Question about Rockford Fosgate Punch 301M Car Audio Amplifier
Fuse location on a punch 301m
I cant find the fuse on the amp it self . all other amps that i have had there has always been sn on board fuse. so where is it on this one. plz help me
  • 631 Answers
The older Rockford amps required external fuses. There were no on-board fuses.
Posted on Nov 25, 2008
I have 2 10" Kicker Comp Subs
That amplifier is only rated at 150 watts at 4 ohms, or 300 watts at 2 ohms. Not a very strong amp to run 2 kicker comps. My guess is you have the subs wired wrong for your application. There are 2 types of subs, one is a dual 4 ohm, and one is a dual 2 ohm. Most people bridge these coils together and that cuts your ohms in half. For example. Lets say you have the 10cvr104 subs. Thats the dual 4 ohm sub. You wire the coils together in parallel, now its a 2 ohm sub. You have 2 of these subs running off of your amp, if they are hooked up in parallel, now you have a 1 ohm load, out of the amplifiers normal operation. Your amplifiers internals heat up really quick and there is a thermal overload, putting your amplifier into circuit protection mode. My suggestion for wiring your subs is as follows: for each speaker, wire the coils together like this- positive coil1 to negative coil 2 and negative coil 1 to positive coil 2. That is called running in series, and doubles your ohm load. Next, we need to wire the speakers together properly to hook up to your amplifier. For this, since the coils are hooked together, you only need to use one set of terminals from each sub. And take the positive from sub 1 and hook it to positive of amp. Take negative sub 1 and hook it to positive of sub 2. Take negative of sub 2 and hook it to negative of amp.
Aug 30, 2012 | Rockford Fosgate Punch 301M Car Audio...
I got a rockford fosgate 801s. and i cant find where the fuse is located.
Regards, Tony
May 22, 2011 | Rockford Fosgate Punch 801S Car Audio...
I need to repair my amplifier ..but the tecnition asks me to get the schematics of this amp due to that here in BSAS..ARGENTINA THERE IS NO INFO CONCERNED TO THIS ITEM..thereso...having this info we can...
I have few schematics of Rockford Fosgate units, let me know model number of amplifier to see if its schematics exist in my stock or not.
In case schematics does not exist in my stock, you need to contact Rockford Fosgate for required schematics.
Following schematics exist in my stock:
G250A2
G800A2 Punch 801S PC4333
TEBD10001
1001X
100X2
301M PC 4309H
551S PC4340A H500A2
600A5 PC1986E
601X
MOS 650SCH
PC1000SCH
Power 300SCH
Punch 2001X
Punch 500M
RF2000SCH
Thanks.
Nov 24, 2010 | Rockford Fosgate Car Audio & Video
Rockford Fosgate Punch 500a amp wont turn on
check the internal fuses inside the amp its self these burn up real easy plus if it is them it will save you some money
Mar 31, 2010 | Rockford Fosgate Punch 500a2 Car Audio...
What do i do
make sure all you wiring is in the right place if they are then you amp have a prob
Apr 15, 2009 | Rockford Fosgate Punch 301M Car Audio...
Multi amp hook-up
honestly i dont think those to amps will push cvxs no matter how you wire them up.
the rms on the 200 should be used to push a door speaker.
the 800watt should deff just be hooked to 1 cvx but still wont max it out.
Dec 25, 2008 | Rockford Fosgate Punch 301M Car Audio...
Rockford fodgat punc 301m remote wont work
try running a target switch. most likely your soulderin came loose inside the amplifier
Nov 10, 2008 | Rockford Fosgate Punch 301M Car Audio...
Amp not turning on
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
If neither is too low, the power supply in the amp is probably blown.
ROCKFORD FOSGATE Punch 301M Amplifier Problems!!!!!!!!!
Check the Inline Fuse -=Usually located Close to the battery in the engine copartment=- and also check the fuse in the AMP. Without knowing and seeing all of the details i would say to try to bypass the capicator, I know that i always unhooked my inline before jumping the car but i know it happens. Hopefully it will be just that a fuse or the capicator but if some sort of surge resulted from multiple failures get the amp bench tested at A car audio shop. Just some thoughts.
Feb 21, 2007 | Rockford Fosgate Punch 301M Car Audio...
Rockford Fosgate Punch 301M Car Audio Amplifier Logo
411 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
hoyzee1
Tygh Duval
Tygh Duval
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
