Question about Arris WR850G Router (DHWR850G)
Wireless router won't connect to my laptop
I have a 2wire laptop card.  Running WinXP.  My router is motorola and I can't get the two to connect.  I've tried many things, and yes windows is configuring my wireless settings.  My other computer connects fine, so I know the signal is there.Please help!
  • 57 Answers
1. check your network adapter TCP/IP settings if its set into "Obtain as IP address Automatically".
2. if the settings is set as Automatic and your not getting IP address then select "Use the following IP Address"
3. use IP address followed to your router address like if192.168.0.1 in router type 192.168.0.2 or192.168.0.3 just check the next address IP in your network.
4. after typing subnet IP will automatically set
5. type the router IP address as your default gateway
6. click OK to save your new settings
Hope this will help
Posted on Nov 27, 2008
My 2WIRE router won't give out wireless signal.
Unplug the ISP modem and the 2wire, Check ALL cables and reseat connections, plug in the ISP modem, wait for selftest, plug in wireless, wait for selftest, does your wireless SSID show in Available Wireless Networks on the Laptop? Can you connect using a Ethernet cable to verify it's getting a signal? Contact your ISP and have them verify the signal, have a ISP tech come out to analize the signal, it may be outside?
Feb 07, 2013 | 2wire Computers & Internet
Trying to hook up older dell computer to wireless network (2wire) laptop has wireless card inserted, will not pick up signal from desk top connection.....this laptop did pickup signal from other network in...
Does the older Dell have a wireless radio?
If not, you'll have to use an ethernet cable to the 2wire router or buy a wireless USB card for about $35 or less for the old Dell. I'm assuming you are running XP SP2 or higher system.
Aug 03, 2010 | Dell Computers & Internet
2WIRE Router, Belkin Card, and 10 vs. 13/26 digit encryption key
I would give you two options
1. to change ur wireless key to fit to this card
2. u can still let windows configure wireless for this card as well
However would like to have a clearer report about the problem
Jul 05, 2009 | 2wire (1000-000005-002) 802.11g/b Wireless...
Linksys wireless adapter won't auto connect to 2Wire router
Go into the wireless adapter settings and make your connection "default" and then it should connect automatically .. and if not then look for a "connect automatically setting
May 29, 2009 | 2wire HomePortal® 1800HW Router...
2wire att dsl modem/router on vista
Connect your DSL to wireless router and enable automatic ip on wireless. check whether DHCP is enable in DSL router or not.
Apr 24, 2009 | 2wire 2700HG-B Router (2700HGB)
2Wire 1800HG keeps losing connection
However as you said Desktop works fine and this seems to be issue with Wireless Netwrok card of your Laptop try to upgrade drivers of the Wireless netword card opf your laptop and this may possibly resolve the problem..
Apr 08, 2009 | 2wire 1800HG Router (RG1800HG00)
My wireless light will not come on even if i turn the switch on... why is that?
I experienced this same problem on a friend's AT&T 2WIRE 2701HG-B router. The primary computer used WinXP,sp3; I added a laptop, WinXP,sp3 and a Macbook Pro w/ Leo OS v11, successfully.
How to resolve the issue (rather, how I resolved this issue):
From the desktop computer, connected to 2WIRE:
1) Open a browser and type http://gateway.2wire.net or http://192.168.1.254. This site will automatically detect your settings and provide the necessary info., required to set up your wireless network.
NOTE: NTWK information/settings for THIS router can NOT be retrieved via traditional methods. Ignore all other information that assigns a name to your network and/or password. Follow only this wizard, for success in setting up your wireless connection.
2) Verify that your Firewall and System settings are correct and up-to-date. If not, update your software by pressing the link on the right.
3) Click the Home Networking tab (at top of page):
Locate @ the right of your screen, "Status at a Glance".
Under "Home Network", verify:
"Ethernet = x"; (where x = $1)
"Wireless = 0" (ZERO IS OKAY!)
("Zero" will change to "1, 2, 3, etc.," upon successful connection of ea. new wireless device(s) added to the NTWK).
* Once a new wireless device is initially and successfully connected to the NTWK, the LCD wireless indicator of the router will illuminate green.
4) Under "Wireless Settings":
NOTE, the network name. This is the name (of Network) that you will use to connect your wireless device(s).
The default password is the 10-digit number [in brackets] displayed on the sticker, located on the bottom of the router (directly above the UPC code, below the SN).
5) Click "Edit Settings":
In the DEVICE YOU ARE ADDING, click or type in the name of NTWK, as stated under "Wireless Settings". Next, type in the 64-bit WEP password (10-digit number displayed on the sticker, located on the bottom of the 2WIRE router).
6) Click "Verify your Home Network".
Verify the wireless device you added is displayed and has been added to the NTWK.
The Ethernet setting should still remain = 1 (or however many devices are connected to the INET via wire) and Wireless should = 1 (or more, if +1 device has been added).
NOW, the wireless LED shall be glowing the same pretty green, as all the other indicators on the router! You are now connected. Congratulations!
RP
Feb 17, 2009 | 2wire 2700HG-B Router (2700HGB)
2 wire
Feb 08, 2009 | 2wire 2700HG-B Router (2700HGB)
How do I set up a home network without internet?
Hi
By default, your wireless connection for your 2wire 1000HW is enabled.Assuming that everything is installed properly in your laptop ie wireless cards etc. than you can view your wireless connection using Dell Wireless connection tool and HP wireless tool. Your know its your network when it says 2wirexxxx {x=combined numbers}. To locate the built-in, 10-digit wireless encryption key for your system, please look at the bottom of the product [2wire] near the bar code label - looks like this : [xxxxxxxxxx].
If you want to access the 2wire Graphic Unit Interface ,you can access it by opening your browser and on your address bar type in homeportal- assuming you are able to connect to your 2wire wirelessly. You can view your network and change you wireless settings. This may also help you :
http://shastademo.2wire.com/rgw3-3/rgw/3-3/homeportal/network/wireless_settings.html
To connect your printer you must have a Print Server [ dep[ends on what model of laserjet you are using } and connected to your printer. Again you will need the encryption key to get it running. You must share your printer on each laptop by going to control panel and share it . In there you willl have the chance to change and modify the settings. You can also use the Windows File and Sharing Wizard. to get it both running.
Hope that would help you a bit. Pls feel free to post your questions in Fixya for further assistance.
Wish you all the best.
Cheers.
Jun 11, 2008 | 2wire HomePortal 1000HW DSL Modem and...
Connecting 2wire router with desktop pc and laptop
hi! try to check the settings on your 2wire modem, you can do this by going to gateway.2wire.net, run the system setup wizard, when you get to the ppp authentication page, check the username & password on it, it should be the one that you setup for your ISP account. as for the wireless on the desktop, it depends on the brand of the wireless adapter, be sure you have installed the drivers for this adapter. you may need to go to the client utility manager or the wireless adapter shortcut/icon on your computer screen then configure it to "see" the 2wire network. make sure wireless encryption is turned on in the 2wire modem's MDC, you can do this by going to homeportal/management, or go to gateway.2wire.net/mdc.
Apr 11, 2008 | 2wire (1000-400108-001) Router
Arris WR850G Router (DHWR850G) Logo
154 people viewed this question
Top Arris Computers & Internet Experts
Jerry
Jerry
bobkoure
Level 1 Expert
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
