Question about Hitachi 53UDX10B 53" Rear Projection Television
Black box covers most of screen some channels, plus gibberish.
Hitachi 53udx10b has blacked out some channels, only when NOT-ADVERT material broadcast. the black box we see covering most of screen is pretty consistent (takes a few secs after tuning a channel to show up), until i changed to a different tuner (ran the comcast sig thru a vcr tuner first), then the black box moved to entirely different channels. because it appears with non-advert material, and there is gibberish (english lettering, nonsense), i'm tempted to blame the closed caption function in the tv or the closed caption transmission. i agree to terms of use. no doubt
  • mc12863 Nov 30, 2008
    Same problem here and we only have an antenna no cable so any answer you all can find is needed.
It is the closed captions on the tv. it is set to closed caption text. turn it off
Posted on Dec 01, 2008
My hitachi 53udx10b was supposedly just serviced but the picture is extremely blue. Have tried adjusting picture to no avail. Help.
I am going to tell you a simple thing to do to know what your problem may be.
With the set on turn the color all the way to zero. Go to a channel if you can that is in black and white. What color is the screen?
If the answer is that it is blue in the background whoever serviced the set did not and could have removed front speaker grill and inspection plate behind it; there is a black plastic block with three screen controls (red,green,blue) and 3 focus controls (do not touch the focus ones.)
I suspect if the blue screen is there a slight adjustment of the blue screen down will correct this.
The picture with the color at zero should be black and white or gray. If blue is background color it will also be with color.
This is called gray scale; picture with color off has to be gray or black and white.
Before you rate this solution if you have questions make a comment right here and I will advise you.
SD TECH
Jun 29, 2011 | Hitachi 53UDX10B 53" Rear Projection...
Black box on screen
Check your closed-captioning setting and make sure captioning is turned off (or set for captions if you really want them). You'll find it's set to "text" mode right now. The set is blanking out a portion of the screen to display text it never receives, and you'll only see this when you view a channel where captions are being broadcast. Most sets have a button on the remote for captions, and it's easy to switch modes without knowing it. Then you wind up with the mysterious black box.
If this helps you out, please take a moment to rate the solution. Thanks for asking here!
Feb 18, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
Smoked out
UNSCREW THE TOP BLACK PLASTIC, IT HOLDS THE MIRROR SO BE CAEFULL WHEN YOU REMOVE IT, FROM THERE IT WILL BE OBVIOUS WHAT TO DO, CLEAN THE MIRROR, BULBS AND BACK OF THE SCREEN. GOOD LUCK
Nov 05, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Large black box keeps covering 80% of the screen
i have the same problem, when i turn the volume knob on hitachi remote it goes away. Anyone heard of thi s???
Aug 30, 2008 | Hitachi 42HDS69 42 in. Plasma Television
Blacked-out box covering 75% of screen
shut off close captioning. the close captioning is in text1 mode and needs to be CC1 in order to work, or shut it off
Mar 25, 2008 | Hitachi 51F500 51" Rear Projection...
Hitachi 50UX14B projection tv
would like to see a pic of problem, im guessing the signal board is bad
Jan 24, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Picture goes Black
that is easy one go to options menu on video look for cc or closed caption option and turn that off
Jan 12, 2008 | Hitachi 43FDX01B TV
Black screen 53in Hitachi 53UDX10B
At seven years old, thats a toss up, because most likely you will be nickle and diming the set from here on in. In my opinion, get a new set. Good Luck
Mar 30, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi 53UDX10B 53" Rear Projection Television Logo
124 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
