Question about Garmin StreetPilot C330 GPS Receiver
Won't turn on, will not charge. Is my battery bad?
I have had this for one year only used it 6 times keep it in my house.
  • 1 more comment
  • bhubbs330 Nov 25, 2008
    Where do you solve my problem for free?
  • loveykel Dec 12, 2008
    I use my Garmin lots and have had it for almost two years. When I went to turn it on last week---nothing!! I charged it, but nothing! Total blankness! Help!
  • loveykel Dec 17, 2008
    That worked! Thanks!
Mine did the exact same thing. I found that the frame around the screen pops off and underneath there was a reset button. I pushed it waited 30 seconds, pushed power and it came on.
Posted on Dec 17, 2008
Mazda Bongo Altenetor Is Not Charging.What May Be The Fault?
-Most Alternator not charge, because the brushes are won out.
But here is the basic to determine what is wrong before replace any part.
-Turn on the car let it run to normal idle then use voltmeter to check
power at battery terminal. If it's below 13 volt. The alternator need to be replace. But if it show 13.5 to 14 volt. The alternator is good. The battery is bad. It doesn't hole any charge. Need new battery.
Keep in mine. each battery is last ONLY 5 Years.
Good Luck
Mai
Aug 11, 2014 | Cars & Trucks
I put my Droid Razr on charger but battery symbol comes on with ? mark. Won't charge or turn on.
1. Turn off your phone when it's not in use. If you're not using your Verizon Wireless Razr, then shut it off. Your battery will last much longer if you regularly do this.
2. Charge your phone less. If you charge your Razr nightly, then your cell phone battery won't last long. Try to charge your phone only a few times a week to extend the battery life.
3. Keep your Bluetooth turned off when you're not using it. Applications, like Bluetooth, are notorious for sucking the power from a cell phone battery.
4. Protect your Razr from extreme temperatures. Your cell phone battery lasts longer if kept at room temperature.
5. Discharge the Razr fully. Before you charge your phone, let it completely die. You can extend the life of the battery by regularly discharging and then fully charging it.
6. Leave the battery in the phone. Keep the Razr battery dry and free of dirt to prolong its life.
Aug 20, 2012 | Motorola Mobility Motorla MOTXT912 DROID...
My Computer Kepps Turning off!
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Aug 15, 2012 | ASUS Computers & Internet
Wont charge or keep charge
If thecell phone battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Feb 12, 2012 | Samsung Cell Phones
Replaced altornator 3 times and wire to battery but still won't charge.
if you replaced alternator 3 times , have you had your battery tested ? if battery is bad usually that will cause alternator to keep going bad . try having battery tested . might just need a battery
Nov 09, 2011 | 1994 GMC Sierra
I purchased lenovo z 570 laptop.clarification of regarding battery i am making 0 battery for every 15 days. (A) BATTERY is fully charged (100% ) , even though iam keeping plug in socket & using...
Not really, the older NiCad batteries get a memory effect if you keep charging from a half charged state, but modern Lithium batteries do not suffer from this problem.
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.These rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Sep 10, 2011 | Computers & Internet
My latte espresso battery keeps dying to fast when it's an 8gb and suppose 2 last for 6-7hrs but it only lasts about 3mins can somebody please tell me what to do!!!!!!!!!!!!!
Ifthe rechargeable battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Jun 01, 2011 | Bell Technology Latte Communications Ice ...
My Samung P3 will no longer keep a charge. I can leave it on the charger all day, then turn it on and the display shows a half charge. After which, it will just shut off saying battery not charged. What...
Ifthe cell phone battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
May 08, 2011 | Samsung YP-P3JCB Digital Media Player
A320s battery has full charge , tested with volt meter. computer shows 6% battery
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
May 08, 2011 | Getac A320S PC Notebook
Garmin StreetPilot C330 GPS Receiver Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
