Question about Kenmore 24032\24036 Top Load Washer
SPIN CYCLE NOT WORKING
MY KENMORE WASHER WORKS GOOD UNTIL IT GETS TO THE SPIN CYCLE....THEN DEAD NO SPIN , NO NOTHING..WATER IS JUST THERE INSIDE THE WASHER....CAN ANYONE HELP...
    Sergeant:
    Champion:
  • 291 Answers
Replace the lid switch and that will fix your problem
Posted on Nov 24, 2008
Kenmore washer 110.16112503 works in wash & spin cycle but not rinse. After wash cycle finished I hear a humming sound and the machine does nothing until I manually start spin cycle. Broken timer?
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
Sep 18, 2016 | Kenmore Washing Machines
Washer quit working in rinse cycle before spin cycle tub full water does nothing but fill with more water when you increase water level
99% of the time the lid switch is what causes this issue, below are two links one where you can get the lid switch and the other explains how to take the washer apart to test and access the washers lid switch.
Cheap Appliance Parts Click Here
Good luck with your repair!
How To Take Kenmore Washer Apart Click Here
Mar 05, 2011 | Kenmore 26882 Top Load Washer
The wash cycle works, but once it gets to the rinse/spin cycle, nothing happens. The washer is full of water and nothing is happenening, even when I try to make it work manually.
The pump is clogged. I take it this a front loader. Pull the bottom panel off (three screws on the bottom) You'll see the pump on the bottom right. Unscrew that clean out (It's going to get messy). You'll probable get a lot of stuff out of there, make sure there is nothing left INSIDE the pump. If the water can't drain the washer won't spin...good luck.
Oct 20, 2010 | Whirlpool Washing Machines
Kenmore washer doesn't spin
the conection b/w the motor and the gear got damage you can get the part online and do it yourself.
you just need to take the pump out and the motor wich bouth connect by clips .
hop it help you
Jan 12, 2010 | Washing Machines
Kenmore 90 Series Washer - No Agitator Movement
You need a timer the motor contacts are probably burnt.
Aug 21, 2009 | Kenmore 15864/15862 Top Load Washer
Kenmore stackable washer/dryer 417.97802792 won't drain
its your brushes on your motor or the motor itself but my guess is the brushes replace and enjoy
Jun 23, 2009 | Kenmore 98702 Stacked Washer/Dryer
Kenmore washer machine cylce stopped in mid cycle
If your washer doesn't seem to work at all, check these:
  • No power
  • Lid switch
No power
Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped?
Lid switch
If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it.
Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
 check these, if still the problem persists then let me know for further help.
Mar 22, 2009 | Kenmore HE2 Plus Front Load Washer
Washer will not fill
not your timer / if anything its eather the water valve or the water slector switch
Nov 23, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore stack washer and dryer
gabehart....sounds like belt is slipping. Replace it. The water pump is on a separate smaller motor so is not affected by the agitator/spin motor.
Jun 04, 2008 | Kenmore 98702 Stacked Washer/Dryer
Washer only works on spin cycle
Sounds like u need a new control panel
Mar 18, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore 24032\24036 Top Load Washer Logo
67 people viewed this question
Sal De
fordexpert
 Brian Main
Brian Main
