Question about Electrical Supplies
Photoelectric Control (Photo Eye), dawn to dusk, install
The photoelectric control (Ace Photo Eye), is on during the day. Do we need to 'set it' to recognize daylight or did I hook it up wrong on this new installation? It has a black, white, and red wire. Black is supply, White is neutral and Red is load. I connected black to black, white to white and red went to straight to the ground wire since there was nothing else to connect it to. The light is on and it is bright daylight.
Can you help?
Thanks!
Keith
Ace Hardware, Photoelectric Control (photo eye), #31668
http://www.acehardwaresuperstore.com/ace-photoelectric-control-4-1516-x-1-1116-x-1-p-19361.html?osCsid=430558681603561d9b40b2111b61b154
  • 3 more comments
  • dandkwilliam Nov 24, 2008
    Hi - there is no switch on this particular unit... thanks for trying... any other ideas?? I have 'direct wired' it so that my mother doesn't have to mess with switching it on and off at all...
    Well - rewired per your direction; covered the eye for 2 minutes, turned off power and 'reset'... uncovered ... daylight... and the light is still on... arghhhh!!!
    Well - rewired the black and red to the black; white to white...
    Turned off the power at the GFI breaker - covered the eye for 2 minutes, uncovered ... daylight... and the light is still on... arghhhh!!!
    any other ideas???
    Thanks for your ideas and help!
  • dandkwilliam Nov 25, 2008
    Hi--I tried that too. Frustrating. Cell must be bad. I'll take it back and try again. Thanks for your help. kw
  • dandkwilliam Dec 07, 2008
    I'm so sorry that we didn't get back to you all earlier! It seems that all it needed was to sit overnight to 'right itself'... and it is now working! We did the wiring, rewiring and everything else that was suggested. We had planned on taking it back - thinking it was a bad photo-cell... but... the next day it had fixed itself... guess it needed the night for an extended time to reset the cell... been working ever since.
    Thanks for all your help!
Connectthe SUPPLY wire (Black) to the Photoelectric Black. ALL of the white wires - to lights and from supply and on PE - connect together
Redfrom PE goes to all light fixture black lines
Posted on Dec 05, 2008
  • 333 Answers
One mor try or the cell is bad.Bring your power source wires into your box outside where photocell is placed on your wall. Wire all connections there from your power source which comes into your box for photocell. That is black from source to black on photocell, white from source to white on photocell and white from light. Remaining wires from your photocell which is red goes to black wire from light . No way it can't work this way. Mine has worked well for a year.
Posted on Nov 24, 2008
    Genius:
  • 1,605 Answers
The black wire and the red wire are connected to the black house line and the white is connected to the white house line, there is no ground wire.
cover the "eye" with an electric tape, the light should come on, the light should go out when you removed the tape.
if you want, you can run the red to a GFI breaker and back to the black house wire.
  • 333 Answers
In that case you probably have no ground wire. Just twist the black and res wires toghter and then twist the two to the black hot lead coming from the house, then connect the white wires and you should be set.
  • 333 Answers
Most of the times you have a switch on the unit that says phot or constant something of the sort. You might have it set that the light stays on or goes on with the wall switch.Check to see if you have that switch on it or behind it. I hope this helps you out.
Why does my dusk to dawn light with photo sensor turn on during the day and off during night?
Bad photo eye?
Photo eye has been rewired with contactor to reverse operation?
Add a comment with more information.
Copy following link for wiring and troubleshoot:
http://waterheatertimer.org/How-to-install-and-troubleshoot-photo-eye.html
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Aug 24, 2013 | Hardware & Accessories
Lithonia photocell light stays on during the day
1) Buy twist-lock photo control:
http://www.intermatic.com/en/Products/Sensors/PhotoControls.aspx
http://www.amazon.com/s/ref=nb_sb_noss_1?url=search-alias%3Dtools&field-keywords=twist+lock+photo+control
2) Spray bit of WD40 on twist-lock blades before installing new photo eye, and then rotate back and forth a bit to make sure there is electrical contact.
Test by placing black tape over photo eye.
Feb 14, 2013 | Hardware & Accessories
I need a replacement photoelectric switch for my outdoor Renaissance lamp model HB9902-98
The unit has motion-sensor/ photo eye capability built in.
There are no replacement parts for this type of device. Or long-term warranty.
The solution that comes to mind immediately is to rewire unit to by-pass the sensor, then install astro dawn-dusk wall timer in place of light switch.
http://waterheatertimer.org/How-to-wire-timers.html
Or install round box extension on the wall box, and wire up separate photo-eye mounted in the box extension.
Oct 13, 2012 | Hardware & Accessories
1st Question: Can Woods timer model 16ULD/3A be used for Christmas light timing? The timer is in the garage not exposed to water at all.
I am unable to identify the 16uld timer.
