Question about Emerson EWF2703 27" TV
Tv stuck in game mode
I can turn on the tv and it goes to game mode.....if I switch it to picture all I have is snow and no sound. How do I get it out of game mode. Have followed manuals directions and it does not correct problem.
SD Tech
  • 14553 Answers
SOURCE: model ewt1321 emerson tv stuck on channel22 so direct tv will not work snow only
with the set turned off --unplug it for a few minutes and plug back in which may allow it to reset itself
Posted on Mar 23, 2012
0 characters
1 Points
I have no picture.
Just a thought from out of date tv user. Make sure there is power at outlet. If you have cable or antenna connected, make sure it is set to the right mode. One mode is all the tv channels, another is simply a second imput like vcr, and may have a third mode for games etc. On mine, each mode is specific to a set of terminals (yell/red/wht) on the tv back side (3 sets of terminals back there with each used with one mode), if in the wrong mode won't connect with input signal. Switch tv on then find the mode switch and try each one to see if you can get a picture or even snow. May also have some auto feature that if signal isn't detected, it won't startup the big screen (so you don't get blast of loud sound and snowy picture), try a spare tv on the input signal to see if the input signal is there and working. Hope that helps.
Jan 13, 2011 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Sony kv 27V15: No picture but sound
Hi! the trouble indicates that your television's picture is the culprit, have your unit check by a qualified technician for verification.
Sep 12, 2009 | Sony KV-27V15 27" TV
Toshiba television will change from tv/video mode to
I would check to see if the Input button is stuck on the front panel of TV. If it is not stuck then it is probably still bad. Tactile switches are notorious for failing in this manor. The only real fix if it is not stuck down is replacing the switch.
I hope this helps,
Jun 22, 2009 | Toshiba 36A43 36" TV
Stuck on channel 2, "No Signal" and snow
Two things may be at play here. The tv might be only programmed for reception on channel 2 and will need to be re programmed to receive other channels.
Also try some basic troubleshooting on the remotes. Start with the remote that came with the tv. Replace the batteries try the "MENU" button. If you can get into the menu try to "autoprogram" the TV
May 01, 2008 | Sony KV-36FS100 36" TV
Channel Reception
It sounds like a defective tuner or a IF module as well. It may also be a defective capacitor(s) or cold solder joints inside the tuner circuitry. I woud suggest to use a VCR or a TV convertor connected to an Audio/video input to change channels instead of fixing it.
Good Luck.
Jan 21, 2008 | Sony KV-27V42 27" TV
Tv seems ok by static and now, no sound (or very faint)
The problem you're describing sounds like a tuner problem. BUT you say that you have the same problem with A-V input too. That's weird!!! Possibly the electronic TV-AV switching circuit is messed up and stuck in the TV (tuner) position. If this is the case you DO have a tuner problem and a switching problem too.
Jan 14, 2007 | Hitachi C29-F200 29" TV
Erratic behavior...
Change all the little switches (on-off, channel up etc). If just one of the switches is intermettent, or a combination of one or more, it can cause you moe misery than you can imagine. The switches are not expensive but can cause you to lose an awfully lot of time and agravation.
Nov 24, 2006 | GE 31GT740 31" TV
No Picture, sound is all static
Make sure the ant. input switch didnt change and check the ant. connections If that dosent work sounds like a defective tuner.
Mar 30, 2006 | Philips Magnavox 27MS343S 27" TV
Emerson EWF2703 27" TV Logo
32 people viewed this question
Top Emerson Standard (CRT) Televisions Experts
Jaime Hernandez
matt martin
matt martin
Are you an Emerson Standard (CRT) Television Expert? Answer questions, earn points and help others
