Question about Kenmore 31913 Progressive Direct Drive Bagged Upright Vacuum
Kenmore 31913 Foot pedal release lever broken-need to replace
1. Foot pedal release lever broke and now the whole vacuum falls down hitting objects (and me) and has caused dents and damage to furniture and household items. Can't find Kemore upright vacuum model 116.31913101 parts #8174906 Pedal or #8174907 Plate, Pedal Washer (non-service item) on any site so I can order and replace this myself before I get killed by this errant cleaning device.
Thanks, a frustrated vacuum owner,
Judi from Parker, CO
FixYa techs - thank you for your response but I solved the problems. It took me 2 hours of continual searching but I finally found the parts - listed under the tab sew machines of all things!? There is one pedal in stock and I called the service company and will pick that up and do it myself. I took that part off my vac and put it back on so know I can do it. I've been fixing stuff all my life and it just takes some logic - anyone can do it if they have a tool kit.
Posted on Nov 25, 2008
The handle release pedal wasn't allowing the handle to lower. I took off the pedal and saw the spring load part was broken. What is this part and how to replace it? Bissell 3760-3 handle release
Order Slider Release (7.93, vacpartswarehouse) Pull off 'tank.' Remove 3 Screws for Foot Detent Lever. Pull off. Remove old slider release and spring (verify it's broke.) Replace with new. I just did this today after a year of dealing with it.
Mar 04, 2012 | Vacuums
My vaccuum lost suction
Sep 16, 2010 | Kenmore 31913 Progressive Direct Drive...
Foot controlled handle release lever is broken. Where to get parts?
I had same problem - the foot release pedal would not spring into place when unit was upright (but would work if you nudged in place with your foot). I installed a replacement part, and it didn't fix the problem. I cut out a small sqare of sponge and jammed it behind the flat end of the bent plastic spring on the release pedal, and it now springs back as it shoud. Hope this helps.
Jan 11, 2010 | Hoover U6630-900 WindTunnel Bagless...
Stand up lever is plastic, broke when stepped on to release handle, can it be repaired, replaced with a better one, plastic breaks too easily?
The pedal release can be replaced but the base will need to be checked for cracks as well. if the base is broken most common is the socket the pedal release snaps into. some of the plastic parts have been made with better materials
Oct 20, 2009 | Hoover Ultra U6430-900 WindTunnel Bagged...
Foot latch is broken. need to replace with new one. how does one access to remove the foot pedal latch. By foot latch, I mean the foot lever that releases the upright to lower the handle and begin...
it is accessed from the bottom underneath by the rear wheel. However, If there are and cracks on the pedal release socket area then the base will need replacement. parts are little cost but the unit needs to be completely disassembled.
Oct 17, 2009 | Hoover U6446-900 WindTunnel Bagged Upright...
Pedal does not engage anymore
I have the same problem. You will need to replace the handle release pedal, part number 8174899, $7.99 plus tax & shipping. Check with Sears Parts. It's a single screw that holds it in place.
Jun 29, 2008 | Vacuums
Foot Pedal Broken
For the handle release, part number is Detent Lever 2030052 Try, or call a local repair shop, if they repair Bissell's, then they may have this part in stock. You shouldn't have to take it aprt, there 2 tabs on the release that fit into slots on the base, there move the slots so as to release the tabs.
Jun 21, 2008 | Bissell 3594 CleanView PowerTrak Bagless...
Bissell Bagless Vacuum cleaner
There is no release, the part is a plastic handle release lever, you can find those at, the cost is approximately 2.29 each, I have replaced more than 20 of these on the commercial vacuums for my cleaning crew, the part is easily broken and easily replaced. I always have 6 or more on hand.
Turn the vacuum over, remove the bottom plate, with a flat head screw driver punch out the old part. turn the vacuum upright again after the broken part is removed. With the body laying back on a hard surface, carefully push in the new part. Unfortunately, these are plastic, too bad they cannot design a more sturdy part for this.
Apr 10, 2008 | Bissell 3522 PowerForce Bagged Upright...
Foot Pedal was knocked out of alignment
You will have to take the top loose so you can put the handle release in its place. It probably isn't in the right place, either that or a piece of it broke off and it needs to be replaced.
Mar 16, 2008 | Bissell 1699 ProHeat Clear View Upright...
Kenmore 31913 Progressive Direct Drive Bagged Upright Vacuum Logo
572 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