Amazon has a page of their timers. I am familiar with all of these.
http://picclick.com/Amazon/Home-Improvement/Electrical/Timers/
Woods timers and manuals show on following link
http://waterheatertimer.org/Woods-timers-and-manuals.html
If you can visually identify the 16ULD timer, then add a comment and I can answer your question.
That being said, any timer can operate Christmas lights.
If your timer has photoelectric eye, then it has to be placed outside where it can respond to dusk and dawn changes in light.
But there are some Woods timers that have photoelectric eye, and that feature can be overridden.
Again it depends on the timer, and clear identification would help numerous folk who are asking fixya about your same timer.
Dec 13, 2010 | Hardware & Accessories
How do I set it and can I use it indoors?
I see nothing in the manual that says 'outdoor use only' EXCEPT timer runs on photoelectric eye.
Timer turns ON automatically at dusk, so if timer is inside, and indoor lights are ON, then timer stays OFF.
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/hb51rc%20-%20english.ashx
http://www.intermatic.com/products/timers/consumer%20outdoor%20timers/electromechanical%20timers/hb51rc.aspx
To use timer outdoors.
Plug timer into wall.
Timer turns ON automaically at Dusk.
Rotate dial to set how long timer will stay ON.
Set timer to turn OFF 2 4 6 8 Hours after dusk
Set timer to turn off at dawn
Set timer to ON so lights are ON full time
Set timer to OFF so lights are off full time.
Dec 09, 2010 | Intermatic Outdoor Timer/Photo Control...
Will the HB51R have to be placed outside to work on dusk to dawn.
The dawn to dusk feature is activated by photoelectric eye that senses when it gets dark.
If you put timer in a dark room, it will turn ON ... let's say to operate Christmas tree after you leave a room for the evening.
But if room stays dark, the timer will not sense when to turn off unless you also set timer to turn off 1-9 hours after ON.
That being said, a Christmas tree might make too much light for the timer's photoelectric eye.
Make sure photoelectric eye is turned away from direct light.
My timer comes on at dusk and the lights blink on and off until they shut off 6 hours later.
1) Put black tape over photoelectric eye on timer.
Photo-eye is small round eyeball that bulges out.
See of lights stay on.
2) Turn timer away from source of light so photoelectric eye does not pick up feedback from lights.
It sounds like photo eye is receiving enough light that it turns off, 'thinking' it's dawn.
And then when lights are off, photo eye 'thinks' it's dark again, so lights come back on.
Let me know if this is the answer, because it's Christmas season, and folks have been asking about blinking outdoor timers. And then you're en-route to become fixya expert and boost your GNP by 3 cents an answer.
Nov 30, 2010 | Woods Outdoor Photoelectric 24 Hour...
My yard stake is a tower with 6 outlets and a single button to set, the brand is Holiday Living. I can't get it to come on at dusk and run for 4 hours without the lights blinking. I want a constant...
Put black tape over photo electric eye and see if lights stay on without blinking.
Dusk-type yard stake has photo electric eye, which is visible as round glass ball.
Lights from circuit can cause photo-eye to think it is daylight, so circuit turns OFF.
Moment later, photo-eye thinks it's dark and lights click back ON
Usually 6-outlet yard stakes have 4 top outlets controlled by timer.
Normally bottom 2 outlets are ON full time.
Make sure bottom outlets are not blinking also, which implies problem with outdoor circuit or basic timer problem.
Check circuit with inexpensive circuit analyzer from Home Depot electric department.
Photoelectric eyes go bad easily, but usually they don't blink.
They stick ON or OFF.
Nov 29, 2010 | Solar Noma 7 Day, 6 Event Outdoor Timer -...
We need clear instructions for setting the timer
Woods makes several outdoor timers:
Image that shows with this post is Woods model #49647.
Below are instructions for #49647 timer.
If your timer is different, add a comment with model number and I'll post instructions for that timer.
Woods model #49647 is outdoor timer with photoelectric control that turns timer ON at dusk.
There are 4 possible settings that show on dial.
Rotate dial to make timer selection.
OFF = timer is OFF full-time until you change dial.
ON = timer is ON full-time until you change dial.
Dusk-Dawn = timer turns ON at dusk and OFF at dawn
2, 4, 6, 8 hours = timer turns ON at dusk, and turns OFF 2, 4, 6, or 8 hours later.
Nov 26, 2010 | Woods Outdoor Lighting Timer
Need wiring diagram for installing a photoelectric switch to turn lights on at dusk and off at dawn. 3 wires, red, white and black.
I am reasonably sure the black wire connects to the black/hot power wire coming in, and the red continues on to the light. I am positive the white wire is connected to all the other white wires. The white wires usually do not connect anywhere on the device, just wire nutted together in the box
Oct 30, 2009 | General Electric Ge 3s7505ss510a6...
Electrical Supplies Logo
7,778 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
