Question about HP ScanJet 5300C Flatbed Scanner
ScanJet 5300c didn't work
An HP scanjet 5300c connected to a networked Windows XP-based workstation via USB link.
The administrator downloaded & installed the drivers and the Scanjet works under the Admin account.
When a restrict-privileged user logs on and tries to scan, the Scanjet flags the "device being accessed by another application" error message and quits.
Using [Start>>My Computer>>Properties>>Hardware>>Devive Manager] to debug, it shows the ScanJet is enabled and working. In [View>>Show hidden devices], it shows no competing device that tries to access the scanner. The drivers were uninstalled and re-installed without any luck.
Using [Start>>Control panel>>Scanners and Cameras] to run the Scanner, the restrict-privileged user is able to run it without any error.
Please help resolving the mysterious scanjet 5300c's access issue.
Thanks
TDoan
    Sergeant:
    Champion:
  • 274 Answers
Most likely the destination folder for the scanning is a shared folder with limited rights. As the administrator, reset the permissions for that folder or redirect the software to a common folder with read/write/creation etc... access.
Also, make sure you are using the HP provided drivers and not those from Microsoft.
Posted on Nov 24, 2008
5300c with windows 8
HP only has drivers for:
Microsoft Windows XP
Microsoft Windows 2000
Microsoft Windows NT 4.0
Microsoft Windows 95
You may be in the market for a new scanner if simply plugging it in doesn't get it working.
ScanJet 5300c cse cxi PrecisionScan software driver
Mar 04, 2015 | HP ScanJet 5300C Flatbed Scanner
Where to find a driver for Scanjet 5300C and Mac OS 10.6? I am looking for a free one (minimal use of this scanner).
You can download the scanner driver from the HP Support WEB site. Click on this link and select your model scanner to download :-
http://welcome.hp.com/country/us/en/support_task.html
Apr 20, 2011 | HP ScanJet 5300C Flatbed Scanner
Driver for windows7 x64
These instructions will make your scanner work with Windows 7:
1) Go to this link and download the official Hp 5300C WinXP 32-bit drivers
ftp://ftp.hp.com/pub/scanners/software/sj664en.exe
2) Run the .EXE
This extracts the files to the directory c:\sj664en
3) Edit the hp53sti.inf file
Find this line:
%HPSJ5300C%=SJ5300C.Par_NT,LPTENUM\VID_04E6PID_800000402ED4
Insert this line above it:
%HPSJ5300C%=SJ5300C.Usb.NT,USB\VID_03f0&PID_0701
The section should look like:
; Win2k Models
%HPSJ5300C%=SJ5300C.Par_NT,LPTENUM\Hewlett-PackardHewle76A2
4) save the file and exit
5) delete HP53STI.CAT
6) Install the driver
Open Device Manager
Find the HP Scanjet device in teh device tree (yellow exclamation mark no doubt)
Right click it
Select Properties
Select Update Driver
Select Browse my comptuer
Select 'Let me pick'
Select 'Have disk'
In the dialog, type c:\sj664
Two unsigned HP Scanjet 5300c drivers will appear
Click on the top one
click next
it will tell you to reboot
7) reboot your PC
8) after rebooting, try it out!
I found this worked for me in PrecisionScan 3.03 TWAIN mode only. The HP-WIA part is broken in this scenario and does not appear in the WIA manager GUI at all.
Regards
j0lx
XP X64 Instructions
This is modified from a vista post, so most of the credit goes to that post that helped me make it work on xp x64.
Go to this link and download the official Hp 5300C WinXP 32-bit drivers to use with x64, the one posted on hp's site does not work.
2) Run the .EXE and then cancel the install, don't install the software, haven't been able to get it to work.
4. Find this line:
[Manufacturer]
%Mfg%=Models
5. Change it to all of the following, all 6 lines:
[Manufacturer]
%Mfg%=Models,NT.5.1, NTamd64
[Models.NTamd64]
Don't change anything else.
Save.
6. delete HP53STI.CAT
Go to device manager and update driver or add new hardware
select the directory these files are in
and it will install or select the scanner from the list.
now install a second party scanner program and it will work the one that comes with the installer for hp doesn't work.
so any second part scanner program should now work with the drive that this installs.
Jan 24, 2011 | HP ScanJet 5300C Flatbed Scanner
Can I make my HP5300C Scanjet operate on windows 7
Use windows7 Prof or Ultimate
Install XP-mode
Working in XP-mode
Install the sj664 HP software.
Though the USB device HP5300C can be found, the HP scanning software will not yet find the scanner. Because the scanner is shared between W7 and XP.
On the XP-mode taskbar disconnect the USB device HP5300C.
Then start HP Precisionscan and the scanner will function as before.
It is clear why HP does not advise this simple procedure.
Just because they did not present any clue triggered me to try it once more.
Jan Wondergem
Aug 22, 2010 | HP ScanJet 5300C Flatbed Scanner
How do I get it to scan the photo? I can't find a start button HP ScanJet 5300C
You must download the HP ScanJet 5300 C install and user disk for some of the basic functions to work, they are all based on Windows context and program menu. By context, we mean that the installed TWAIN driver will allow other applications to select and scan from this scanner quite easily. So once the correct drivers are downloaded, you will need a photo or scanning software, for example, Adobe Elements, MS Photoeditor, and a favorite everywhere, IRFANview which is free and available on CNET as a download. It supports all manner of import and Twain device scanning and does so with ease and many useful photo tools, too.
Aug 03, 2010 | HP ScanJet 5300C Flatbed Scanner
My hp scanner 5300c scanner has been problematic when installing on two different computers, causing both computers to need repair. Anybody else have a similar experience?
Download and install the latest driver for your scanner. The 5300c Scanjet did not ship with drivers for XP or Vista. A download is required for XP compatibility. Vista or Windows 7 should recognize the scanner without requiring additional software. If the software you are installing is not compatible it can cause issues with the computer. If you are installing from CD please look at the CD to see if it lists your version of Windows.
XP Driver Download: http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=sj664en&lc=en&dlc=en&cc=us&os=228&product=58381&sw_lang=
Sep 12, 2009 | HP ScanJet 5300C Flatbed Scanner
Trying to find a driver or fix for the hp scanjet 5300c
http://www.pixel2life.com/publish/tutorials/399/how_to_get_your_hp_scanjet_5300c_working_in_windows_vista/
Try this method for Vista, haven't had time try it on my new win7 notebook. But still works great on my other notebook running Vista and XP pro.
Mar 11, 2009 | HP ScanJet 5300C Flatbed Scanner
I'm looking for the Instruction manual for the ScanJet 5300C flatbed scanner.
Download from the link below.
S : Manual for Scan Jet 5300C
Please leave proper feedback for the solution given.
Thanks
Feb 19, 2009 | HP ScanJet 5300C Flatbed Scanner
Hp scanjet 5300c vista
I had the same problem. I tried various compatibility settings (without success). What fixed it for me was going to the Compatibility tab and checking the "Run this program as an administrator" box.
Dec 11, 2008 | HP ScanJet 5300C Flatbed Scanner
Windows Vista Driver for HP Scanjet 3200C
Help me I need vista 32 bit driver for my hp scanjet 3200c.
Thank you
Oct 24, 2008 | HP ScanJet 3200C Flatbed Scanner
HP ScanJet 5300C Flatbed Scanner Logo
459 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
