Question about Fisher and Paykel Fisher Paykel Intuitive Eco Washer IWL15
HELP!! fisher and paykel intuitive clothes washer: error code 36
Can anyone advise me what error code 36 is? Machine has stopped. Thank you.
    Scholar:
  • 76 Answers
Schmotty, An error code "36" means Water leak fault: The Motor Control Module has needed to top up the water level more than 4 times during agitate. This is excessive, as normally only one or two top ups are required to replace the air that has escaped from a full load during agitate. The most likely cause is that the machine is siphoning. The other alternative is that the machine has developed a leak.Thats what you have to do: Primary Source: Pump System. Action 1) Check the height of the drain hose outlet. Minimum 33.46in / 850mm, maximum 47.24in / 1200mm. 2) Check that the hose guide is fitted and check that the hose does not protrude more than .78in / 20mm beyond the guide. Secondary Source: Mechanical. Action: 1) Check the pressure tube connections on the outer basket and Motor Control Module. 2) Check that the drive shaft seal and the pump housing seal have not developed a leak. Tertiary Source: Motor Control Module. Action: Replace Motor Control Module. Gendos...post it
Posted on Jan 02, 2007
FISHER PAYKEL WASHING MACHINE FAULT CODE 56 DOES ANYONE KNOW WHAT IT MEANS
Error code 56 is mostly the motor controller, SD11 & SD12 brown boards, 3 x 332k resistors near the small transformer go low & need replacing with a 1 meg Ohm resistor will fix the problem.
May 22, 2011 | Fisher and Paykel Fisher Paykel Intuitive...
Code 37 -
To my knowledge, Error Code 37 on a Fisher & Paykel machine refers to "drain fault" which could either mean that the drain valve will not open or that the drain pump will not run. The easiest user intervention that could be performed is to check for any blockage/clog at the drain filter, drain pipe, drain pump impeller and drain valve.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 16, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Water sensing level not working on Fisher & Paykel Eco Intuitive washing machine . The water just keeps filling up until I stop it manually . We can't use the machine to wash clothes as the Service...
Your pressure value switch is malfunction. First thing you can try that is cheap to fix is to try clean the hose that connects to the outer tub. A lot of times there is algae develops after years of washing.
May 07, 2011 | Fisher and Paykel Fisher Paykel Intuitive...
Hello -Just looking for help on fixing a service code 66 which comes up when you turn the power on. Unknown age on machine. Fisher and paykel intuitive eco model IW811
HI error code 66 means you have a pressure transducer out of range error.This means that the control module is faulty and needs replacing.please confirm that the error code is numbered 66.Please reply for further help and clarification of this fault code.Hope this helps.
Jun 02, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher and Paykel error codes
Think you have the same problem I had ! I changed the water pump and cured the problem. Hope this helps !
Mar 30, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Intuitive eco fisher & paykel washing machine
this is a pretty clear cut fault (66). It is a problem with the pressure transducer (water level). The only cure is to replace the motor controller (which is the lower of the 2 modules in the console)
Oct 23, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher and paykel intuitive washer what is a code 43 please
HI, Go to this site is has all fault codes all you do is find your product click it and it will show you the fault codes and what they mean and suggest how to fix it. http://www.repairclinic.com/0078.asp
Jun 09, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Error codes
We have an instruction manual but there are no codes.
Apr 15, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
IW712- fisher paykel intuitive eco.
I BELIEVE THAT IS A ROTOR SENSOR ERROR
REPLACE THE ROTOR SENSOR
Feb 15, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
364 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Archie Ferrarini
Archie Ferrarini
shaun taylor
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
