Question about Philips Magnavox Learning Universal Remote
Codes and auto don't seem to work as per instructions on internet
Hi I have a sanyo tv and the internet gave me two codes;0035 and 0039,press set button enter code press set. I tried and it doesn't work.
the auto one was; press set for 2 sec, press tv
reoeatadly press vol+ until tv turs off and press set.
Itried all this to no avail, what am I doing wrong ?
regards Ronnie Fogarty
Hi the answer is, find the original manual and then you realize that the codes you give for the sanyo are wrong, and the manual is right. 0035 & 0039
If I HAVE A SOLUTION i GIVE IT FOR FREE
Posted on Nov 25, 2008
What remote codes do we need to connect remote to Sanyo TV model 3264B 2008.
Mary, Universal remote codes for Sanyo TV model 3264B Check the attached links,instruction and guides containing 3 and/or 4 digit codes, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://codesforuniversalremotes.com/universal-remote-control-codes-sanyo-tvs
How to Set Up the Codes for Sanyo Television and Remote
4 digit codes for TV sets including LCD Plasma and Panel TVs GE universal...
Apr 26, 2016 | Sanyo Televison & Video
I have a TV 139f universal TV remote, my TV is a Sanyo 32xr8da.can't seem to set it up.
here are instructions, there are various codes for Sanyo in the 3rd image, try each until one works. Post back with difficulties or successes25281847-n1rm044d2kbvhi1lhg52tcvk-1-0.jpg 25281847-n1rm044d2kbvhi1lhg52tcvk-1-9.jpg 25281847-n1rm044d2kbvhi1lhg52tcvk-1-13.jpg
Nov 13, 2014 | Televison & Video
Dish tv remote code
Hi L. Pruett, my name is Mike Houston of DISH Network and withthe Durabrand TV there are a couple of codes we do have for that TV. The threedigit codes will be 220 and 233 and what you will want to do is hold down the clearTV button until all the mode buttons light up. Press one of the three digitcodes I have sent press the # button and then press the Red TV button on theremote, the TV should have turned off and if not after trying the two 3 digitcodes I will send you a link for a Power Scan; http://www.dishnetwork.com/SupportSection/power-scan-instructions- Mike H.
Nov 14, 2011 | Durabrand DU1901 TV
What is my tv code for programming my dish network remote.
Hi!
Welcome to FixYa!
You can use these codes to program the Dish remote control to your Sanyo DS32920:
542, 589, 590, 591, 592,609
You may also try Power Scan Instructions. Please follow the steps bellow.
1. While at the TV locations (TV1 or TV2 depending on which key is installed), point the remote at the TV. Press and hold the TV MODE button on the remote until all four MODE buttons at the top of the remote light up.
2. Press the RECEIVER POWER button on the remote.
3. Press the UP ARROW on the remote, about one press every two seconds. Stop as soon as the TV turns off. This process may take several minutes.
4. Press POUND (#) on the remote. The TV MODE button will flash three times.
5. Press TV POWER on the remote to turn on the TV. Press VOLUME on the remote to confirm the remote controls the TV. If this does not work, return to Step 1.
Keep me posted.
Thanks.
Lor04
Apr 07, 2011 | Sanyo DS32920 32" TV
I need a code to use a universal remote on a Sanyo TV, model # DS13330
Codes depend on the remote brand. However, if your TV was built 6 months before the remote was programmed or was manufactured after the remote was produced, then it may not have that code.
RCA remote codes for Sanyo include: 017,021,039,056,057,058 . You can also try the search for code function: turn on the TV, press and hold the code search button. When the indicator light comes on, press and release the TV button. Then hit ON/OFF once per second until the TV goes off. (This can take 100 tries.) Press Enter. If the TV responds to other commands, it is set. Otherwise repeat the scan.
Philips remote codes for Sanyo: 002 412 506 619 902 (for one of the units) Use http://www.urc.philips.com/ to find your specific remote and its code list.
I hope this helps.
Sep 14, 2010 | Televison & Video
I need tv tuning codes for sanyo c25eg95b
Read the Instruction Manual for the Universal Remote Control it should have an Auto Tune feature where you can set the code by pointing the control at the TV when on and pressing the POWER ON and SET button on the control together for 3 seconds, when the TV turns off press the TV button immediately, Good Luck
May 17, 2010 | Sanyo Televison & Video
Sanyo TV I need a code for my optimum cable remote control to turn on and off the TV with their remote control.
Here's the instructions and codes plus an alternative method if one of the codes below do not work.
Three-Digit Code Programming Method:
  1. Turn on the TV.
  2. Press and hold the TV and DONE buttons simultaneously for 3 seconds. The iO button will light.
  3. With the iO button lit, point the remote at the TV and enter the TV's three-digit code (see code table below). The TV will shut off when the correct code is entered.
  4. Verify by pressing the SEL button. This should turn the TV on and off.
  5. Press the TV button to store the three-digit code. The iO button will blink twice to confirm that the code is stored.
Codes: 007, 053, 057, 082, 020, 239
Auto Search Programming Method Use this method if the three-digit code method does not successfully program your remote control:
  1. Turn on the TV.
  2. Press the CBL and DONE buttons simultaneously for 3 seconds. The iO button will light.
  3. Hold down CH+ and release it as soon as the TV powers off.
  4. Press CH- five times (the television may or may not turn on again as you do this). If the television does not power, turn it on manually before proceeding.
  5. Press CH+ one at a time until the television shuts off.
  6. Press TV to save the code.
To save time, the Auto-Scan function is trying codes as fast as possible while CH+ is being held down. It scans so fast that you may pass the desired code while holding down the CH+ button. Steps 4-5 allow you fine tune the auto-scan so you reach the correct code.
Nov 26, 2009 | Sanyo Televison & Video
Urc-3021Boo one for all set up and codes for a sanyo tv
To control a Sanyo TV with a One for All URC-3021, follow these steps:
1) Turn on your TV.
2) On the remote, press the TV key once.
3) Press and hold SET until the LED blinks twice, then release SET.
4) Enter the code 0154.
The LED will blink twice.
If it does not blink twice, go back to step 2 and try the same code again.
5) Aim the remote at the TV and press POWER.
The device should turn off.
If it does not turn off, try the auto-search function.
To search for a code for your TV:
  1. On the remote control, press TV once.
  2. Press and hold SET until the LED blinks twice, then release SET.
  3. Enter 9 - 9 - 1.The LED will blink twice.
  4. Aim the remote control at the the TV and slowly alternate between pressing POWER and TV. Stop when the TV turns off.
  5. To lock in the code, press and hold SET until the LED blinks twice, then release SET.
Hope that helps.
Oct 17, 2009 | One For All URC-3021 Remote Control
Power plus universal remote control codes
Try downloading this manual
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/mitsubishi/bd512-manual.zip&area=other
Jul 13, 2008 | Televison & Video
Lost codes for 4 in one used for universal remote control
DRC800 Sanyo TV 0799,0154,0893 Panasonic VCR 0035,0162,1062,0616,0225,1035 press device key for 6 seconds led will blink solid key in code correct code will cause led to blink 3 times press power button to confirm code works. rg
Sep 09, 2007 | Philips 8-Function Universal Learning...
Philips Magnavox Learning Universal Remote Logo
55 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
