Question about Jensen 100W x 4 Amplifier KA5 Car Audio Amplifier
My amp wont work
The light on my amp keeps going from the green light to the green light. it isent the fueses or the groung. what is the problam?
  • 631 Answers
The amp probably has shorted output transistors. To eliminate other possible causes, read through the following page:
Amp in Protect Mode - Troubleshooting
Let me know if you have any other questions.
Posted on Nov 25, 2008
Blown fuses but a new one and now the tails wont go off i have to pull the fuese
is it your brake light i would check the switch on your brake pedal that could be shorted and caused your fuse to blow and maybe now its not working keeping your light on
Feb 18, 2013 | Cars & Trucks
99 Grand Cherokee headlights keep popping fuese
The circuit load is much higher with the HID lights, you need to rewire the headlights to a large gauge wire.
Jul 03, 2012 | 1999 Jeep Grand Cherokee
When I pulled bed off ,wires were cut. I have 2 green wires cut making 4 ends, 1 black wire and one white wire. I assume the green go with green , but the black ground and white wire I am not sure where...
Use a test light and check which wire has power as you turn on each function. The ground can be checked with an ohm meter . Put one lead of the meter on a clean groung spot on the frame and test each wire with the other lead . The wire that shows infinity or 0 resistance should be groung .
Oct 22, 2010 | 1990 Chevrolet C1500
91 Geo tracker , Starting problems
my geo tracker wont turn over the lights wont come on nothing is working iv tested the battrey its fine and checked all the fueses they are fine too why is there no power to any thing?
May 31, 2010 | 1991 Geo Tracker
Needs a new battery. The alternator meter reads charge. The battery doesn't seem to have umph... What battery is best and cheapest?
The cheapest battery isent the best to get as the one which sells a lot is good and the ALTERNATOR must charge at 13.5 amps and battery 12volts.
Turn on head lights and start engine if lights brighten up then its charging But if the lights dont go bright then the alternator isent up to standard so get it reconed So check charging before buying a battery. Let me know how you go with it Ron
Oct 15, 2009 | 1996 Ford Explorer
Alpine amp wont turn on..
your power wire is sufficating yor amp probably
Jul 29, 2009 | Kenwood KAC-8152D Car Audio Amplifier
CAR WONT START BUT LIGHTS STILL WORK
with headlights on, try cranling the engine. I they dim the batt is no good, If they go out, you have a battery connection problem/loose or poor contact on groung(neg) cable. If nothing happens your starter relay is kaput.. Good luck
Jun 14, 2009 | 1995 Lincoln Town Car
Brake Lights Out
Hi welcome to fixya.com
Try putting on your flashers,and see if they come on.
Sounds like a loose groung wire usually green.They need to contact bare metal.lots of times they just need retighting.
Dec 13, 2008 | 2006 Hyundai Sonata
Jensen 100W x 4 Amplifier KA5 Car Audio Amplifier Logo
152 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
