Our 2 year our Jenn-air French Door fridge suddenly stopped cooling in the upper (refrigerator) compartment. The bottom freezer compartment works fine (-20F). We have tried unplugging and repluggin the power cord. No change. We hear a hum inside the fridge, but do not think the compressor is running, since the whole unit is much too quiet and is not vibrating at all. Lights are on inside the Fridge. We have also tried running the thermostat up and down to min and max settings? Any other simple suggestions or is it repairman time?
Sounds like the evap fan is not running. The fan takes cold air from the freezer to cool the refer compartment. If the freezer is cold the compressor is running. Generally the freezer will stay cold since the cooling coils are there but it must have the fan working to get the air up to the refer area. Pull everything out the freezer and take the back panel off to view the coils and fan, etc. It's a simple easy job to change the fan. If you find the coils are a total block of ice then it's another problem... the defrost cycle isn't working. Sooo... see if the fan is running in the freezer compartment first. See http://www.partselect.com/Schematics/Maytag/AA43-57.gif for fan location, item 18 is the fan motor. Let us know what you find out.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
The fan is turning and the coil is clean except at the enterence to the freezer (i.e. the coils are NOT a complete block of ice). It is frozen at the back of the freezer compartment behind the vents. We are using a heat gun to melt that.
BTW: There has been this annoying buzzing sound for the last several months...
Scratch that about the fan. We were looking at fan #25, not fan number 18. We are not sure how to find that fan.
sorry for the last posting, we opened the very back (behind) of the unit. we tried to open the back panel inside the freezer but couldn't get it open. We did find that the coils seem to be the big block of ice that you mentioned...
we will leave the door open and the unit off until morning.
My Jenn-Air French Door bottom freezer refrigerator is model number JFC2070KRS, apparently an older version of the JFC2089HE, but looks exactly the same.The problem is that while the freezer compartment works fine, the refrigerator compartment does not cool. I am aware of HVACRH20's solution posted on 1/2/07. My question is: Does his solution refer to removing the back panel inside the freezer or the outside panel cover in the back of the refrigerator? Thanks. RAS613
I have a Jenn-Air French door refrigerator and also found that while the freezer worked find the refrigerator was not working. When I investigated inside of freezer I found that the coils have a huge block of ice. The problem is that it takes forever to melt that ice and even if I melt it, would the problem return later ?
Refrigerator doesn't seem to be cooling in either compartment. There is only a small hum coming from the components. Have had several recent power outages and i suspect the compressor may have been damaged. I don't hear any of the "gurgling" it used to make when it was working. It was fine up until about a week ago
I HAVE A PROBLEM WITH MY KIC 2 DOOR REFRIGERATOR FRIDGE/FREEZER COMBO REFRIGERATOR.THE FREEZER WORKS FINE AND THE LIGHT IN THE REFRIGERATOR WORKS WELL BUT THE REST OF THE REFRIGERATOR DOESN'T WORK. WHAT COULD BE THE PROBLEM. THANK YOU REGARDS DANIELLE.
