Question about Whirlpool Refrigerators
Food freezing in refrigerator and water dripping
We notice water dripping on the top shelf in frig and it will build up in bottom drawers of frig, also we set it on the lowest setting because food is freezing on top 2 shelves, food is still freezing on the lowest setting.
  • Anonymous Mar 31, 2014
    type bma26f food is freezing
  • 370 Answers
The problem with the water is that the drain tube is plugged. The easiest way to fix this and to save money is to unplugg the refrigerator and leave the doors open all day. This will thaw out the drain tube without a service technician coming out. That will fix that problem. With it freezing the food on the where its not supposed, This may be a bad cold control. But try unplugging the unit for a day with the doors open and this may fix both problems. (i know it will fix the water issue)
Posted on Nov 24, 2008
Hotpoint model #ctxy14epjrwh slow water drip from inside of the refrigerator. inside the top of the frig, center, there are several components that appear to come down from the freezer. the lowest one...
That water is from the melting frost of the automatic defrost cycle. Their is drain in the freezer behind the back wall under the evaperator coil that is blocked, so instead of defrost water draining it's pooling in the freezer or in some case espically on models with the freezer on the top,the water is leaking from the freezer vents into the fresh food compartment.
The way to clear the drain is remove back plate and remove all ice build up and GENTLY make a small hole in drain through then totally flush w/warm water.
The exact location of drain is under the coil behind back freezer plate in the centeroldtech2332_52.jpg
Aug 24, 2011 | Refrigerators
I have a top freezer/bottom refrigerator-6months old-no icemaker hooked up. There is water dripping continuously into the refrigerator compartment-some of it freezes and the rest accumulates in the...
Good luck
I hope this helps
Gene
Aug 17, 2011 | Maytag 21.7 Cu. Ft. Top-Mount Refrigerator...
At times, there is water that freezes under the vegetable/fruit drawers that are at the bottom of the refrigerator. Also, at times there may be a thin layer of ice on the floor of the top freezer. I'm...
Your freezer drain is clogged or frozen up with ice blockage. Need to remove the freezer floor liner, usually 2-4 1/4" screws holding it in - slide it out. Next slowly pour hot water over ice build up and melt all ice. The drain is under the evaporator coils (small hole near center) this connects to a pan under the refrigerator that then evaporates on its own. I usually place a couple of bowls inside fresh food area on top shelf to catch excess water dripping through ceiling of fresh foods.
Next you will need to attach a heat probe from the heater under the freezer coils and feed it into the drain in order to prevent freezing up again. Use part #819043 heat probe or strip some #14 gauge copper wire and wrap around heater once and place down through drain. Recommend the heat probe 819043 to get it right the first time.
Jan 30, 2011 | Roper RT21SKXLQ Top Freezer Refrigerator
Water dripping in the refrigerator and freezes on the top shelf. It seems to be coming from the freezer compartment. There is a square piece of metal missing from the top of the main compartment. One can...
Removed everything from the freezes. Removed a false bottom from the freezer floor, 2 screws. There was an ice build up under this plastic bottom. I let the ice melt with the de-frost cycle (or frost free cycle). No more water dripping into the refrigerator compartment.
Dec 15, 2009 | Whirlpool Refrigerators
Water dripping from freezer onto top shelf of fridge with ice buildup back of freezer
the defroster isn't close enough to the drain to be effective. remove the back wall of the inside of the freezer, remove the excess ice. clear out the ice from the drain using hot water and a turkey baster. there is a kit from whirlpool that uses a piece of metal and a screw around the defrost rod, but I found out that a piece of 14 gauge solid core wire with the insulation stripped off works great too. stick the stripped wire into the drain, 2 to 3 inches, and wrap the rest around the defrost rod.
Jun 02, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Hi, I can help you. The drain is plugged in the freezer section. Could I get the model #?
Some models need an after market drain heat strip added.
Please let me know and I can get you through tis.
Thanks
Vic
May 30, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
GE Profile Arctica - Frig Freezing Food
Replace the damper assy, in the Refrigerator section. The damper door is stuck open. Very common problem on these refrigerators.
Nov 24, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Dripping water
YOUR DRAIN FROM FREEZER TO DRAIN PAN IS CLOGGED,LOOK INSIDE TOP BACK OF REFRIG. SHOULD BE DRAIN HOPPER,REMOVE AND CLEAR OUT DRAIN,THANKS-MIKE
May 29, 2008 | Whirlpool ET1FTKXK Top Freezer...
Roper Refrigerator
open the freezer compartment loo for ice build up on floor of frezer especally towards rear behind back panel. sounds like you have a clogged/frozen defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials)
Mar 05, 2008 | Roper RT21AKXKQ Top Freezer Refrigerator
Refrigerators Logo
268 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
