Question about KitchenAid KEBC107 Electric Single Oven
Oven will not heat at all after an interrumpted cleaning cycle (power went off)
I have a brand new oven that stopped working after an interrupted cleaning cycle. All lights work fine but it is not heating at all. The fan is working. Can some one tell me what to do? - This was the second time I was using the oven - I used the self clean and the power went off due to a storm.
  • sidemidt Oct 13, 2008
    I have basically the same situation with my KERS807 except when the power went back on, the range won't turn on at all. No lights, fan, nothing works with the one exception being the lock on the oven door, you can't open it. I tried resetting the breaker at the main panel & no response.
    And I realize it's an oven & not a cable modem or something, but I thought it might be worth a shot so I tried pulling the oven away from the wall, unplugging it for awhile & then plugging it back in, with the same result, nothing. )-:
    Sounds like mine probably needs more than just a thermo switch...]-: Help Please!
    Novelist:
  • 116 Answers
There is a thermo fuse located behind the back panel of the oven. If the oven appears to be working but is not actually heating then this is the cause. The oven will have to be removed from the wall, power to the oven shut off at the main breaker and the back panel removed. the thermo fuse is just to the left and up from the center of the convection fan. It has 2 wires connected to it.
Posted on Mar 11, 2007
Hotpoint self cleaning oven clean light won't stop blinking
might need to run it through the cycle again. you may have disrupted the timers and if has not reset itself. try this link and see if these answers help you out.
Why does my oven light keep blinking after the self cleaning cycle on my...
Dec 02, 2017 | Hotpoint Ovens
I interrupted the cleaning cycle accidentally. The door opened after cooling, and then I tried to restart the cleaning, but now the locking latch is in the lock position with the oven door open. How can we...
First make sure that you wait long enough before you try. If it has not cooled completely it will not release the lock from the lock position. Sometimes if you cycle the power to your oven off and then on again you can reset the oven and the switch may relax, but in your case you may have to lightly pry the latch assembly to the open position. Turn off the breaker to your oven for a good minute or two before reapplying the power again.
If this fails to work then check your manual for instructions or to get a factory service number. They should be able to give you the information you need to open your oven.
Nov 03, 2010 | Ovens
Oven self-clean won't turn off!!
You will need to press the stop/cancel button, this will clear the cleaning cycle, due to the interruption. If this does not clear the display you will need to unplug the stove for five minutes and then plug it back in and this should clear the display.
Nov 14, 2009 | GE Ovens
Bottom oven doesn't heat after running self-clean cycle
Usually, when an oven won't heat, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
Aug 17, 2009 | GE Profile JTP56 Electric Double Oven
Circuitry may have gotten tripped during clean cycle. Oven will open and electronics work but neither element will heat.
baked control module for heating elements. if you have a volt meter, check for power when oven on, if no juice its the control element, if you do get juice then its the elements
May 28, 2009 | Whirlpool GBS277PRS Stainless Steel...
Display went blank during the self cleaning cycle
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
uiitu
Apr 29, 2009 | GE JTP28 Electric Double Oven
Our Dacor Millennia wall oven will not heat
There is a manual reset button behind the vent under the touch pad. Turn off the power. Open the door. Remove the vent. Behind the latch is a two wire switch. press the red button on it until it clicks. reassemble and turn on power. It over heated when the power went off by stopping the cooling fan.
Mar 04, 2009 | Dacor MCS130SS Millennia Electric Single...
Jenn-Air JMC7000 Microwave Stopped working
take the trim off of the microwave and on the top of the oven on the right side all the way in the back there should be a reset button just like a surge protector.
Dec 01, 2008 | Ovens
I want to stop the self cleaning function
To Stop or Interrupt a Self-Cleaning Cycle
If it becomes necessary to stop or interrupt a self-cleaning cycle due to excessive smoke or fire:
1. Push CANCEL.
2. Once the oven has cooled down and the word "LOCKED" shown in the display has gone out, then the oven door can be opened.
Nov 15, 2008 | Frigidaire GLEB27S7A Electric Single Oven
Oven shut down during Self-cleaning
tde, sounds like your thermal fuse (TC0) opened on the back side of the oven. If this opens, it will shut the oven down. This happens alot during self cleaning on built ins. Sometimes I have to re-route the tco to a different area to prevent this from happening. Your part number is 4451442. You will have to pull the oven out far enough to remove the back paneling and replace the fuse....Catriver..post back.
Oct 24, 2006 | Whirlpool RBD275PDS Electric Double Oven
KitchenAid KEBC107 Electric Single Oven Logo
358 people viewed this question
Top KitchenAid Ovens Experts
Marvin
Marvin
Craig Butler
Craig Butler
Jim Goldsmith
Jim Goldsmith
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
