Question about Hitachi 70SBX74B 70" Rear Projection Television
65 INCH REAR PROJECTION TV WORKS AND THEN TURNS OFF
I HAD SEARS LOOK AT IT . SAYS THYE DEFLECTION BOARD IS DEFECTIVE . TV WAS MADE IN 2004 (MODEL 65SWX20B) AND NOT WORKED SINCE FEB 08. BEFORE THEN WORKED FOR ABOUT 2 YEARS . WHERE CN I GET THE BOARD?
  • brownmagic Jan 23, 2009
    I have the same TV and the same problem. Sears sent my board to get it fix, but when it arrive at PTS electronics the board was broken in half. I am also looking for a deflection board.
2 Suggested Answers
  • 32 Answers
SOURCE: 65SWX20B 65 in. Rear Projection Television: how do i clean my Hitachi 65SWX20B 65 in. Rear Pro...
Remove the upper back cover of the television and clean the back of the screen, the mirror which reflects the image onto the screen, the focusing lenses (do not loosen or remove the wingnuts).
Posted on May 09, 2010
What's your problem?40-42 inch Theater View Toshiba TV, Date on TV is June 1999. Picture slowly started shrinking from up and down. Model no. TZ50V51 Serial no. 77988872 chasis no. 9951
you're experiencing a vertical deflection issue and will most likely need to replace the deflection board. You can get a deflection board for your model from www.tvrepairworld.com
Oct 18, 2011 | Toshiba 57H81 57" Rear Projection...
The Tv Turns on and off several times without showing a picture. It never turns on completely. What would cause this?
That model is famous for the deflection board having issues, replacing the deflection board should solve the issue. You can get a new deflection board from www.tvcircuitboards.com
Jul 24, 2011 | RCA D52W19 52" Rear Projection Television
Mitsubishi 65 inch rear projector TV with remote. Model WS65807. HD ready, but not HD. Has failed circuit board, part number 930B866001. This board regulates audio and video. Part no longer available...
Short answer: No.
The board and install will cost you more than an LCD/LED flat screen TV.
Sorry for the bad news, but you will save space and electricity with the new TV.
Next problem: Trashing the projection TV.
Oct 25, 2017 | Mitsubishi WS-65807 65" Rear Projection...
On the screen there is a green shadow on one side and a red shadow on the other side of every object in the scene
This tv has two big black ICs as convergence output on deflection circuit board that are defective and causing problem in tv, IC number is STK392-110
replace both ICs to solve tv problem, also chekc for faded color big resistor nearby these ICs or those got burn mark, replace these resistors with same value, aslo check cold/ dry solder joints in deflection circuit board and resolder these joint/ connections.
Thanks.
Jan 21, 2011 | Hitachi 65TWX20B 65" Rear Projection...
How do i relpace the deflection board on rca 52 inch tv projector
There are a series of plastic retaining clips that need to be depressed in order to work the deflection board from its plastic frame mount.
Sep 19, 2010 | RCA D52W19 52" Rear Projection Television
Broken GE HDTV - Need Help To Fix
The deflection board needs replacement. The chirping is indicating the deflection circuit has an issue. You can get a replacement deflection board from www.tvrepairworld.com which includes instructions on how to remove and replace the board.
May 26, 2010 | GE D52GW12 52" Rear Projection HDTV-Ready...
Sears rear projection television
you would have to leave them a email, as Sears doesnt make their own sets they are usually phillips, RCa or magnavox depending on your model. They would have to determine which chaassis you have and who made it in order to locate any parts.
Aug 24, 2008 | Televison & Video
Philips 55 inch rear projection tv
When it is on, do you see any distortion in color?  If not probably bad power supply board. Call 1-800-543-4330 and have model and chassis number and ask for Power supply/deflection board. Only about 200.00
May 29, 2008 | Philips 55PW9363 55" Rear Projection...
Mitsubishi 65 inch rear projection diamond
its the circut board that leads into tv from power cord , i had bought mitsubishi65819 black diamond gray 65inch for $54 ,is under the warranty the board cost $350 , labor $200 but this depends on where u live ,either way it was a steal for me ,but yea i had same problem when u turn tv on it shuts down like not even 2seconds i had tech come out and he had to take the board to get it repaired ,its not available he said but its repairable , was a sears tech so sears can repair it
Oct 29, 2007 | Mitsubishi WS-65869 65" Rear Projection...
Televison & Video Logo
26 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
