Computers & Internet Logo
Posted on Nov 24, 2008
Windows vista upgrades doesnt finish loading other programs
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Nov 24, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
42
Points
What version of windows vista do you have? The basic edition that comes with the computer actually has many bugs that you can only fix with home premium.
Dell xps one a2010 wont boot up after windows 7 upgrade
You can just reload the program and Windows at one point will ask if you want to repair or re-install. You may need to reload the original program 1st, then load Windows 7 for the upgrade to work.
Upgrades read the computer to identify what was previously loaded to qualify the new program. So if it's a Vista to Win7, if Vista wasn't loaded first on the upgrade if you replaced the hard drive in some cases, it doesn't always take properly.
2answers
I want to upgrade winxp to vista online how can i do that?
Hi ,
Unfortunately , there are no secure sources where you could upgrade from , not even at Microsoft's .
You need to buy the install disc in an officially recognized shop .
best regards .
How to change os
Hi
To change OS - Operating system, the easiest way if by upgrading your operating system from Windows XP to Vista or Windows 7 or others.
Here how it works. Open your computer and let it run your windows operating system until it finished loading the windows display. After, put the OS installer on your CDROM to upgrade it either to Vista or Windows 7 and it will run the upgrade process. Follow the procedure and it is easy to follow. It will reboot for 3 times and finish itself. And its done.
I hope it helps you.
I want window vista BUT I DONT KNOW HOW CAN I DO THIS
Hi there !
So tell me, what do you want to do with your computer? Do your computer crash and need to reinstall your Windows Vista operating system? Or you want to upgrade your operating system from Windows XP to Windows Vista.
For reinstalling Windows Vista, is it the same procedure when reinstalling Windows XP and Windows 7. Here is the link on how to reinstall operating system http://www.fixya.com/support/r7410371-reinstall_windows_xp_or_installing_clean. For Windows Vista, here is the procedure on how to reinstall Windows Vista.
1. Just put the installer CD into the CDROM Drive and open your computer
2. If message appear to press any key to boot from CD. Press any key to go to Windows Set up.
3. From there, just follow the installation procedure and put CD key if prompted and it will install itself the whole process. It will reboot for 3 times and don't press anykey when this happen. it will be finished within 20 mins.
For upgrading from Windows XP to Windows Vista, remember that all your files and softwares will be remove except for the hardware drivers. But not all the hardware drivers will be 100% working because upgrading the operating system will make your drivers outdated or not compatible with Windows Vista. If some drivers not working, just install the hardware drivers compatible with Windows Vista.
Here is the procedure.
1. Do not put the Windows Vista installer CD yet into the CDROM drive.
2. Open your computer and let it run to Windows XP program until is is finished to load your Windows settings.
3. Now insert your Windows Vista installer CD to the CDROM drive, it will pop up the upgrade installation wizard and just choose the upgrade installation. It will run the upgrading installation and just follow the instruction and it will be finish with 20 mins.
I hope this will help you and thank you for using FixYa !
Webroot says loading but never finishes
please also upgrade the webroot spy sweeper sofware
I hace gigaware pc cam but it doesnt working on my windows vista lap top.Can you help me
Well the gigaware cameras are not made for vista.. but will work if you just play with it.
I would suggest
unplug camera.
restart PC
after the PC has finished booting and is done loading your personal profile
{some computers take 5 min to finish loading all your setting and starting programs}
so give it a few min
plug in camera and walk away
DO NOT TOUCH YOUR PC
let Vista find the camera on its own... do not force.
It should find it and tell you that it has found it and if it found software for it.
give it 5 min
Hopefully that takes care of your issues..
FYI Not all Vistas can run XP software
only PRO and Ultimate are truly XP compatible
ATCAW Computers
Vista
Try rebooting the system.
If possible, use the BIOS to boot through the CD.
If that works, the Windows Vista Installation screen would come up, and then you would have the repair install option. IF not:
Before windows loads, press F8 and load the system on Safe Mode.
Then, try to load the windows setup CD and try the repair install option.
If none of that works, perhaps your windows defender is on, preventing the system from using protected files.
If that is the case, go to Control Panel > Windows Defender > Disable.
Don't forget to put it back on once finished.
2answers
Upgraded t vista
just visit the manufacture website of your tuner card manufacture
Grand Canyon Tech
Grand Canyon Tech
