Question about Broksonic CTSGT8118T 13 in. TV/VCR Combo
Broksonic 8118ctt i need a scmatic for ctsg8188ctt
  • fishingfool1 Mar 23, 2009
    need scamatic for ant jack relacement
Threw out 8118 tv/vcr
thanks anyway
Posted on Nov 25, 2008
Have a S96T vanguard 1980 camper, new to me. When the right hand signal light is on the running lights flash on.need original routing scammatic
Check for a bad, loose or corroded ground first. A bad ground can cause all sorts of funny things that make no sense. I have seen a bad ground cause the instrument lights flash when the brakes are applied, in a car.
Jul 30, 2016 | RVs
I need the scmatic
You need to determining make n model before you will get what you want Re: Jeff
Nov 24, 2012 | Radio Communications
Please show the schimatic diagram of TC-21S80RQ TV
Send your email address to me. I'll send a copy of the scmatic to you by return mail.
Apr 15, 2012 | Panasonic TC-21S80RQ TV
I need a wireing scmatics for a eclipse cd3000 can u help?
Hello there,
I came across the Owners & Installation Manual through the Crutchfield site... the installation manual has been attached inside the Owners manual, at the very end of the document.
the Installation manual begins at page 65
The first wiring description is on Page 70, and the full wiring diagram for the deck is on Page 72
I hope that helps.
May 25, 2010 | Eclipse CD3000 CD Player
Need to find a scmatic for vacuum hoses for my 1994 chevy S10 blazer doesn't start when cold
The vaccume hose routing should be on a sticker on the radiator shroud under the hood.You may need a temperature senser to fix your problem.
Nov 01, 2009 | 1994 Chevrolet S-10 Blazer
Blazer one hub not engaging..suggestions?
Sounds like the spring broke and someone didn't get the bearings tight or lock the nut that tightens the bearings.Its farly easy to do. So jack up the tire.Remove the locking hub and see if it is tight..Make sure when tightening the bearing its ONLY enough to get the slop out of the wiggle which you indicated about it being really loose.Theres also a snap ring that keeps the axle in the locking hub.If any I have indicated is not in there go to your local parts store and they pull up a scmatic and then you can get what you are missing and the order in which the parts go..
Mar 28, 2009 | 1992 Chevrolet C1500
The insterment lights don't work
I know this might sound strange to you, but check the TAILIGHT fuse. Some GM cars suffer similar symptoms. Tailight fuse blows ( tailights inop and unknown to the driver ), and sort of like a warning of something wrong, NO DASH LIGHTS. Check this first. You still might have other probs
Mar 24, 2009 | 1994 Chevrolet K1500
Yaesuft767gx cutting out on recieve and no sideband
You can find ALL of the manuals for the 767gx here at Mods - DK
Hope this helps!
Mar 21, 2009 | Radio Communications
A miswire
The blower is smoking because you have it hooked up to the same wires you've hooked the electric coil to.  That coil runs on 240 volts.  Those wires are typically red and black.  The motor runs on 120.  One of the wires should be shifted to a neutral (white wire).  Assuming the motor is still alive...this will fix it.
Oct 19, 2008 | Intertherm P3RA-048K Air Conditioner
Broksonic CTSGT8118T 13 in. TV/VCR Combo Logo
116 people viewed this question
Top Broksonic Televison & Video Experts
Are you a Broksonic Televison and Video Expert? Answer questions, earn points and help others
