me it needed a new pump motor. $300. When he realised I was on to him he just gave up. So hard for repair people to do an honest day's work these days..
Posted on Nov 10, 2011
I removed the half wash solenoid on the side of the water pump and notice the plastic flap was ajar and getting forced down with water pressure even though half wash hadnt been selected. i removed the plastic flap, replaced solenoid and bottom spray arm works fine now. we never use the half wash cycle so it was a good result for us.thanks for all your help. regards rob
Posted on Nov 26, 2008
Just had the exact same fault. Model DW28W.. Removed the flap and presto..all working again.
Posted on Feb 21, 2015
My Hotpoint dishwasher works fine except that it will no longer wash the dishes in the top rack. It's like the water is not coming up far enough from the bottom to do the job.
There should be an upper spray arm to wash the upper rack, it may be stuck. Look at its position, run the machine a few seconds and see if it moved. The spray nozzles on the arm often get clogged with food particles. the pipe feeding the spray arm has to extend when you pull the rack out and retracts when you push it in. Make sure it works properly and has not disconnected.
Sep 04, 2017 | Hotpoint Dishwashers
I don't beleive my sprayer arm is working on the bottom of DW
The problem is hard water and your softener must not be taken it all out. There is a new product out called the dishwasher filtration system. It filters the water before it enters your dishwasher. It works amazing and has a money back guarantee. You will love the way your dishes look after the first load. It is also very affordable (like 70 bucks). Go to www.dishwasherfilter.com to find out more info.
May 05, 2010 | Maytag 24 in. MDB4100 Built-in Dishwasher
7-8 year old KitchenAid washes dishes on bottom, but not on top
Position the spray arms in a certain position. Activate the dishwasher for a few seconds and then examine the position of the spray arms. If the upper spray arm has not moved, then either there is no water coming to the spray arm or the spray arm is clogged.
Apr 14, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
My dish washer is not cleaning the dishes properly.it almost seems as if the top rack is no being clean.
try using dishwasher majic or a cleaner / ck the holes in wash arms as the must be clear . clean srreen in bottom and make sure the water tempt is hot enough .min 130 to 140 deg . low water tempt cause=s most dw washability problems . + a fresh dergt. podwer is best as liq freeze in winter and are no good. //**** .hope this helped .
Dec 23, 2009 | Tappan 18 in. MDR251RE Built-in Dishwasher
Whirlpool du1055xtsq 3 not cleaning top rack of
In my experience, you probably have a clog in the spray arm/arms for the top rack. Take the arm(s) out and see if the holes in them are clogged. Rice, plastic wrappers, and glass from dishes that broke in there are the most common culprits I've seen.
Nov 25, 2009 | Whirlpool Dishwashers
Dishwasher leaving white sticky residue on dishes
maybe machine is not filling with correct amount of water try adding an extra omunt of water say 2 litres and see if the machine sounds like it is washing properly
open the door when operating and observe wah arm positions as these turn aroun as it washes
also check that the wash arms are not blocked
Nov 03, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Doesnt dry dishes, top rack not clean, has been serviced 3 times
If you have checked everything that was mentioned (and none of them are the issue) then either the heater inside the unit is not coming on during the wash and rinse cycles and/or the fan motor inside the door is not coming on during the dry cycle. A technician can easily check this out with the correct tools and by putting the unit into test mode.
As for the top rack dishes being dirty and there being soap left in the dispenser, this sounds like wash motor is either weak or the vario motor is not switching between the upper and lower spray nozzles. The sump assembly should be replaced for this issue.
Jan 18, 2009 | LG 24 in. LDF7810 Built-in Dishwasher
Dishwaser working,but not cleaning dishes properly
unfortunately, there is no way to run it and see what it is doing. the only way to check if the spray arms are working properly is to put your ear up to the dishwasher while it is running. you should hear the water spraying along the door panel on both the top and bottom ( Note: some dishwashers run the spray arms simultaneously and sometimes they run at seperate times ).
another thing to check is your water temperature. the water must be 120 degrees in the dishwasher in order to clean the dishes properly. also, if your kitchen sink takes a while to get hot water, you will need to run the sink first prior to starting the dishwasher. I have to apply this method at my house because it takes a while for the water to get hot at my sink. if I run it without starting the sink, the water in the dishwasher is 80 degrees or so and will not clean properly. Joe
Nov 18, 2008 | Dishwashers
Maytag Quiet Series 300 dishwasher, dishes are dirty, control panel only works some of the time, bad smell coming from dishes and dishwasher.
Our control panel is fine. For now. (The machine is only 3 months old). This is our problem--and I haven't yet seen this complaint at all over the internt: The lower wash arm is getting stuck on the bottom rack and stopping immediately. This seems to be a design flaw. The bottom rack is just built too low. A service man was out once. He tightened the wash arm. Didn't work. The service department at the dealership is now ignoring our subsequent calls!! So I wonder if the "not cleaning" problem you have is because of this.
Sep 25, 2008 | Dishwashers
Poor/Uneven Wash Quality
there is a new product out that filters the water going into your dishwasher. it works great and my dishes look fantastic. they use to look dirty with a white film on them. after the first load when i hooked up the dishwasher filter my dishes looked brand new. it is affordable and works everytime. you can get it at www.dishwasherfilter.com.
Oct 11, 2007 | Kenmore 15529 Built-in Dishwasher
Dishwashers Logo
837 people viewed this question
Top Dishwashers Experts
